Creating dependencies between middleware components
PetrKraus
Comprehensive information about SDK SW components and SDK release describing YML can be found in the Yml data record guide here:
http://10.193.108.154:4000/mcu-sdk-generator/doc/Yml%20data%20record%20guide.html#add-a-middleware-y...
Example
We need to build a dependency from the eIQ component to the CMSIS DSK Library component.
It is needed to add the dependency definition into the __requires__ section of the dependent component into YML:
middleware.eiq.cmsis_nn:
  section-type: component
  __requires__:
    - middleware.eiq.ui_control
      CMSIS_DSP_Lib.arm_cortexM7lfdp_math
  contents:
    cc-include:
      - path: middleware/eiq/cmsis-nn/Include
    files:
Such dependency will be reflected on the MCUXpresso website and also in the SDK manifest file:
    <component id="middleware.eiq.cmsis_nn.MIMXRT1052" name="CMSIS-NN" brief="CMSIS-NN library" version="1.0.0" full_name="CMSIS-NN library" devices="MIMXRT1052xxxxB" dependency="platform.CMSIS_DSP_Lib.arm_cortexM7lfdp_math.MIMXRT1052" category="Machine Learning/eIQ" user_visible="true" type="middleware">
      <source path="middleware/eiq/cmsis-nn/Include" target_path="CMSIS/NN/Include" type="c_include">
        <files mask="arm_nnfunctions.h"/>
        <files mask="arm_nnsupportfunctions.h"/>
        <files mask="arm_nn_tables.h"/>
      </source>
How to verify that the dependency has been correctly described it will really work in the SW tools?
  1. You can generate an SDK package with this component and check the behavior in the MCUX IDE.
  2. You can check SDK release data tables - output of the first two stages of the SDK Generator, where the component dependencies are resolved:
    1. Run “ruby all_evkxxx.rb -a eiq -c superset -o target_dir“, in the target_dir/devices/<xxxx>/<xxxx>.yml, you can check under your middleware.eiq.ui_control, it should have the “CMSIS_DSP_Lib.ui_control” in the “web_requires”, like
      middleware.eiq.ui_control:
        section-type: component_support
        __requires__:
          - board.evkbimxrt1050
          - board.evkmimxrt1060
        component_info:
          common:
            ui_name: eIQ
            ui_description: eIQ machine learning
            ui_category: Middleware
            ui_control: 'True'
            ui_control_default: 'False'
            ui_release_specific: 'True'
            full_name: eIQ
            class: Machine Learning
            version: 1.0
        web_requires:
          - CMSIS_DSP_Lib.ui_control
  3. You can ask the SWPE team to deploy your experimental SDK release superset with this change on an MCUX sandbox website - follow instructions described here: https://confluence.sw.nxp.com/display/MCUXSDKB/Deployment+of+an+experimental+SDK+release+image+on+th...
