mtd-utils for ls1046afrwy repository
已解决
跳至解决方案
1,227 次查看
williawh
Where should I pull mtd-utils from that is supported by NXP and freescale/layerscape?
I am needing to boot from QSPI with rootfs on NAND IFC similar to:
https://community.nxp.com/t5/Layerscape/Reading-from-a-Ubifs-filesystem-on-LS1046-Freeway/m-p/117877...
https://community.nxp.com/t5/T-Series/T1024RDB-NAND-UIB-ECC-error/m-p/1039573
Need mtd-utils for setting up NAND flash.
William
1 解答
1,180 次查看
williawh
I found that if I build the ubuntu:main rootfs, it does contain the mtd-utils...
William
在原帖中查看解决方案
2 回复数
1,203 次查看
williawh
Just wondering, once I get the kernel configured properly with mtd, ubi, and ubifs are the necessary commands available at that time or do I still need to install mtd-utils and needed dependencies?
1,181 次查看
williawh
William
