make error in dpdk of LSDK20.12
1,230 次查看
rashmikj
When i try build dpdk of LSDK20.12 with the following command on target board,
make T=arm64-dpaa-linuxapp-gcc install CONFIG_RTE_KNI_KMOD=n CONFIG_RTE_EAL_IGB_UIO=n -j 4
it shows this error
/home/user/dpdk20/dpdk/arm64-dpaa-linuxapp-gcc/.config:4: *** missing separator. Stop.
/home/user/dpdk20/dpdk/mk/rte.sdkroot.mk:110: recipe for target 'all' failed
make[2]: *** [all] Error 2
/home/user/dpdk20/dpdk/mk/rte.sdkinstall.mk:60: recipe for target 'pre_install' failed
make[1]: *** [pre_install] Error 2
/home/user/dpdk20/dpdk/mk/rte.sdkroot.mk:89: recipe for target 'install' failed
make: *** [install] Error 2
Kindly help
1 回复
1,224 次查看
yipingwang
On the target board, please remove folder "arm64-dpaa-linuxapp-gcc", then run the following command.
