lx2160ardb's network could not work for lsdk20.04
6,046 次查看
zhanghonghui
Hi, I'm using the lsdk20.04 BSP compile the BSP images for lx2160ardb:
 flex-builder -m lx2160ardb -a arm64
and flash the images to a usb stick by flex-installer and then bootup from the usb stick, everything seems alright except that the network interface could not workable.
I tried the dpmac.17 and dpmac.18 and it could assign IP address to those interface, but there's no response when I plugin/plugout the ethernet cable from that ports, and I got all the package lost when do ping to other host.
But those port works fine in uboot stage or system boot from my flash using tiny system.
I'm not sure what's wrong, I guess its the ethernet driver problem. could you please help to take a look.
[ 6.097780] mmcblk1boot0: mmc1:0001 R1J59E partition 1 8.00 MiB
[ 6.101813] lib80211: common routines for IEEE802.11 drivers
[ 6.107861] mmcblk1boot1: mmc1:0001 R1J59E partition 2 8.00 MiB
[ 6.113367] lib80211_crypt: registered algorithm 'NULL'
[ 6.119271] lib80211_crypt: registered algorithm 'WEP'
[ 6.119273] lib80211_crypt: registered algorithm 'CCMP'
[ 6.119275] lib80211_crypt: registered algorithm 'TKIP'
[ 6.119302] 9pnet: Installing 9P2000 support
[ 6.119349] mmcblk1rpmb: mmc1:0001 R1J59E partition 3 4.00 MiB, chardev (508:0)
[ 6.123589] tsn generic netlink module v1 init...
[ 6.135583] Key type dns_resolver registered
[ 6.140103] registered taskstats version 1
[ 6.144196] Loading compiled-in X.509 certificates
[ 6.149813] Btrfs loaded, crc32c=crc32c-generic
[ 6.155555] fsl_mc_dprc dprc.1: Adding to iommu group 0
[ 6.214553] fsl_dpaa2_eth dpni.1: Adding to iommu group 0
[ 6.219984] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 6.226379] fsl_dpaa2_eth dpni.0: Adding to iommu group 0
[ 6.231794] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 6.238180] fsl_mc_allocator dpbp.1: Adding to iommu group 0
[ 6.243878] fsl_mc_allocator dpbp.0: Adding to iommu group 0
[ 6.249581] dpaa2_mac dpmac.18: Adding to iommu group 0
[ 6.254808] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 6.261190] dpaa2_mac dpmac.17: Adding to iommu group 0
[ 6.266419] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 6.272801] dpaa2_mac dpmac.6: Adding to iommu group 0
[ 6.277941] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 6.281232] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 6.284330] dpaa2_mac dpmac.5: Adding to iommu group 0
[ 6.290563] scsi host4: usb-storage 1-1:1.0
[ 6.295519] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 6.306077] dpaa2_mac dpmac.4: Adding to iommu group 0
[ 6.311217] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 6.317601] dpaa2_mac dpmac.3: Adding to iommu group 0
[ 6.322742] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 6.329125] dpaa2_mac dpmac.2: Adding to iommu group 0
[ 6.334268] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 6.340657] dpaa2_caam dpseci.0: Adding to iommu group 0
[ 6.345997] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 6.369292] fsl_mc_allocator dpmcp.35: Adding to iommu group 0
[ 6.376351] fsl_mc_allocator dpmcp.34: Adding to iommu group 0
[ 6.383378] fsl_mc_allocator dpmcp.33: Adding to iommu group 0
[ 6.390411] fsl_mc_allocator dpmcp.32: Adding to iommu group 0
[ 6.397377] fsl_mc_allocator dpmcp.31: Adding to iommu group 0
[ 6.404362] fsl_mc_allocator dpmcp.30: Adding to iommu group 0
[ 6.411391] fsl_mc_allocator dpmcp.29: Adding to iommu group 0
[ 6.418360] fsl_mc_allocator dpmcp.28: Adding to iommu group 0
[ 6.425331] fsl_mc_allocator dpmcp.27: Adding to iommu group 0
[ 6.432362] fsl_mc_allocator dpmcp.26: Adding to iommu group 0
[ 6.439331] fsl_mc_allocator dpmcp.25: Adding to iommu group 0
[ 6.446306] fsl_mc_allocator dpmcp.24: Adding to iommu group 0
[ 6.453331] fsl_mc_allocator dpmcp.23: Adding to iommu group 0
[ 6.460315] fsl_mc_allocator dpmcp.22: Adding to iommu group 0
[ 6.467283] fsl_mc_allocator dpmcp.21: Adding to iommu group 0
[ 6.474302] fsl_mc_allocator dpmcp.20: Adding to iommu group 0
[ 6.481339] fsl_mc_allocator dpmcp.19: Adding to iommu group 0
[ 6.488320] fsl_mc_allocator dpmcp.18: Adding to iommu group 0
[ 6.495295] fsl_mc_allocator dpmcp.17: Adding to iommu group 0
[ 6.502322] fsl_mc_allocator dpmcp.16: Adding to iommu group 0
[ 6.509356] fsl_mc_allocator dpmcp.15: Adding to iommu group 0
[ 6.516349] fsl_mc_allocator dpmcp.14: Adding to iommu group 0
[ 6.523324] fsl_mc_allocator dpmcp.13: Adding to iommu group 0
[ 6.530338] fsl_mc_allocator dpmcp.12: Adding to iommu group 0
[ 6.537373] fsl_mc_allocator dpmcp.11: Adding to iommu group 0
[ 6.544372] fsl_mc_allocator dpmcp.10: Adding to iommu group 0
[ 6.551344] fsl_mc_allocator dpmcp.9: Adding to iommu group 0
[ 6.558237] fsl_mc_allocator dpmcp.8: Adding to iommu group 0
[ 6.565144] fsl_mc_allocator dpmcp.7: Adding to iommu group 0
[ 6.572043] fsl_mc_allocator dpmcp.6: Adding to iommu group 0
[ 6.578993] fsl_mc_allocator dpmcp.5: Adding to iommu group 0
[ 6.585884] fsl_mc_allocator dpmcp.4: Adding to iommu group 0
[ 6.592791] fsl_mc_allocator dpmcp.3: Adding to iommu group 0
[ 6.599685] fsl_mc_allocator dpmcp.2: Adding to iommu group 0
[ 6.606574] fsl_mc_allocator dpmcp.1: Adding to iommu group 0
[ 6.612468] fsl_dpaa2_ptp dprtc.0: Adding to iommu group 0
[ 6.620167] ptp_qoriq: device tree node missing required elements, try automatic configuration
[ 6.628967] pps pps0: new PPS source ptp0
[ 6.636063] fsl_mc_dpio dpio.15: Adding to iommu group 0
[ 6.644954] fsl_mc_dpio dpio.15: probed
[ 6.652398] fsl_mc_dpio dpio.14: Adding to iommu group 0
[ 6.661335] fsl_mc_dpio dpio.14: probed
[ 6.668822] fsl_mc_dpio dpio.13: Adding to iommu group 0
[ 6.677725] fsl_mc_dpio dpio.13: probed
[ 6.685166] fsl_mc_dpio dpio.12: Adding to iommu group 0
[ 6.694122] fsl_mc_dpio dpio.12: probed
[ 6.701645] fsl_mc_dpio dpio.11: Adding to iommu group 0
[ 6.710567] fsl_mc_dpio dpio.11: probed
[ 6.717966] fsl_mc_dpio dpio.10: Adding to iommu group 0
[ 6.726921] fsl_mc_dpio dpio.10: probed
[ 6.734504] fsl_mc_dpio dpio.9: Adding to iommu group 0
[ 6.743334] fsl_mc_dpio dpio.9: probed
[ 6.750700] fsl_mc_dpio dpio.8: Adding to iommu group 0
[ 6.759498] fsl_mc_dpio dpio.8: probed
[ 6.766872] fsl_mc_dpio dpio.7: Adding to iommu group 0
[ 6.775765] fsl_mc_dpio dpio.7: probed
[ 6.783193] fsl_mc_dpio dpio.6: Adding to iommu group 0
[ 6.792085] fsl_mc_dpio dpio.6: probed
[ 6.799387] fsl_mc_dpio dpio.5: Adding to iommu group 0
[ 6.808188] fsl_mc_dpio dpio.5: probed
[ 6.815543] fsl_mc_dpio dpio.4: Adding to iommu group 0
[ 6.824361] fsl_mc_dpio dpio.4: probed
[ 6.831665] fsl_mc_dpio dpio.3: Adding to iommu group 0
[ 6.840468] fsl_mc_dpio dpio.3: probed
[ 6.847830] fsl_mc_dpio dpio.2: Adding to iommu group 0
[ 6.856631] fsl_mc_dpio dpio.2: probed
[ 6.863938] fsl_mc_dpio dpio.1: Adding to iommu group 0
[ 6.872736] fsl_mc_dpio dpio.1: probed
[ 6.880116] fsl_mc_dpio dpio.0: Adding to iommu group 0
[ 6.888966] fsl_mc_dpio dpio.0: probed
[ 6.893384] fsl_mc_allocator dpcon.31: Adding to iommu group 0
[ 6.899379] fsl_mc_allocator dpcon.30: Adding to iommu group 0
[ 6.905369] fsl_mc_allocator dpcon.29: Adding to iommu group 0
[ 6.911350] fsl_mc_allocator dpcon.28: Adding to iommu group 0
[ 6.917338] fsl_mc_allocator dpcon.27: Adding to iommu group 0
[ 6.923328] fsl_mc_allocator dpcon.26: Adding to iommu group 0
[ 6.929310] fsl_mc_allocator dpcon.25: Adding to iommu group 0
[ 6.935300] fsl_mc_allocator dpcon.24: Adding to iommu group 0
[ 6.941289] fsl_mc_allocator dpcon.23: Adding to iommu group 0
[ 6.947273] fsl_mc_allocator dpcon.22: Adding to iommu group 0
[ 6.953262] fsl_mc_allocator dpcon.21: Adding to iommu group 0
[ 6.959249] fsl_mc_allocator dpcon.20: Adding to iommu group 0
[ 6.965235] fsl_mc_allocator dpcon.19: Adding to iommu group 0
[ 6.971224] fsl_mc_allocator dpcon.18: Adding to iommu group 0
[ 6.977214] fsl_mc_allocator dpcon.17: Adding to iommu group 0
[ 6.983205] fsl_mc_allocator dpcon.16: Adding to iommu group 0
[ 6.989193] fsl_mc_allocator dpcon.15: Adding to iommu group 0
[ 6.995184] fsl_mc_allocator dpcon.14: Adding to iommu group 0
[ 7.001173] fsl_mc_allocator dpcon.13: Adding to iommu group 0
[ 7.007163] fsl_mc_allocator dpcon.12: Adding to iommu group 0
[ 7.013154] fsl_mc_allocator dpcon.11: Adding to iommu group 0
[ 7.019147] fsl_mc_allocator dpcon.10: Adding to iommu group 0
[ 7.025147] fsl_mc_allocator dpcon.9: Adding to iommu group 0
[ 7.031055] fsl_mc_allocator dpcon.8: Adding to iommu group 0
[ 7.036960] fsl_mc_allocator dpcon.7: Adding to iommu group 0
[ 7.042868] fsl_mc_allocator dpcon.6: Adding to iommu group 0
[ 7.048776] fsl_mc_allocator dpcon.5: Adding to iommu group 0
[ 7.054688] fsl_mc_allocator dpcon.4: Adding to iommu group 0
[ 7.060598] fsl_mc_allocator dpcon.3: Adding to iommu group 0
[ 7.066505] fsl_mc_allocator dpcon.2: Adding to iommu group 0
[ 7.072421] fsl_mc_allocator dpcon.1: Adding to iommu group 0
[ 7.078337] fsl_mc_allocator dpcon.0: Adding to iommu group 0
[ 7.087338] fsl_mc_dprc dprc.1: DPRC device bound to driver
[ 7.240867] fsl_dpaa2_eth dpni.1: Probed interface eth0
[ 7.330188] scsi 4:0:0:0: Direct-Access 8.07 PQ: 0 ANSI: 4
[ 7.339243] sd 4:0:0:0: [sda] 31457280 512-byte logical blocks: (16.1 GB/15.0 GiB)
[ 7.347489] sd 4:0:0:0: [sda] Write Protect is off
[ 7.352275] sd 4:0:0:0: [sda] Mode Sense: 23 00 00 00
[ 7.352962] sd 4:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 7.394011] fsl_dpaa2_eth dpni.0: Probed interface eth1
[ 7.403703] dpaa2_mac dpmac.18: Connected to rgmii-id PHY.
