More on MCUXpresso and BCA
4,377 次查看
JBM
I am porting an older application with bootloader functionality to MCUXpresso.  I have read a number of posts here and this on in particular seems to apply:
https://community.nxp.com/message/1004329?commentID=1004329#comment-1004329
In the end, it appears that the best way was to modify the linker scripts and, I assume, not use the managed linker script.   Has anybody been able to load the BootloaderConfig at a specific address with the MCUXpresso manageed linker script?
I have already got the flash relocated (I think) to the right address for my bootloader application. Now I would like to figure out how to move the BCA (I've done it by modifying linker scripts) using the managed linker script.
标记 (2)
6 回复数
4,224 次查看
nxf56274
I write a document to show you how to allocate the data at specified address.
TIC
4,224 次查看
JBM
I've already done what is in this document.   Another person wrote a similar document a year or two ago.  My question was, has anybody done with WITHOUT turning off the managed linker script functionality?
4,224 次查看
nxf56274
If you do not turn off managed linker script, you can't modify the ld file. When you modify the ld file without turning off, the modification will not effect.
TIC
4,224 次查看
ErichStyger
Specialist I
In 99.9% you don't need to turn off managed linker scripts, because you can add/change things with the FreeMarker scripts. Turning off managed linker scripts bypasses all the checks of the linker file and should not be done: using the FreeMarker way has worked very well for me.
4,224 次查看
JBM
Thanks Erich, I'll take a look at that.
4,224 次查看
ErichStyger
Specialist I
