Accidental "unlock kinetis" command on K20 of FRDM-KW36 Board.
erickr
I have accidentally used "unlock kinetis" command on the K20 chip of FRDM-KW36 board. I've mistakenly plugged the Jlink on the J14 header instead of J12. Now I am not able to use the board using USB. Is there a way to fix this? Please help.
Kind regards