[ 7.413667] dpaa2_mac dpmac.17: Connected to rgmii-id PHY.
[ 7.423149] dpaa2_mac dpmac.6: Registered fixed PHY.
[ 7.431921] dpaa2_mac dpmac.5: Registered fixed PHY.
[ 7.469128] dpaa2_mac dpmac.4: Connected to usxgmii PHY.
[ 7.505134] dpaa2_mac dpmac.3: Connected to usxgmii PHY.
[ 7.514354] dpaa2_mac dpmac.2: Registered fixed PHY.
[ 7.520896] dpaa2_caam dpseci.0: dpseci v5.3
[ 7.548589] fsl_mc_dprc dprc.1 (unnamed net_device) (uninitialized): netif_napi_add() called with weight 512
[ 7.580849] dpaa2_caam dpseci.0: algorithms registered in /proc/crypto
[ 7.589844] dpaa2_caam dpseci.0: hash algorithms registered in /proc/crypto
[ 7.598554] rtc-pcf2127-i2c 1-0051: setting system clock to 2020-05-13T06:13:49 UTC (1589350429)
[ 7.607495] ALSA device list:
[ 7.610457] No soundcards found.
[ 7.898343] sda: sda1 sda2 sda3 sda4
[ 7.905497] sd 4:0:0:0: [sda] Attached SCSI removable disk
[ 8.891369] EXT4-fs (sda4): mounted filesystem with ordered data mode. Opts: (null)
[ 8.899091] VFS: Mounted root (ext4 filesystem) on device 8:4.
[ 8.914775] devtmpfs: mounted
[ 8.920294] Freeing unused kernel memory: 5888K
[ 8.924970] Run /sbin/init as init process
[ 10.070404] random: fast init done
[ 10.635516] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +)
[ 10.659784] systemd[1]: Detected architecture arm64.
[ 10.706017] systemd[1]: Set hostname to <localhost>.
[ 11.142031] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support.
[ 11.159107] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 11.248293] systemd[1]: Configuration file /lib/systemd/system/weston.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 11.329113] systemd[1]: Configuration file /lib/systemd/system/fmc.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 11.389497] random: systemd: uninitialized urandom read (16 bytes read)
[ 11.396128] systemd[1]: Reached target Swap.
[ 11.412206] random: systemd: uninitialized urandom read (16 bytes read)
[ 11.419073] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 11.440225] random: systemd: uninitialized urandom read (16 bytes read)
[ 11.448366] systemd[1]: Created slice System Slice.
[ 11.602176] EXT4-fs (sda4): re-mounted. Opts: errors=remount-ro
[ 12.178379] systemd-journald[666]: Received request to flush runtime journal from PID 1
[ 13.236229] switch cluster 0 cpu-freq governor to schedutil
[ 13.276171] switch cluster 1 cpu-freq governor to schedutil
[ 13.496510] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 14.825774] random: crng init done
[ 14.829178] random: 7 urandom warning(s) missed due to ratelimiting
[ 19.604946] pfe: module is from the staging directory, the quality is unknown, you have been warned.
root@localhost:~# cat /proc/version
Linux version 5.4.3 (root@fbubuntu) (gcc version 7.5.0 (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04)) #1 SMP PREEMPT Wed May 13 09:52:14 CST 2020
8 回复数
5,839 次查看
zhanghonghui
Now I using the official released binary for lx2160ardb by "flex-build -i download -m lx2160ardb" of version lsdk20.04 and still got the dpmac.17 and dpmac.18 still could not work.
Hope you guys could give me some advise about this.
thanks.
5,839 次查看
yipingwang
Would you please provide and attach your whole console log?
After login Linux, please type command "ls-listni" to show dpni ports?
5,839 次查看
zhanghonghui
And it works fine if I using lsdk19.09, below is the console logs that boot from lsdk19.09, I have setup the network automatically in 19.09.
NOTICE: BL2: Built : 00:41:58, Jul 30 2019
NOTICE: UDIMM 18ADF2G72AZ-3G2E1
NOTICE: DDR4 UDIMM with 2-rank 64-bit bus (x8)
NOTICE: 32 GB DDR4, 64-bit, CL=22, ECC on, 256B, CS0+CS1
NOTICE: BL2: Booting BL31
NOTICE: BL31: v1.5(release):LSDK-19.06
NOTICE: BL31: Built : 00:42:06, Jul 30 2019
NOTICE: Welcome to LX2160 BL31 Phase
U-Boot 2019.04-gcbd7e30bf8 (Jul 29 2019 - 21:38:31 +0800)
SoC: LX2160ACE Rev1.0 (0x87360010)
Clock Configuration:
CPU0(A72):2000 MHz CPU1(A72):2000 MHz CPU2(A72):2000 MHz
CPU3(A72):2000 MHz CPU4(A72):2000 MHz CPU5(A72):2000 MHz
CPU6(A72):2000 MHz CPU7(A72):2000 MHz CPU8(A72):2000 MHz
CPU9(A72):2000 MHz CPU10(A72):2000 MHz CPU11(A72):2000 MHz
CPU12(A72):2000 MHz CPU13(A72):2000 MHz CPU14(A72):2000 MHz
CPU15(A72):2000 MHz
Bus: 700 MHz DDR: 2900 MT/s
Reset Configuration Word (RCW):
00000000: 50777738 1c500050 00000000 00000000
00000010: 00000000 0c010000 00000000 00000000
00000020: 022001a0 00002580 00000000 00000096
00000030: 00000000 00000000 00000000 00000000
00000040: 00000000 00000000 00000000 00000000
00000050: 00000000 00000000 00000000 00000000
00000060: 00000000 00000000 00027000 00000000
00000070: 08b30010 001d0020
Model: NXP Layerscape LX2160ARDB Board
Board: LX2160ACE Rev1.0-RDB, Board version: B, boot from FlexSPI DEV#0
FPGA: v5.0
SERDES1 Reference: Clock1 = 161.13MHz Clock2 = 161.13MHz
SERDES2 Reference: Clock1 = 100MHz Clock2 = 100MHz
SERDES3 Reference: Clock1 = 100MHz Clock2 = 100Hz
I2C: ready
VID: Core voltage after adjustment is at 802 mV
DRAM: 31.9 GiB
DDR 31.9 GiB (DDR4, 64-bit, CL=22, ECC on)
DDR Controller Interleaving Mode: 256B
DDR Chip-Select Interleaving Mode: CS0+CS1
Using SERDES1 Protocol: 19 (0x13)
Using SERDES2 Protocol: 5 (0x5)
Using SERDES3 Protocol: 2 (0x2)
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Loading Environment from SPI Flash... SF: Detected mt35xu512g with page size 256 Bytes, erase size 128 KiB, total 64 MiB
OK
EEPROM: NXID v1
In: serial_pl01x
Out: serial_pl01x
Err: serial_pl01x
Net:
CS4223: Using software initialization...
CS4223: edc/gain/equalization settings: host: CX/4dB/4dB, line: SR/4dB/4dB
DPMAC3@xgmii running firmware version 3.5.A
DPMAC3@xgmii: system interface USXGMII
DPMAC3@xgmii: Aquantia AQR107 Firmware Version 3.5.a
DPMAC4@xgmii running firmware version 3.5.A
DPMAC4@xgmii: system interface USXGMII
DPMAC4@xgmii: Aquantia AQR107 Firmware Version 3.5.a
FSL_MDIO1:0 is connected to DPMAC5@25g-aui. Reconnecting to DPMAC6@25g-aui
PCIe0: pcie@3400000 disabled
PCIe1: pcie@3500000 disabled
PCIe2: pcie@3600000 Root Complex: no link
PCIe3: pcie@3700000 disabled
PCIe4: pcie@3800000 Root Complex: no link
PCIe5: pcie@3900000 disabled
DPMAC2@xlaui4, DPMAC3@xgmii, DPMAC4@xgmii, DPMAC5@25g-aui, DPMAC6@25g-aui, DPMAC17@rgmii-id, DPMAC18@rgmii-id
crc32+
fsl-mc: Booting Management Complex ... SUCCESS
fsl-mc: Management Complex booted (version: 10.16.2, boot status: 0x1)
Hit any key to stop autoboot: 0
=> boot
starting USB...
USB0: Register 200017f NbrPorts 2
Starting the controller
USB XHCI 1.00
USB1: Register 200017f NbrPorts 2
USB XHCI 1.00
scanning bus 0 for devices... 2 USB Device(s) found
scanning bus 1 for devices... 1 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
Device 0: Vendor: Rev: 8.07 Prod:
Type: Removable Hard Disk
Capacity: 15360.0 MB = 15.0 GB (31457280 x 512)
... is now current device
Scanning usb 0:1...
Scanning usb 0:2...
Found U-Boot script /lx2160ardb_boot.scr
980 bytes read in 11 ms (86.9 KiB/s)
## Executing script at 80000000
24852992 bytes read in 1039 ms (22.8 MiB/s)
32280 bytes read in 17 ms (1.8 MiB/s)
## Flattened Device Tree blob at 90000000
Booting using the fdt blob at 0x90000000
Loading Device Tree to 000000009fff5000, end 000000009ffffe17 ... OK
fsl-mc: Deploying data path layout ... SUCCESS
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
[ 0.000000] Linux version 4.19.68 (jenkins@saturn) (gcc version 7.4.0 (Ubuntu/Linaro 7.4.0-1ubuntu1~18.04.1)) #1 SMP PREEMPT Thu Oct 17 16:15:03 CST 2019
[ 0.000000] Machine model: NXP Layerscape LX2160ARDB
[ 0.000000] earlycon: pl11 at MMIO32 0x00000000021c0000 (options '')
[ 0.000000] bootconsole [pl11] enabled
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 32 MiB at 0x00000000f9c00000
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x000000277fffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x277ffcd980-0x277ffcf13f]
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x000000277fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fbdfffff]
[ 0.000000] node 0: [mem 0x0000002080000000-0x000000277fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000277fffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] random: get_random_bytes called from start_kernel+0xa8/0x418 with crng_init=0
[ 0.000000] percpu: Embedded 25 pages/cpu s63448 r8192 d30760 u102400
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for EL2 vector hardening
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 7724544
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: console=ttyAMA0,115200 earlycon=pl011,mmio32,0x21c0000 root=PARTUUID=000b400b-04 rw rootwait pci=pcie_bus_perf default_hugepagesz=1024m hugepagesz=1024m hugepages=2 pci=pcie_bus_perf isolcpus=1-8 i1
[ 0.000000] software IO TLB: mapped [mem 0xf5c00000-0xf9c00000] (64MB)
[ 0.000000] Memory: 28674912K/31389696K available (14844K kernel code, 1678K rwdata, 6152K rodata, 1536K init, 940K bss, 2682016K reserved, 32768K cma-reserved)
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=16.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=16
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: no VLPI support, no direct LPI support
[ 0.000000] ITS [mem 0x06020000-0x0603ffff]
[ 0.000000] ITS@0x0000000006020000: allocated 65536 Devices @2761880000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GIC: using LPI property table @0x0000002761860000
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000006200000
[ 0.000000] CPU0: using LPI pending table @0x0000002761870000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] arch_timer: cp15 timer(s) running at 25.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x5c409fb33, max_idle_ns: 440795203156 ns
[ 0.000001] sched_clock: 56 bits at 25MHz, resolution 39ns, wraps every 4398046511103ns
[ 0.008310] Console: colour dummy device 80x25
[ 0.012831] Calibrating delay loop (skipped), value calculated using timer frequency.. 50.00 BogoMIPS (lpj=100000)
[ 0.023298] pid_max: default: 32768 minimum: 301
[ 0.028042] Security Framework initialized
[ 0.038710] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes)
[ 0.049457] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.056982] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.064035] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.095465] ASID allocator initialised with 32768 entries
[ 0.108933] rcu: Hierarchical SRCU implementation.
