Where should I pull mtd-utils from that is supported by NXP and freescale/layerscape?
I am needing to boot from QSPI with rootfs on NAND IFC similar to:
https://community.nxp.com/t5/T-Series/T1024RDB-NAND-UIB-ECC-error/m-p/1039573
Need mtd-utils for setting up NAND flash.
William
已解决! 转到解答。
Just wondering, once I get the kernel configured properly with mtd, ubi, and ubifs are the necessary commands available at that time or do I still need to install mtd-utils and needed dependencies?
