New features update:
Compiler Optimization flags are supported for IAR application and library projects:
1. -On / -Ol / -Om / -Oh / -Oh -Ssize / -Oh -Sspeed / -Oh -Sbalance / --no_size_contraints
2. Enabled transformations checkbox items in Optimization tab are enabled by default, each item could be disabled by adding cx-flags settings in yml:
--no_cse / --no_unroll / --no_inline / --no_code_motion / --no_tbaa / --no_clustering / --no_scheduling
Note: Vectorization setting is to enhance DSP performance for Arm Cortex-A NEON units, not supported now.
The usage is same with existing merge-to-freertosconfig. For more details, please review Release Actions of Generator in SDK 2.x.
Here is an example:
mcux-undefine tag has been enabled in yml setting for Mcuxpresso IDE.
For example:
In yml file:
And this macro will show in Undefined symbols:
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