[ 0.121808] Platform MSI: gic-its@6020000 domain created
[ 0.127223] PCI/MSI: /interrupt-controller@6000000/gic-its@6020000 domain created
[ 0.134809] fsl-mc MSI: /interrupt-controller@6000000/gic-its@6020000 domain created
[ 0.143010] EFI services will not be available.
[ 0.155596] smp: Bringing up secondary CPUs ...
[ 0.192304] Detected PIPT I-cache on CPU1
[ 0.192319] GICv3: CPU1: found redistributor 1 region 0:0x0000000006220000
[ 0.192353] CPU1: using LPI pending table @0x000000275e790000
[ 0.192374] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[ 0.224318] Detected PIPT I-cache on CPU2
[ 0.224333] GICv3: CPU2: found redistributor 100 region 0:0x0000000006240000
[ 0.224368] CPU2: using LPI pending table @0x000000275e7b0000
[ 0.224388] CPU2: Booted secondary processor 0x0000000100 [0x410fd083]
[ 0.256342] Detected PIPT I-cache on CPU3
[ 0.256353] GICv3: CPU3: found redistributor 101 region 0:0x0000000006260000
[ 0.256386] CPU3: using LPI pending table @0x000000275e7c0000
[ 0.256402] CPU3: Booted secondary processor 0x0000000101 [0x410fd083]
[ 0.288372] Detected PIPT I-cache on CPU4
[ 0.288387] GICv3: CPU4: found redistributor 200 region 0:0x0000000006280000
[ 0.288419] CPU4: using LPI pending table @0x000000275e020000
[ 0.288438] CPU4: Booted secondary processor 0x0000000200 [0x410fd083]
[ 0.320397] Detected PIPT I-cache on CPU5
[ 0.320410] GICv3: CPU5: found redistributor 201 region 0:0x00000000062a0000
[ 0.320444] CPU5: using LPI pending table @0x000000275e030000
[ 0.320460] CPU5: Booted secondary processor 0x0000000201 [0x410fd083]
[ 0.352428] Detected PIPT I-cache on CPU6
[ 0.352444] GICv3: CPU6: found redistributor 300 region 0:0x00000000062c0000
[ 0.352477] CPU6: using LPI pending table @0x000000275e050000
[ 0.352496] CPU6: Booted secondary processor 0x0000000300 [0x410fd083]
[ 0.384453] Detected PIPT I-cache on CPU7
[ 0.384467] GICv3: CPU7: found redistributor 301 region 0:0x00000000062e0000
[ 0.384499] CPU7: using LPI pending table @0x000000275e0b0000
[ 0.384517] CPU7: Booted secondary processor 0x0000000301 [0x410fd083]
[ 0.416487] Detected PIPT I-cache on CPU8
[ 0.416505] GICv3: CPU8: found redistributor 400 region 0:0x0000000006300000
[ 0.416538] CPU8: using LPI pending table @0x000000275e0c0000
[ 0.416557] CPU8: Booted secondary processor 0x0000000400 [0x410fd083]
[ 0.448510] Detected PIPT I-cache on CPU9
[ 0.448526] GICv3: CPU9: found redistributor 401 region 0:0x0000000006320000
[ 0.448559] CPU9: using LPI pending table @0x000000275e0e0000
[ 0.448576] CPU9: Booted secondary processor 0x0000000401 [0x410fd083]
[ 0.480543] Detected PIPT I-cache on CPU10
[ 0.480563] GICv3: CPU10: found redistributor 500 region 0:0x0000000006340000
[ 0.480597] CPU10: using LPI pending table @0x000000275e140000
[ 0.480617] CPU10: Booted secondary processor 0x0000000500 [0x410fd083]
[ 0.512567] Detected PIPT I-cache on CPU11
[ 0.512584] GICv3: CPU11: found redistributor 501 region 0:0x0000000006360000
[ 0.512615] CPU11: using LPI pending table @0x000000275e150000
[ 0.512632] CPU11: Booted secondary processor 0x0000000501 [0x410fd083]
[ 0.544600] Detected PIPT I-cache on CPU12
[ 0.544622] GICv3: CPU12: found redistributor 600 region 0:0x0000000006380000
[ 0.544655] CPU12: using LPI pending table @0x000000275e170000
[ 0.544676] CPU12: Booted secondary processor 0x0000000600 [0x410fd083]
[ 0.576623] Detected PIPT I-cache on CPU13
[ 0.576642] GICv3: CPU13: found redistributor 601 region 0:0x00000000063a0000
[ 0.576674] CPU13: using LPI pending table @0x000000275e1c0000
[ 0.576691] CPU13: Booted secondary processor 0x0000000601 [0x410fd083]
[ 0.608655] Detected PIPT I-cache on CPU14
[ 0.608678] GICv3: CPU14: found redistributor 700 region 0:0x00000000063c0000
[ 0.608711] CPU14: using LPI pending table @0x000000275e1e0000
[ 0.608731] CPU14: Booted secondary processor 0x0000000700 [0x410fd083]
[ 0.640678] Detected PIPT I-cache on CPU15
[ 0.640698] GICv3: CPU15: found redistributor 701 region 0:0x00000000063e0000
[ 0.640732] CPU15: using LPI pending table @0x000000275e1f0000
[ 0.640748] CPU15: Booted secondary processor 0x0000000701 [0x410fd083]
[ 0.640787] smp: Brought up 1 node, 16 CPUs
[ 1.000448] SMP: Total of 16 processors activated.
[ 1.005290] CPU features: detected: GIC system register CPU interface
[ 1.011804] CPU features: detected: 32-bit EL0 Support
[ 1.023592] CPU: All CPU(s) started at EL2
[ 1.027756] alternatives: patching kernel code
[ 1.032855] devtmpfs: initialized
[ 1.038351] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 1.048244] futex hash table entries: 4096 (order: 6, 262144 bytes)
[ 1.054960] xor: measuring software checksum speed
[ 1.099829] 8regs : 8477.000 MB/sec
[ 1.144081] 8regs_prefetch: 7315.000 MB/sec
[ 1.188092] 32regs : 8537.000 MB/sec
[ 1.232111] 32regs_prefetch: 8045.000 MB/sec
[ 1.236774] xor: using function: 32regs (8537.000 MB/sec)
[ 1.242232] pinctrl core: initialized pinctrl subsystem
[ 1.247942] DMI not present or invalid.
[ 1.251970] NET: Registered protocol family 16
[ 1.256724] audit: initializing netlink subsys (disabled)
[ 1.262228] audit: type=2000 audit(1.080:1): state=initialized audit_enabled=0 res=1
[ 1.270065] cpuidle: using governor menu
[ 1.274220] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[ 1.281702] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 1.289055] DMA: preallocated 256 KiB pool for atomic allocations
[ 1.295552] Serial: AMBA PL011 UART driver
[ 1.300470] Machine: NXP Layerscape LX2160ARDB
[ 1.304963] SoC family: QorIQ LX2160A
[ 1.308657] SoC ID: svr:0x87360010, Revision: 1.0
[ 1.314257] 21c0000.serial: ttyAMA0 at MMIO 0x21c0000 (irq = 19, base_baud = 0) is a SBSA
[ 1.322534] console [ttyAMA0] enabled
[ 1.329879] bootconsole [pl11] disabled
[ 1.337787] sbsa-uart 21d0000.serial: aliased and non-aliased serial devices found in device tree. Serial port enumeration may be unpredictable.
[ 1.350733] 21d0000.serial: ttyAMA1 at MMIO 0x21d0000 (irq = 20, base_baud = 0) is a SBSA
[ 1.361889] fsl_mc_bus 80c000000.fsl-mc: MC firmware version: 10.16.2
[ 1.370910] fsl_mc_dprc dprc.1: DMA mask not set
[ 1.386585] HugeTLB registered 1.00 GiB page size, pre-allocated 2 pages
[ 1.393606] cryptd: max_cpu_qlen set to 1000
[ 1.464282] raid6: int64x1 gen() 1232 MB/s
[ 1.536291] raid6: int64x1 xor() 1110 MB/s
[ 1.608327] raid6: int64x2 gen() 1684 MB/s
[ 1.680344] raid6: int64x2 xor() 1614 MB/s
[ 1.752381] raid6: int64x4 gen() 2578 MB/s
[ 1.824419] raid6: int64x4 xor() 1829 MB/s
[ 1.896452] raid6: int64x8 gen() 2189 MB/s
[ 1.968469] raid6: int64x8 xor() 1789 MB/s
[ 2.040509] raid6: neonx1 gen() 2499 MB/s
[ 2.112533] raid6: neonx1 xor() 2792 MB/s
[ 2.184578] raid6: neonx2 gen() 3274 MB/s
[ 2.256597] raid6: neonx2 xor() 3488 MB/s
[ 2.328629] raid6: neonx4 gen() 4301 MB/s
[ 2.400652] raid6: neonx4 xor() 3749 MB/s
[ 2.472693] raid6: neonx8 gen() 4852 MB/s
[ 2.544718] raid6: neonx8 xor() 4097 MB/s
[ 2.548978] raid6: using algorithm neonx8 gen() 4852 MB/s
[ 2.554365] raid6: .... xor() 4097 MB/s, rmw enabled
[ 2.559318] raid6: using neon recovery algorithm
[ 2.564149] ACPI: Interpreter disabled.
[ 2.568500] vgaarb: loaded
[ 2.571317] SCSI subsystem initialized
[ 2.575284] usbcore: registered new interface driver usbfs
[ 2.580779] usbcore: registered new interface driver hub
[ 2.586132] usbcore: registered new device driver usb
[ 2.591455] i2c i2c-0: IMX I2C adapter registered
[ 2.596309] i2c i2c-1: IMX I2C adapter registered
[ 2.601179] pps_core: LinuxPPS API ver. 1 registered
[ 2.606142] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 2.615278] PTP clock support registered
[ 2.619236] EDAC MC: Ver: 3.0.0
[ 2.622556] No BMan portals available!
[ 2.626495] QMan: Allocated lookup table at (____ptrval____), entry count 65537
[ 2.633864] No QMan portals available!
