What is the latest version of the Radar SDK?
6,163 次查看
jane_yu
What is the latest version of the Radar SDK? Is there a newer version than SW32R37-RSDK-RTM-1.1.1?
Thank you!
标记 (1)
8 回复数
5,749 次查看
Daniel_Popa
Hi Jane,
The latest one is  RTM-1.1.1
5,747 次查看
Daniel_Popa
Version 1.2.0 is now available here
5,747 次查看
jane_yu
Hi Daniel,
Thank you!
I have installed S32R27X-37X_RSDK_RTM_1_2_0, I want to use DCC development kit run 1RF 4Antennas Demo, Which project should I use?
5,747 次查看
Daniel_Popa
pavelagrigoroaei-b44148‌,
Can you suggest which project is needed ?
Thank you!
5,747 次查看
jane_yu
Hi Daniel,
1RF 4Antennas Demo. An error occurs when I built the project,Can you tell me where the problem is?
Thank you!
5,747 次查看
b13310
could you please clarify for me what method you used to import project - if you had "copy project into workspace" checked?
Irina
5,747 次查看
jane_yu
Hi Irina,
I had "copy project into workspace" checked,the method I import project as follows:
5,747 次查看
b13310
this is what I suspect.
Could you please try to import it again without this option checked (you would need either remove project you already imported, or use new workspace)
Irina