[ 2.637687] No USDPAA memory, no 'fsl,usdpaa-mem' in device-tree
[ 2.643904] Advanced Linux Sound Architecture Driver Initialized.
[ 2.650363] clocksource: Switched to clocksource arch_sys_counter
[ 2.656534] VFS: Disk quotas dquot_6.6.0
[ 2.660475] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 2.667421] pnp: PnP ACPI: disabled
[ 2.674021] NET: Registered protocol family 2
[ 2.678656] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes)
[ 2.686940] TCP established hash table entries: 262144 (order: 9, 2097152 bytes)
[ 2.695188] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 2.702282] TCP: Hash tables configured (established 262144 bind 65536)
[ 2.709002] UDP hash table entries: 16384 (order: 7, 524288 bytes)
[ 2.715520] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes)
[ 2.722520] NET: Registered protocol family 1
[ 2.727105] RPC: Registered named UNIX socket transport module.
[ 2.733019] RPC: Registered udp transport module.
[ 2.737713] RPC: Registered tcp transport module.
[ 2.742412] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.749578] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 2.757862] kvm [1]: 8-bit VMID
[ 2.761269] kvm [1]: vgic-v2@c0e0000
[ 2.764852] kvm [1]: GIC system register CPU interface enabled
[ 2.770858] kvm [1]: vgic interrupt IRQ1
[ 2.774951] kvm [1]: Hyp mode initialized successfully
[ 2.781649] Initialise system trusted keyrings
[ 2.786151] workingset: timestamp_bits=44 max_order=23 bucket_order=0
[ 2.793000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.798952] NFS: Registering the id_resolver key type
[ 2.804002] Key type id_resolver registered
[ 2.808178] Key type id_legacy registered
[ 2.812182] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 2.818930] fuse init (API version 7.27)
[ 2.822931] 9p: Installing v9fs 9p2000 file system support
[ 2.829680] Key type asymmetric registered
[ 2.833771] Asymmetric key parser 'x509' registered
[ 2.838660] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 2.846108] io scheduler noop registered
[ 2.850025] io scheduler deadline registered
[ 2.854303] io scheduler cfq registered (default)
[ 2.859000] io scheduler mq-deadline registered
[ 2.863521] io scheduler kyber registered
[ 2.870341] layerscape-pcie-gen4 3600000.pcie: host bridge /soc/pcie@3600000 ranges:
[ 2.878089] layerscape-pcie-gen4 3600000.pcie: MEM 0x9040000000..0x907fffffff -> 0x40000000
[ 3.886771] layerscape-pcie-gen4 3600000.pcie: link never came up
[ 3.892883] layerscape-pcie-gen4 3600000.pcie: link bring-up failed
[ 3.899198] layerscape-pcie-gen4 3600000.pcie: PCI host bridge to bus 0000:00
[ 3.906326] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 3.911807] pci_bus 0000:00: root bus resource [mem 0x9040000000-0x907fffffff] (bus address [0x40000000-0x7fffffff])
[ 3.922363] pci 0000:00:00.0: enabling Extended Tags
[ 3.928333] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 3.933563] pci 0000:00:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 256
[ 3.942068] pcieport 0000:00:00.0: Signaling PME with IRQ 110
[ 3.947854] pcieport 0000:00:00.0: AER enabled with IRQ 110
[ 3.953554] layerscape-pcie-gen4 3800000.pcie: host bridge /soc/pcie@3800000 ranges:
[ 3.961296] layerscape-pcie-gen4 3800000.pcie: MEM 0xa040000000..0xa07fffffff -> 0x40000000
[ 4.970000] layerscape-pcie-gen4 3800000.pcie: link never came up
[ 4.976098] layerscape-pcie-gen4 3800000.pcie: link bring-up failed
[ 4.982397] layerscape-pcie-gen4 3800000.pcie: PCI host bridge to bus 0001:00
[ 4.989524] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 4.995004] pci_bus 0001:00: root bus resource [mem 0xa040000000-0xa07fffffff] (bus address [0x40000000-0x7fffffff])
[ 5.005557] pci 0001:00:00.0: enabling Extended Tags
[ 5.011510] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 5.016743] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 256
[ 5.025246] pcieport 0001:00:00.0: Signaling PME with IRQ 111
[ 5.031033] pcieport 0001:00:00.0: AER enabled with IRQ 111
[ 5.036932] EINJ: ACPI disabled.
[ 5.041528] Freescale LS2 console driver
[ 5.045502] fsl-ls2-console: device fsl_mc_console registered
[ 5.051277] fsl-ls2-console: device fsl_aiop_console registered
[ 5.059309] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 5.066327] SuperH (H)SCI(F) driver initialized
[ 5.070989] msm_serial: driver initialized
[ 5.075847] arm-smmu 5000000.iommu: probing hardware configuration...
[ 5.082286] arm-smmu 5000000.iommu: SMMUv2 with:
[ 5.086897] arm-smmu 5000000.iommu: stage 1 translation
[ 5.092201] arm-smmu 5000000.iommu: stage 2 translation
[ 5.097503] arm-smmu 5000000.iommu: nested translation
[ 5.102720] arm-smmu 5000000.iommu: coherent table walk
[ 5.108022] arm-smmu 5000000.iommu: (IDR0.CTTW overridden by FW configuration)
[ 5.115324] arm-smmu 5000000.iommu: stream matching with 128 register groups
[ 5.122451] arm-smmu 5000000.iommu: 64 context banks (0 stage-2 only)
[ 5.128970] arm-smmu 5000000.iommu: Supported page sizes: 0x61311000
[ 5.135401] arm-smmu 5000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 5.141834] arm-smmu 5000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 5.153247] brd: module loaded
[ 5.159937] loop: module loaded
[ 5.163769] ahci-qoriq 3200000.sata: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[ 5.172729] ahci-qoriq 3200000.sata: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[ 5.182734] scsi host0: ahci-qoriq
[ 5.186242] ata1: SATA max UDMA/133 mmio [mem 0x03200000-0x0320ffff] port 0x100 irq 106
[ 5.194381] ahci-qoriq 3210000.sata: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[ 5.203332] ahci-qoriq 3210000.sata: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[ 5.213205] scsi host1: ahci-qoriq
[ 5.216704] ata2: SATA max UDMA/133 mmio [mem 0x03210000-0x0321ffff] port 0x100 irq 107
[ 5.224818] ahci-qoriq 3220000.sata: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[ 5.233771] ahci-qoriq 3220000.sata: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[ 5.243698] scsi host2: ahci-qoriq
[ 5.247202] ata3: SATA max UDMA/133 mmio [mem 0x03220000-0x0322ffff] port 0x100 irq 108
[ 5.255279] ahci-qoriq 3230000.sata: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[ 5.264230] ahci-qoriq 3230000.sata: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[ 5.274101] scsi host3: ahci-qoriq
[ 5.277591] ata4: SATA max UDMA/133 mmio [mem 0x03230000-0x0323ffff] port 0x100 irq 109
[ 5.286410] m25p80 spi0.0: found mt35xu512aba, expected m25p80
[ 5.292240] m25p80 spi0.0: mt35xu512aba (65536 Kbytes)
[ 5.297795] m25p80 spi0.1: found mt35xu512aba, expected m25p80
[ 5.303623] m25p80 spi0.1: mt35xu512aba (65536 Kbytes)
[ 5.309681] libphy: Fixed MDIO Bus: probed
[ 5.314258] tun: Universal TUN/TAP device driver, 1.6
[ 5.319607] thunder_xcv, ver 1.0
[ 5.322846] thunder_bgx, ver 1.0
[ 5.326076] nicpf, ver 1.0
[ 5.328875] libphy: Freescale XGMAC MDIO Bus: probed
[ 5.336404] libphy: Freescale XGMAC MDIO Bus: probed
[ 5.341802] Freescale FM module, FMD API version 21.1.0
[ 5.347070] Freescale FM Ports module
[ 5.350727] fsl_mac: fsl_mac: FSL FMan MAC API based driver
[ 5.356326] fsl_dpa: FSL DPAA Ethernet driver
[ 5.360705] fsl_advanced: FSL DPAA Advanced drivers:
[ 5.365664] fsl_proxy: FSL DPAA Proxy initialization driver
[ 5.371258] fsl_oh: FSL FMan Offline Parsing port driver
[ 5.376824] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[ 5.383866] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 5.389623] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 5.395451] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 5.401382] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 5.408337] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 5.413919] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 5.421742] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 5.427769] sky2: driver version 1.30
[ 5.431832] VFIO - User Level meta-driver version: 0.3
[ 5.437207] dwc3 3100000.usb: Failed to get clk 'ref': -2
[ 5.442665] ------------[ cut here ]------------
[ 5.447274] dwc3 3100000.usb: request value same as default, ignoring
[ 5.453734] WARNING: CPU: 10 PID: 1 at /home/jenkins/ci/lsdk/master/all/packages/linux/linux/drivers/usb/dwc3/core.c:347 dwc3_core_init+0xd24/0xd80
[ 5.466931] Modules linked in:
[ 5.469976] CPU: 10 PID: 1 Comm: swapper/0 Not tainted 4.19.68 #1
[ 5.476056] Hardware name: NXP Layerscape LX2160ARDB (DT)
[ 5.481442] pstate: 40000005 (nZcv daif -PAN -UAO)
[ 5.486221] pc : dwc3_core_init+0xd24/0xd80
[ 5.490393] lr : dwc3_core_init+0xd24/0xd80
[ 5.494562] sp : ffff00000995bb00
[ 5.497864] x29: ffff00000995bb00 x28: 0000000000000007
[ 5.503165] x27: ffff0000095f5068 x26: ffff0000094fd6c8
[ 5.508466] x25: ffff8026de2647a0 x24: ffff000008f07000
[ 5.513766] x23: ffff8026ddef0c10 x22: ffff00000969a000
[ 5.519066] x21: 0000000000000041 x20: 0000000030c11004
[ 5.524367] x19: ffff8026de265880 x18: ffffffffffffffff
[ 5.529667] x17: 0000000000000000 x16: 0000000000000000
[ 5.534967] x15: ffff00000969a708 x14: ffff00008983f6ff
[ 5.540267] x13: ffff00000983f70d x12: ffff00000969a980
[ 5.540519] ata1: SATA link down (SStatus 0 SControl 300)
[ 5.545567] x11: ffff000008721090 x10: ffff00000995b7d0
[ 5.545570] x9 : 0000000000000016 x8 : 2c746c7561666564
[ 5.545573] x7 : 20736120656d6173 x6 : 000000000000015d
[ 5.564511] ata2: SATA link down (SStatus 0 SControl 300)
[ 5.566851] x5 : 0000000000000000 x4 : 0000000000000000
[ 5.566854] x3 : ffffffffffffffff x2 : ffff0000096b43b8
[ 5.566859] x1 : 74fe3105fdae9100 x0 : 0000000000000000
[ 5.588136] Call trace:
[ 5.590572] dwc3_core_init+0xd24/0xd80
[ 5.594396] dwc3_probe+0x8b0/0xd30
[ 5.597874] platform_drv_probe+0x50/0xa0
[ 5.601871] really_probe+0x1b8/0x290
[ 5.605520] driver_probe_device+0x58/0x100
[ 5.609691] __driver_attach+0xe0/0xe8
[ 5.613428] bus_for_each_dev+0x74/0xc8
[ 5.617251] driver_attach+0x20/0x28
[ 5.620814] bus_add_driver+0x1ac/0x218
[ 5.624508] ata4: SATA link down (SStatus 0 SControl 300)
[ 5.624637] driver_register+0x60/0x110
[ 5.624641] __platform_driver_register+0x40/0x48
[ 5.638537] dwc3_driver_init+0x18/0x20
[ 5.642361] do_one_initcall+0x5c/0x178
[ 5.646186] kernel_init_freeable+0x198/0x244
[ 5.650532] kernel_init+0x10/0x108
[ 5.654008] ret_from_fork+0x10/0x18
[ 5.657572] ---[ end trace 73fd21d1e7afdbb6 ]---
[ 5.662503] dwc3 3110000.usb: Failed to get clk 'ref': -2
[ 5.668426] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 5.674950] ehci-pci: EHCI PCI platform driver
[ 5.679400] ehci-platform: EHCI generic platform driver
[ 5.684655] ehci-orion: EHCI orion driver
[ 5.688688] ehci-exynos: EHCI EXYNOS driver
[ 5.692893] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 5.699069] ohci-pci: OHCI PCI platform driver
[ 5.703519] ohci-platform: OHCI generic platform driver
[ 5.708771] ohci-exynos: OHCI EXYNOS driver
[ 5.713072] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 5.718560] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 5.726404] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220f66d hci version 0x100 quirks 0x0000000002010010
[ 5.735806] xhci-hcd xhci-hcd.0.auto: irq 25, io mem 0x03100000
[ 5.742005] hub 1-0:1.0: USB hub found
[ 5.745758] hub 1-0:1.0: 1 port detected
[ 5.749784] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 5.755265] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 5.762917] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 5.763299] ata3: SATA link down (SStatus 0 SControl 300)
[ 5.769457] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 5.783074] hub 2-0:1.0: USB hub found
[ 5.786828] hub 2-0:1.0: 1 port detected
[ 5.790880] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 5.796364] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
[ 5.804193] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f66d hci version 0x100 quirks 0x0000000002010010
[ 5.813594] xhci-hcd xhci-hcd.1.auto: irq 26, io mem 0x03110000
[ 5.819734] hub 3-0:1.0: USB hub found
[ 5.823487] hub 3-0:1.0: 1 port detected
[ 5.827498] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 5.832979] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
[ 5.840628] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[ 5.847166] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 5.855410] hub 4-0:1.0: USB hub found
[ 5.859163] hub 4-0:1.0: 1 port detected
[ 5.863287] usbcore: registered new interface driver usb-storage
[ 5.870197] ftm-alarm 2800000.timer: registered as rtc1
[ 5.881329] rtc-pcf2127-i2c 1-0051: rtc core: registered rtc-pcf2127-i2c as rtc0
[ 5.888949] i2c /dev entries driver
[ 5.893636] i2c i2c-0: Added multiplexed i2c bus 2
[ 5.898502] i2c i2c-0: Added multiplexed i2c bus 3
[ 5.903418] i2c i2c-0: Added multiplexed i2c bus 4
[ 5.908365] i2c i2c-0: Added multiplexed i2c bus 5
[ 5.913223] i2c i2c-0: Added multiplexed i2c bus 6
[ 5.918086] i2c i2c-0: Added multiplexed i2c bus 7
[ 5.922940] i2c i2c-0: Added multiplexed i2c bus 8
[ 5.927794] i2c i2c-0: Added multiplexed i2c bus 9
[ 5.932580] pca954x 0-0077: registered 8 multiplexed busses for I2C mux pca9547
[ 5.941976] qoriq_cpufreq: Freescale QorIQ CPU frequency scaling driver
[ 5.949138] sdhci: Secure Digital Host Controller Interface driver
[ 5.955311] sdhci: Copyright(c) Pierre Ossman
[ 5.959763] Synopsys Designware Multimedia Card Interface Driver
[ 5.966054] sdhci-pltfm: SDHCI platform and OF driver helper
[ 5.997356] mmc0: SDHCI controller on 2140000.esdhc [2140000.esdhc] using ADMA 64-bit
[ 6.030706] mmc1: SDHCI controller on 2150000.esdhc [2150000.esdhc] using ADMA 64-bit
[ 6.039100] ledtrig-cpu: registered to indicate activity on CPUs
[ 6.046420] caam 8000000.crypto: device ID = 0x0a1a020000000000 (Era 10)
[ 6.053126] caam 8000000.crypto: job rings = 3, qi = 1
[ 6.061190] caam algorithms registered in /proc/crypto
[ 6.066869] caam 8000000.crypto: caam pkc algorithms registered in /proc/crypto
[ 6.074409] caam_jr 8010000.jr: registering rng-caam
[ 6.081240] caam 8000000.crypto: algorithms registered in /proc/crypto
[ 6.088425] usbcore: registered new interface driver usbhid
[ 6.090369] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 6.093992] usbhid: USB HID core driver
[ 6.104531] No fsl,qman node
[ 6.106970] mmc1: new HS400 MMC card at address 0001
[ 6.107494] Freescale USDPAA process driver
[ 6.112801] mmcblk1: mmc1:0001 R1J59E 116 GiB
[ 6.116536] fsl-usdpaa: no region found
[ 6.116538] Freescale USDPAA process IRQ driver
[ 6.121304] mmcblk1boot0: mmc1:0001 R1J59E partition 1 8.00 MiB
[ 6.127048] optee: probing for conduit method from DT.
[ 6.129680] mmcblk1boot1: mmc1:0001 R1J59E partition 2 8.00 MiB
[ 6.135238] optee: api uid mismatch
[ 6.140418] mmcblk1rpmb: mmc1:0001 R1J59E partition 3 4.00 MiB, chardev (236:0)
[ 6.146787] u32 classifier
[ 6.159754] Actions configured
[ 6.163581] Initializing XFRM netlink socket
[ 6.167922] NET: Registered protocol family 10
[ 6.172645] Segment Routing with IPv6
[ 6.176334] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 6.182445] NET: Registered protocol family 17
[ 6.186888] NET: Registered protocol family 15
[ 6.191338] Bridge firewalling registered
[ 6.195384] 8021q: 802.1Q VLAN Support v1.8
[ 6.199590] 9pnet: Installing 9P2000 support
[ 6.203866] tsn generic netlink module v1 init...
[ 6.208585] Key type dns_resolver registered
[ 6.213129] registered taskstats version 1
[ 6.217219] Loading compiled-in X.509 certificates
[ 6.222222] Btrfs loaded, crc32c=crc32c-generic
[ 6.227696] iommu: Adding device dprc.1 to group 0
[ 6.287215] iommu: Adding device dpni.1 to group 0
[ 6.292035] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 6.298427] iommu: Adding device dpni.0 to group 0
[ 6.303229] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 6.309615] iommu: Adding device dpbp.1 to group 0
[ 6.314447] iommu: Adding device dpbp.0 to group 0
[ 6.319279] iommu: Adding device dpmac.18 to group 0
[ 6.324248] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 6.330632] iommu: Adding device dpmac.17 to group 0
[ 6.335599] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 6.341982] iommu: Adding device dpmac.6 to group 0
[ 6.346862] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 6.353247] iommu: Adding device dpmac.5 to group 0
[ 6.358126] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 6.364509] iommu: Adding device dpmac.4 to group 0
[ 6.369388] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 6.375771] iommu: Adding device dpmac.3 to group 0
[ 6.380651] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 6.387036] iommu: Adding device dpmac.2 to group 0
[ 6.391916] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 6.398300] iommu: Adding device dpseci.0 to group 0
[ 6.399111] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 6.403290] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 6.409611] scsi host4: usb-storage 1-1:1.0
[ 6.420918] iommu: Adding device dpmcp.35 to group 0
[ 6.426976] iommu: Adding device dpmcp.34 to group 0
[ 6.433033] iommu: Adding device dpmcp.33 to group 0
[ 6.439099] iommu: Adding device dpmcp.32 to group 0
[ 6.445154] iommu: Adding device dpmcp.31 to group 0
[ 6.451224] iommu: Adding device dpmcp.30 to group 0
[ 6.457278] iommu: Adding device dpmcp.29 to group 0
[ 6.463347] iommu: Adding device dpmcp.28 to group 0
[ 6.469403] iommu: Adding device dpmcp.27 to group 0
[ 6.475463] iommu: Adding device dpmcp.26 to group 0
[ 6.481526] iommu: Adding device dpmcp.25 to group 0
[ 6.487588] iommu: Adding device dpmcp.24 to group 0
[ 6.493649] iommu: Adding device dpmcp.23 to group 0
[ 6.499714] iommu: Adding device dpmcp.22 to group 0
[ 6.505776] iommu: Adding device dpmcp.21 to group 0
[ 6.511836] iommu: Adding device dpmcp.20 to group 0
[ 6.517899] iommu: Adding device dpmcp.19 to group 0
[ 6.523961] iommu: Adding device dpmcp.18 to group 0
[ 6.530024] iommu: Adding device dpmcp.17 to group 0
[ 6.536086] iommu: Adding device dpmcp.16 to group 0
[ 6.542146] iommu: Adding device dpmcp.15 to group 0
[ 6.548210] iommu: Adding device dpmcp.14 to group 0
[ 6.554271] iommu: Adding device dpmcp.13 to group 0
[ 6.560332] iommu: Adding device dpmcp.12 to group 0
[ 6.566402] iommu: Adding device dpmcp.11 to group 0
[ 6.572457] iommu: Adding device dpmcp.10 to group 0
[ 6.578526] iommu: Adding device dpmcp.9 to group 0
[ 6.584449] iommu: Adding device dpmcp.8 to group 0
[ 6.590374] iommu: Adding device dpmcp.7 to group 0
[ 6.596293] iommu: Adding device dpmcp.6 to group 0
[ 6.602267] iommu: Adding device dpmcp.5 to group 0
[ 6.608189] iommu: Adding device dpmcp.4 to group 0
[ 6.614107] iommu: Adding device dpmcp.3 to group 0
[ 6.620027] iommu: Adding device dpmcp.2 to group 0
[ 6.625949] iommu: Adding device dpmcp.1 to group 0
[ 6.630866] iommu: Adding device dprtc.0 to group 0
[ 6.636273] fsl_dpaa2_ptp dprtc.0: Linked as a consumer to dpmcp.35
[ 6.644247] ptp_qoriq: device tree node missing required elements, try automatic configuration
[ 6.652976] pps pps0: new PPS source ptp0
[ 6.660117] iommu: Adding device dpio.15 to group 0
[ 6.665509] fsl_mc_dpio dpio.15: Linked as a consumer to dpmcp.34
[ 6.674848] fsl_mc_dpio dpio.15: probed
[ 6.682281] iommu: Adding device dpio.14 to group 0
[ 6.687673] fsl_mc_dpio dpio.14: Linked as a consumer to dpmcp.33
[ 6.696480] fsl_mc_dpio dpio.14: probed
[ 6.703913] iommu: Adding device dpio.13 to group 0
[ 6.709302] fsl_mc_dpio dpio.13: Linked as a consumer to dpmcp.32
[ 6.718529] fsl_mc_dpio dpio.13: probed
[ 6.725982] iommu: Adding device dpio.12 to group 0
[ 6.731372] fsl_mc_dpio dpio.12: Linked as a consumer to dpmcp.31
[ 6.740478] fsl_mc_dpio dpio.12: probed
[ 6.747938] iommu: Adding device dpio.11 to group 0
[ 6.753327] fsl_mc_dpio dpio.11: Linked as a consumer to dpmcp.30
[ 6.762548] fsl_mc_dpio dpio.11: probed
[ 6.769944] iommu: Adding device dpio.10 to group 0
[ 6.775337] fsl_mc_dpio dpio.10: Linked as a consumer to dpmcp.29
[ 6.784479] fsl_mc_dpio dpio.10: probed
[ 6.791892] iommu: Adding device dpio.9 to group 0
[ 6.797194] fsl_mc_dpio dpio.9: Linked as a consumer to dpmcp.28
[ 6.806324] fsl_mc_dpio dpio.9: probed
[ 6.813482] iommu: Adding device dpio.8 to group 0
[ 6.818865] fsl_mc_dpio dpio.8: Linked as a consumer to dpmcp.27
[ 6.828034] fsl_mc_dpio dpio.8: probed
[ 6.835349] iommu: Adding device dpio.7 to group 0
[ 6.840652] fsl_mc_dpio dpio.7: Linked as a consumer to dpmcp.26
[ 6.849823] fsl_mc_dpio dpio.7: probed
[ 6.857140] iommu: Adding device dpio.6 to group 0
[ 6.862362] fsl_mc_dpio dpio.6: Linked as a consumer to dpmcp.25
[ 6.871469] fsl_mc_dpio dpio.6: probed
[ 6.878852] iommu: Adding device dpio.5 to group 0
[ 6.884155] fsl_mc_dpio dpio.5: Linked as a consumer to dpmcp.24
[ 6.892982] fsl_mc_dpio dpio.5: probed
[ 6.900353] iommu: Adding device dpio.4 to group 0
[ 6.905657] fsl_mc_dpio dpio.4: Linked as a consumer to dpmcp.23
[ 6.914786] fsl_mc_dpio dpio.4: probed
[ 6.922139] iommu: Adding device dpio.3 to group 0
[ 6.927443] fsl_mc_dpio dpio.3: Linked as a consumer to dpmcp.22
[ 6.936494] fsl_mc_dpio dpio.3: probed
[ 6.943811] iommu: Adding device dpio.2 to group 0
[ 6.949114] fsl_mc_dpio dpio.2: Linked as a consumer to dpmcp.21
[ 6.958285] fsl_mc_dpio dpio.2: probed
[ 6.965424] iommu: Adding device dpio.1 to group 0
[ 6.970864] fsl_mc_dpio dpio.1: Linked as a consumer to dpmcp.20
[ 6.979979] fsl_mc_dpio dpio.1: probed
[ 6.987353] iommu: Adding device dpio.0 to group 0
[ 6.992655] fsl_mc_dpio dpio.0: Linked as a consumer to dpmcp.19
[ 7.001784] fsl_mc_dpio dpio.0: probed
[ 7.006088] iommu: Adding device dpcon.31 to group 0
[ 7.011102] iommu: Adding device dpcon.30 to group 0
[ 7.016113] iommu: Adding device dpcon.29 to group 0
[ 7.021123] iommu: Adding device dpcon.28 to group 0
[ 7.026130] iommu: Adding device dpcon.27 to group 0
[ 7.031147] iommu: Adding device dpcon.26 to group 0
[ 7.036160] iommu: Adding device dpcon.25 to group 0
[ 7.041169] iommu: Adding device dpcon.24 to group 0
[ 7.046178] iommu: Adding device dpcon.23 to group 0
[ 7.051189] iommu: Adding device dpcon.22 to group 0
[ 7.056197] iommu: Adding device dpcon.21 to group 0
[ 7.061209] iommu: Adding device dpcon.20 to group 0
[ 7.066216] iommu: Adding device dpcon.19 to group 0
[ 7.071227] iommu: Adding device dpcon.18 to group 0
[ 7.076238] iommu: Adding device dpcon.17 to group 0
[ 7.081247] iommu: Adding device dpcon.16 to group 0
[ 7.086255] iommu: Adding device dpcon.15 to group 0
[ 7.091269] iommu: Adding device dpcon.14 to group 0
[ 7.096280] iommu: Adding device dpcon.13 to group 0
[ 7.101293] iommu: Adding device dpcon.12 to group 0
[ 7.106306] iommu: Adding device dpcon.11 to group 0
[ 7.111319] iommu: Adding device dpcon.10 to group 0
[ 7.116332] iommu: Adding device dpcon.9 to group 0
[ 7.121256] iommu: Adding device dpcon.8 to group 0
[ 7.126180] iommu: Adding device dpcon.7 to group 0
[ 7.131107] iommu: Adding device dpcon.6 to group 0
[ 7.136030] iommu: Adding device dpcon.5 to group 0
[ 7.140955] iommu: Adding device dpcon.4 to group 0
[ 7.145883] iommu: Adding device dpcon.3 to group 0
[ 7.150808] iommu: Adding device dpcon.2 to group 0
[ 7.155736] iommu: Adding device dpcon.1 to group 0
[ 7.160663] iommu: Adding device dpcon.0 to group 0
[ 7.168673] fsl_mc_dprc dprc.1: DPRC device bound to driver
[ 7.174869] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpmcp.18
[ 7.216478] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpcon.31
[ 7.225202] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpio.15
[ 7.231792] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpcon.30
[ 7.240480] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpio.14
[ 7.247115] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpcon.29
[ 7.255843] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpio.13
[ 7.262435] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpcon.28
[ 7.271119] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpio.12
[ 7.277753] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpcon.27
[ 7.286480] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpio.11
[ 7.293068] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpcon.26
[ 7.301748] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpio.10
[ 7.308391] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpcon.25
[ 7.317115] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpio.9
[ 7.323628] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpcon.24
[ 7.332355] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpio.8
[ 7.338865] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpcon.23
[ 7.347592] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpio.7
[ 7.354103] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpcon.22
[ 7.362829] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpio.6
[ 7.369340] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpcon.21
[ 7.378063] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpio.5
[ 7.384577] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpcon.20
[ 7.393301] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpio.4
[ 7.399814] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpcon.19
[ 7.408540] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpio.3
[ 7.415052] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpcon.18
[ 7.423777] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpio.2
[ 7.430289] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpcon.17
[ 7.439014] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpio.1
[ 7.444337] scsi 4:0:0:0: Direct-Access 8.07 PQ: 0 ANSI: 4
[ 7.445525] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpcon.16
[ 7.460048] sd 4:0:0:0: [sda] 31457280 512-byte logical blocks: (16.1 GB/15.0 GiB)
[ 7.461776] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpio.0
[ 7.468287] sd 4:0:0:0: [sda] Write Protect is off
[ 7.474149] fsl_dpaa2_eth dpni.1: Linked as a consumer to dpbp.1
[ 7.485067] sd 4:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 7.556469] fsl_dpaa2_eth dpni.1: Probed interface eth0
[ 7.562278] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpmcp.17
[ 7.603853] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpcon.15
[ 7.612539] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpio.15
[ 7.619127] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpcon.14
[ 7.627813] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpio.14
[ 7.634436] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpcon.13
[ 7.643159] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpio.13
[ 7.649747] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpcon.12
[ 7.658431] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpio.12
[ 7.665070] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpcon.11
[ 7.673794] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpio.11
[ 7.680381] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpcon.10
[ 7.689061] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpio.10
[ 7.695709] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpcon.9
[ 7.704305] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpio.9
[ 7.710807] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpcon.8
[ 7.719464] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpio.8
[ 7.726019] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpcon.7
[ 7.734614] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpio.7
[ 7.741114] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpcon.6
[ 7.749707] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpio.6
[ 7.756209] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpcon.5
[ 7.764869] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpio.5
[ 7.771402] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpcon.4
[ 7.779998] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpio.4
[ 7.786501] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpcon.3
[ 7.795158] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpio.3
[ 7.801712] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpcon.2
[ 7.810305] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpio.2
[ 7.816807] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpcon.1
[ 7.825399] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpio.1
[ 7.831900] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpcon.0
[ 7.840552] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpio.0
[ 7.847120] fsl_dpaa2_eth dpni.0: Linked as a consumer to dpbp.0
[ 7.924797] fsl_dpaa2_eth dpni.0: Probed interface eth1
[ 7.930662] dpaa2_mac dpmac.18: Linked as a consumer to dpmcp.16
[ 7.986925] sda: sda1 sda2 sda3 sda4
[ 7.992981] sd 4:0:0:0: [sda] Attached SCSI removable disk
[ 8.015292] dpaa2_mac dpmac.18: Connected to rgmii-id PHY.
[ 8.021340] dpaa2_mac dpmac.17: Linked as a consumer to dpmcp.15
[ 8.107288] dpaa2_mac dpmac.17: Connected to rgmii-id PHY.
[ 8.113313] dpaa2_mac dpmac.6: Linked as a consumer to dpmcp.14
[ 8.122513] dpaa2_mac dpmac.6: Registered fixed PHY.
[ 8.128082] dpaa2_mac dpmac.5: Linked as a consumer to dpmcp.13
[ 8.137363] dpaa2_mac dpmac.5: Registered fixed PHY.
[ 8.142884] dpaa2_mac dpmac.4: Linked as a consumer to dpmcp.12
[ 8.152466] dpaa2_mac dpmac.4: Connected to xgmii PHY.
[ 8.159145] dpaa2_mac dpmac.3: Linked as a consumer to dpmcp.11
[ 8.168676] dpaa2_mac dpmac.3: Connected to xgmii PHY.
[ 8.174364] dpaa2_mac dpmac.2: Linked as a consumer to dpmcp.10
[ 8.183591] dpaa2_mac dpmac.2: Registered fixed PHY.
[ 8.189116] dpaa2_caam dpseci.0: Linked as a consumer to dpmcp.9
[ 8.196139] dpaa2_caam dpseci.0: dpseci v5.3
[ 8.223369] netif_napi_add() called with weight 512 on device
[ 8.229201] dpaa2_caam dpseci.0: Linked as a consumer to dpio.15
[ 8.235201] dpaa2_caam dpseci.0: Linked as a consumer to dpio.14
[ 8.241202] dpaa2_caam dpseci.0: Linked as a consumer to dpio.13
[ 8.247202] dpaa2_caam dpseci.0: Linked as a consumer to dpio.12
[ 8.253200] dpaa2_caam dpseci.0: Linked as a consumer to dpio.11
[ 8.259199] dpaa2_caam dpseci.0: Linked as a consumer to dpio.10
[ 8.265197] dpaa2_caam dpseci.0: Linked as a consumer to dpio.9
[ 8.271108] dpaa2_caam dpseci.0: Linked as a consumer to dpio.8
[ 8.277019] dpaa2_caam dpseci.0: Linked as a consumer to dpio.7
[ 8.282931] dpaa2_caam dpseci.0: Linked as a consumer to dpio.6
[ 8.288843] dpaa2_caam dpseci.0: Linked as a consumer to dpio.5
[ 8.294754] dpaa2_caam dpseci.0: Linked as a consumer to dpio.4
[ 8.300665] dpaa2_caam dpseci.0: Linked as a consumer to dpio.3
[ 8.306577] dpaa2_caam dpseci.0: Linked as a consumer to dpio.2
[ 8.312488] dpaa2_caam dpseci.0: Linked as a consumer to dpio.1
[ 8.318399] dpaa2_caam dpseci.0: Linked as a consumer to dpio.0
[ 8.336682] dpaa2_caam dpseci.0: algorithms registered in /proc/crypto
[ 8.343728] dpaa2_caam dpseci.0: hash algorithms registered in /proc/crypto
[ 8.356507] rtc-pcf2127-i2c 1-0051: setting system clock to 2020-05-14 08:49:28 UTC (1589446168)
[ 8.365406] ALSA device list:
[ 8.368394] No soundcards found.
[ 9.138378] dpaa2_mac dpmac.6 (unnamed net_device) (uninitialized): Link is Up - 1Gbps/Full - flow control off
[ 9.170373] dpaa2_mac dpmac.5 (unnamed net_device) (uninitialized): Link is Up - 1Gbps/Full - flow control off
[ 9.202372] dpaa2_mac dpmac.2 (unnamed net_device) (uninitialized): Link is Up - 1Gbps/Full - flow control off
[ 9.437993] EXT4-fs (sda4): mounted filesystem with ordered data mode. Opts: (null)
[ 9.445661] VFS: Mounted root (ext4 filesystem) on device 8:4.
[ 9.928616] devtmpfs: mounted
[ 9.932019] Freeing unused kernel memory: 1536K
[ 9.936617] Run /sbin/init as init process
[ 9.943377] random: fast init done
[ 10.602820] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarc)
[ 10.627828] systemd[1]: Detected architecture arm64.
Welcome to Ubuntu 18.04.4 LTS!
[ 10.664074] systemd[1]: Set hostname to <localhost>.
[ 11.135448] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 11.152487] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 11.190685] dpaa2_mac dpmac.17 (unnamed net_device) (uninitialized): Link is Up - 1Gbps/Full - flow control rx/tx
[ 11.261675] systemd[1]: Configuration file /lib/systemd/system/weston.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 11.333782] systemd[1]: Configuration file /lib/systemd/system/fmc.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 11.396705] random: systemd: uninitialized urandom read (16 bytes read)
[ 11.403435] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 11.426417] random: systemd: uninitialized urandom read (16 bytes read)
[ 11.433085] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 11.458398] random: systemd: uninitialized urandom read (16 bytes read)
[ 11.465020] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ OK ] Reached target Local Encrypted Volumes.
[ OK ] Created slice User and Session Slice.
[ OK ] Created slice System Slice.
[ OK ] Listening on RPCbind Server Activation Socket.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on udev Control Socket.
[ OK ] Listening on fsck to fsckd communication Socket.
[ OK ] Listening on Journal Socket.
Starting Set the console keyboard layout...
Mounting NFSD configuration filesystem...
Mounting POSIX Message Queue File System...
[ OK ] Listening on Journal Audit Socket.
Mounting RPC Pipe File System...
[ OK ] Created slice system-systemd\x2dfsck.slice.
Mounting Kernel Debug File System...
[ OK ] Created slice system-serial\x2dgetty.slice.
[ OK ] Listening on Journal Socket (/dev/log).
[ OK ] Reached target Slices.
Starting Remount Root and Kernel File Systems...
[ 11.763934] EXT4-fs (sda4): re-mounted. Opts: errors=remount-ro
[ OK ] Listening on Syslog Socket.
Starting Journal Service...
[ OK ] Reached target Paths.
Starting Load Kernel Modules...
Starting Create list of required st…ce nodes for the current kernel...
Mounting Huge Pages File System...
[ OK ] Listening on udev Kernel Socket.
Starting udev Coldplug all Devices...
[ OK ] Started Set the console keyboard layout.
[ OK ] Started Journal Service.
[FAILED] Failed to mount NFSD configuration filesystem.
See 'systemctl status proc-fs-nfsd.mount' for details.
[DEPEND] Dependency failed for NFS server and services.
[DEPEND] Dependency failed for NFSv4 ID-name mapping service.
[DEPEND] Dependency failed for NFS Mount Daemon.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted RPC Pipe File System.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Create list of required sta…vice nodes for the current kernel.
[ OK ] Mounted Huge Pages File System.
Starting Create Static Device Nodes in /dev...
Mounting FUSE Control File System...
Mounting Kernel Configuration File System...
Starting Apply Kernel Variables...
Starting Load/Save Random Seed...
Starting pNFS block layout mapping daemon...
Starting Flush Journal to Persistent Storage...
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Mounted FUSE Control File System.
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Load/Save Random Seed.
[ OK ] Started pNFS block layout mapping daemon.
[ OK ] Reached target Local File Systems (Pre).
Starting udev Kernel Device Manager...
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Found device /dev/ttyAMA0.
[ OK ] Found device /sys/subsystem/net/devices/eth1.
[ OK ] Found device 6387 boot.
Starting File System Check on /dev/…b83-44f1-401c-9d3a-baca094b125d...
[ OK ] Started File System Check Daemon to report status.
[ OK ] Started File System Check on /dev/d…ddb83-44f1-401c-9d3a-baca094b125d.
Mounting /boot...
[ OK ] Mounted /boot.
[ OK ] Reached target Local File Systems.
Starting Preprocess NFS configuration...
Starting Raise network interfaces...
Starting Create Volatile Files and Directories...
Starting Set console font and keymap...
[ OK ] Started ifup for eth1.
Starting QEMU KVM preparation - module, ksm, hugepages...
[ OK ] Started Preprocess NFS configuration.
[ OK ] Started Create Volatile Files and Directories.
[ OK ] Started Set console font and keymap.
[ OK ] Started QEMU KVM preparation - module, ksm, hugepages.
Starting Network Name Resolution...
Starting RPC bind portmap service...
Starting Network Time Synchronization...
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Reached target NFS client services.
[ OK ] Started Raise network interfaces.
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started RPC bind portmap service.
[ OK ] Reached target Remote File Systems (Pre).
[ OK ] Reached target Remote File Systems.
[ OK ] Reached target RPC Port Mapper.
[ OK ] Started Network Name Resolution.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Initialization.
Starting Docker Socket for the API.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Daily apt download activities.
[ OK ] Started Daily apt upgrade and clean activities.
[ OK ] Started Discard unused blocks once a week.
[ OK ] Started Message of the Day.
[ OK ] Reached target Timers.
[ OK ] Reached target Network.
[ OK ] Reached target Network is Online.
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Listening on Docker Socket for the API.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
Starting LSB: HPA's tftp server...
Starting vsftpd FTP server...
Starting System Logging Service...
Starting LSB: Execute the kexec -e command to reboot system...
Starting OpenBSD Secure Shell server...
[ OK ] Started Regular background program processing daemon.
Starting Login Service...
Starting Permit User Sessions...
[ OK ] Started Set the CPU Frequency Scaling governor.
Starting Dispatcher daemon for systemd-networkd...
[ OK ] Started D-Bus System Message Bus.
Starting Resets System Activity Data Collector...
Starting NXP Frame Manager Configuration tool...
Starting containerd container runtime...
[ OK ] Started System Logging Service.
[ OK ] Started vsftpd FTP server.
[ OK ] Started Permit User Sessions.
[ OK ] Started OpenBSD Secure Shell server.
[ OK ] Started Resets System Activity Data Collector.
[ OK ] Started NXP Frame Manager Configuration tool.
[ OK ] Started containerd container runtime.
[ OK ] Started Login Service.
[ OK ] Started Unattended Upgrades Shutdown.
Starting Docker Application Container Engine...
Starting Weston Wayland Compositor (on tty7)...
Starting Set console scheme...
[ OK ] Started Serial Getty on ttyAMA0.
[ OK ] Started LSB: Execute the kexec -e command to reboot system.
[ OK ] Started Weston Wayland Compositor (on tty7).
[ OK ] Started LSB: HPA's tftp server.
[ OK ] Started Set console scheme.
[ OK ] Created slice system-getty.slice.
[ OK ] Started Getty on tty1.
[ OK ] Reached target Login Prompts.
Starting LSB: Load kernel image with kexec...
[ OK ] Started LSB: Load kernel image with kexec.
[ OK ] Created slice User Slice of root.
Starting User Manager for UID 0...
[ OK ] Started Session 1 of user root.
[ OK ] Started User Manager for UID 0.
[ OK ] Started Dispatcher daemon for systemd-networkd.
Stopping User Manager for UID 0...
[ OK ] Stopped User Manager for UID 0.
[ OK ] Removed slice User Slice of root.
Ubuntu 18.04.4 LTS localhost ttyAMA0
localhost login:
localhost login: root
Password:
Last login: Thu May 14 08:49:40 UTC 2020 on tty7
Welcome to Ubuntu 18.04.4 LTS (GNU/Linux 4.19.68 aarch64)
* Support: https://www.nxp.com/lsdk
* Documentation: https://lsdk.github.io/document
* Licensing: https://lsdk.github.io/eula
root@localhost:~# ls-listni
dprc.1/dpni.1 (interface: eth0, end point: dpmac.2)
dprc.1/dpni.0 (interface: eth1, end point: dpmac.17)
root@localhost:~# ifconfig
docker0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 172.17.0.1 netmask 255.255.0.0 broadcast 172.17.255.255
ether 02:42:b1:c8:fa:64 txqueuelen 0 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
eth1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.201.202 netmask 255.255.255.0 broadcast 192.168.201.255
inet6 fe80::204:9fff:fe05:dd8d prefixlen 64 scopeid 0x20<link>
ether 00:04:9f:05:dd:8d txqueuelen 1000 (Ethernet)
RX packets 78 bytes 7256 (7.2 KB)
RX errors 0 dropped 15 overruns 0 frame 0
TX packets 16 bytes 1208 (1.2 KB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 2 bytes 176 (176.0 B)
TX packets 2 bytes 176 (176.0 B)
root@localhost:~# ping 192.168.201.71
PING 192.168.201.71 (192.168.201.71) 56(84) bytes of data.
64 bytes from 192.168.201.71: icmp_seq=1 ttl=64 time=0.385 ms
^C
--- 192.168.201.71 ping statistics ---
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 0.385/0.385/0.385/0.000 ms
5,839 次查看
yipingwang
According to Linux Kernel boot up console log, it seems Linux Kernel source code has been modified.
Would you please try Linux Kernel Image from LSDK 20.04 pre_built Image tar ball?
I uploaded LSDK 20.04 5.4 Image  in the folloing link. Please copy Image to the boot partition on USB.
https://drive.google.com/open?id=1FOBBFzdbZ98vUXLW2QNpHG0Uktq959ym
5,839 次查看
zhanghonghui
Yes, I have apply the preempt-rt patch to the kernel and enable the preempt rt configuration, but this is not the root cause.
I have got the network interface solved by upgrade the firmware of MC to 10.20.4,
It seems that the MC firmware version must be consist with the kernel code.
Thanks for your help.
below is the console output after I upgrade the firmware.
fsl-mc: Management Complex booted (version: 10.20.4, boot status: 0x1)
5,839 次查看
zhanghonghui
those interface works fine in uboot,but after bootup to linux shell, it could not got any package.
crc32+
=> printenv ethact
ethact=DPMAC2@xlaui4
=> setenv ethact DPMAC17@rgmii-id
=> printenv serverip
serverip=192.168.201.237
=> printenv ipaddr
ipaddr=192.168.201.202
=> ping $serverip
Using DPMAC17@rgmii-id device
host 192.168.201.237 is alive
5,839 次查看
zhanghonghui
BTW, I'm using lx2160ardb rev1 not rev2 evb board. ls-listni output is and console log is as below:
=▒NOTICE: BL2: v1.5(release):LSDK-19.06
CPU15(A72):2000 MHz
FPGA: v5.0
I2C: ready
DRAM: 31.9 GiB
OK
EEPROM: NXID v1
In: serial_pl01x
Out: serial_pl01x
Err: serial_pl01x
Net:
crc32+
starting USB...
USB XHCI 1.00
USB XHCI 1.00
** Unrecognized filesystem type **
Scanning usb 0:2...
980 bytes read in 10 ms (95.7 KiB/s)
36758016 bytes read in 1532 ms (22.9 MiB/s)
32643 bytes read in 17 ms (1.8 MiB/s)
Loading Device Tree to 000000009fff5000, end 000000009fffff82 ... OK
Starting kernel ...
[ 0.000000] 000: printk: bootconsole [pl11] enabled
[ 0.000000] 000: efi: Getting EFI parameters from FDT:
[ 0.000000] 000: efi: UEFI not found.
[ 0.000000] 000: cma: Reserved 320 MiB at 0x00000000e7c00000
[ 0.000000] 000: NUMA: No NUMA configuration found
[ 0.000000] 000: NUMA: Faking a node at [mem 0x0000000080000000-0x000000277fffffff]
[ 0.000000] 000: NUMA: NODE_DATA [mem 0x277c3df780-0x277c3e0fff]
[ 0.000000] 000: Zone ranges:
[ 0.000000] 000: DMA32
[ 0.000000] 000: [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] 000: Normal
[ 0.000000] 000: [mem 0x0000000100000000-0x000000277fffffff]
[ 0.000000] 000: Movable zone start for each node
[ 0.000000] 000: Early memory node ranges
[ 0.000000] 000: node 0: [mem 0x0000000080000000-0x00000000fbdfffff]
[ 0.000000] 000: node 0: [mem 0x0000002080000000-0x000000277fffffff]
[ 0.000000] 000: Initmem setup node 0 [mem 0x0000000080000000-0x000000277fffffff]
[ 0.000000] 000: On node 0 totalpages: 7847424
[ 0.000000] 000: DMA32 zone: 8192 pages used for memmap
[ 0.000000] 000: DMA32 zone: 0 pages reserved
[ 0.000000] 000: DMA32 zone: 507392 pages, LIFO batch:63
[ 0.000000] 000: Normal zone: 114688 pages used for memmap
[ 0.000000] 000: Normal zone: 7340032 pages, LIFO batch:63
[ 0.000000] 000: psci: probing for conduit method from DT.
[ 0.000000] 000: psci: PSCIv1.1 detected in firmware.
[ 0.000000] 000: psci: Using standard PSCI v0.2 function IDs
[ 0.000000] 000: psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] 000: psci: SMC Calling Convention v1.1
[ 0.000000] 000: percpu: Embedded 20 pages/cpu s44992 r8192 d28736 u81920
[ 0.000000] 000: pcpu-alloc: s44992 r8192 d28736 u81920 alloc=20*4096
[ 0.000000] 000:
[ 0.000000] 000: [0]
[ 0.000000] 000: 00
[ 0.000000] 000: 01
[ 0.000000] 000: 02
[ 0.000000] 000: 03
[ 0.000000] 000: 04
[ 0.000000] 000: 05
[ 0.000000] 000: 06
[ 0.000000] 000: 07
[ 0.000000] 000:
[ 0.000000] 000: 08
[ 0.000000] 000: 09
[ 0.000000] 000: 10
[ 0.000000] 000: 11
[ 0.000000] 000: 12
[ 0.000000] 000: 13
[ 0.000000] 000: 14
[ 0.000000] 000: 15
[ 0.000000] 000:
[ 0.000000] 000: Detected PIPT I-cache on CPU0
[ 0.000000] 000: CPU features: detected: GIC system register CPU interface
[ 0.000000] 000: CPU features: detected: EL2 vector hardening
[ 0.000000] 000: CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] 000: CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] 000: Speculative Store Bypass Disable mitigation not required
[ 0.000000] 000: Built 1 zonelists, mobility grouping on. Total pages: 7724544
[ 0.000000] 000: Policy zone: Normal
[ 0.000000] 000: Kernel command line: console=ttyAMA0,115200 earlycon=pl011,mmio32,0x21c0000 root=PARTUUID=019d98bb-04 rw rootwait pci=pcie_bus_perf default_hugepagesz=1024m hugepagesz=1024m hugepages=2 pci=pcie_bus_perf isolcpus=1
[ 0.000000] 000: Dentry cache hash table entries: 4194304 (order: 14, 67108864 bytes, linear)
[ 0.000000] 000: Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] 000: mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] 000: software IO TLB: mapped [mem 0xe3c00000-0xe7c00000] (64MB)
[ 0.000000] 000: Memory: 28225524K/31389696K available (18620K kernel code, 2552K rwdata, 8856K rodata, 5824K init, 1087K bss, 2836492K reserved, 327680K cma-reserved)
[ 0.000000] 000: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
[ 0.000000] 000: rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] 000: rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.000000] 000: rcu: RCU_SOFTIRQ processing moved to rcuc kthreads.
[ 0.000000] 000: No expedited grace period (rcu_normal_after_boot).
[ 0.000000] 000: Tasks RCU enabled.
[ 0.000000] 000: rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] 000: NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] 000: GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] 000: GICv3: 256 SPIs implemented
[ 0.000000] 000: GICv3: 0 Extended SPIs implemented
[ 0.000000] 000: GICv3: Distributor has no Range Selector support
[ 0.000000] 000: GICv3: 16 PPIs implemented
[ 0.000000] 000: GICv3: no VLPI support, no direct LPI support
[ 0.000000] 000: GICv3: CPU0: found redistributor 0 region 0:0x0000000006200000
[ 0.000000] 000: ITS [mem 0x06020000-0x0603ffff]
[ 0.000000] 000: ITS@0x0000000006020000: allocated 65536 Devices @2758c80000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] 000: ITS: using cache flushing for cmd queue
[ 0.000000] 000: GICv3: using LPI property table @0x0000002758c70000
[ 0.000000] 000: GIC: using cache flushing for LPI property table
[ 0.000000] 000: GICv3: CPU0: using allocated LPI pending table @0x0000002758d00000
[ 0.000000] 000: random: get_random_bytes called from start_kernel+0x2bc/0x458 with crng_init=0
[ 0.000000] 000: arch_timer: cp15 timer(s) running at 25.00MHz (phys).
[ 0.000000] 000: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x5c409fb33, max_idle_ns: 440795203156 ns
[ 0.000000] 000: sched_clock: 56 bits at 25MHz, resolution 39ns, wraps every 4398046511103ns
[ 0.008707] 000: Console: colour dummy device 80x25
[ 0.013669] 000: Calibrating delay loop (skipped), value calculated using timer frequency..
[ 0.022198] 000: 50.00 BogoMIPS (lpj=100000)
[ 0.026508] 000: pid_max: default: 32768 minimum: 301
[ 0.031646] 000: LSM: Security Framework initializing
[ 0.036850] 000: Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.045018] 000: Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.077586] 000: ASID allocator initialised with 32768 entries
[ 0.091491] 000: rcu: Hierarchical SRCU implementation.
[ 0.120820] 000: Platform MSI: gic-its@6020000 domain created
[ 0.126661] 000: PCI/MSI: /interrupt-controller@6000000/gic-its@6020000 domain created
[ 0.134691] 000: fsl-mc MSI: /interrupt-controller@6000000/gic-its@6020000 domain created
[ 0.143317] 000: EFI services will not be available.
[ 0.156343] 000: smp: Bringing up secondary CPUs ...
[ 0.209476] 001: Detected PIPT I-cache on CPU1
[ 0.213977] 001: GICv3: CPU1: found redistributor 1 region 0:0x0000000006220000
[ 0.221372] 001: GICv3: CPU1: using allocated LPI pending table @0x0000002758d10000
[ 0.229122] 001: CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[ 0.281521] 002: Detected PIPT I-cache on CPU2
[ 0.286021] 002: GICv3: CPU2: found redistributor 100 region 0:0x0000000006240000
[ 0.293593] 002: GICv3: CPU2: using allocated LPI pending table @0x0000002758d20000
[ 0.301344] 002: CPU2: Booted secondary processor 0x0000000100 [0x410fd083]
[ 0.353570] 003: Detected PIPT I-cache on CPU3
[ 0.358065] 003: GICv3: CPU3: found redistributor 101 region 0:0x0000000006260000
[ 0.365635] 003: GICv3: CPU3: using allocated LPI pending table @0x0000002758d30000
[ 0.373382] 003: CPU3: Booted secondary processor 0x0000000101 [0x410fd083]
[ 0.425628] 004: Detected PIPT I-cache on CPU4
[ 0.430128] 004: GICv3: CPU4: found redistributor 200 region 0:0x0000000006280000
[ 0.437699] 004: GICv3: CPU4: using allocated LPI pending table @0x0000002758d40000
[ 0.445449] 004: CPU4: Booted secondary processor 0x0000000200 [0x410fd083]
[ 0.497679] 005: Detected PIPT I-cache on CPU5
[ 0.502174] 005: GICv3: CPU5: found redistributor 201 region 0:0x00000000062a0000
[ 0.509745] 005: GICv3: CPU5: using allocated LPI pending table @0x0000002758d50000
[ 0.517491] 005: CPU5: Booted secondary processor 0x0000000201 [0x410fd083]
[ 0.569741] 006: Detected PIPT I-cache on CPU6
[ 0.574242] 006: GICv3: CPU6: found redistributor 300 region 0:0x00000000062c0000
[ 0.581813] 006: GICv3: CPU6: using allocated LPI pending table @0x0000002758d60000
[ 0.589563] 006: CPU6: Booted secondary processor 0x0000000300 [0x410fd083]
[ 0.641791] 007: Detected PIPT I-cache on CPU7
[ 0.646288] 007: GICv3: CPU7: found redistributor 301 region 0:0x00000000062e0000
[ 0.653858] 007: GICv3: CPU7: using allocated LPI pending table @0x0000002758d70000
[ 0.661605] 007: CPU7: Booted secondary processor 0x0000000301 [0x410fd083]
[ 0.713852] 008: Detected PIPT I-cache on CPU8
[ 0.718356] 008: GICv3: CPU8: found redistributor 400 region 0:0x0000000006300000
[ 0.725927] 008: GICv3: CPU8: using allocated LPI pending table @0x0000002758d80000
[ 0.733678] 008: CPU8: Booted secondary processor 0x0000000400 [0x410fd083]
[ 0.785903] 009: Detected PIPT I-cache on CPU9
[ 0.790401] 009: GICv3: CPU9: found redistributor 401 region 0:0x0000000006320000
[ 0.797972] 009: GICv3: CPU9: using allocated LPI pending table @0x0000002758d90000
[ 0.805719] 009: CPU9: Booted secondary processor 0x0000000401 [0x410fd083]
[ 0.857963] 010: Detected PIPT I-cache on CPU10
[ 0.862557] 010: GICv3: CPU10: found redistributor 500 region 0:0x0000000006340000
[ 0.870217] 010: GICv3: CPU10: using allocated LPI pending table @0x0000002758da0000
[ 0.878055] 010: CPU10: Booted secondary processor 0x0000000500 [0x410fd083]
[ 0.930016] 011: Detected PIPT I-cache on CPU11
[ 0.934604] 011: GICv3: CPU11: found redistributor 501 region 0:0x0000000006360000
[ 0.942262] 011: GICv3: CPU11: using allocated LPI pending table @0x0000002758db0000
[ 0.950098] 011: CPU11: Booted secondary processor 0x0000000501 [0x410fd083]
[ 1.002077] 012: Detected PIPT I-cache on CPU12
[ 1.006672] 012: GICv3: CPU12: found redistributor 600 region 0:0x0000000006380000
[ 1.014332] 012: GICv3: CPU12: using allocated LPI pending table @0x0000002758dc0000
[ 1.022171] 012: CPU12: Booted secondary processor 0x0000000600 [0x410fd083]
[ 1.074128] 013: Detected PIPT I-cache on CPU13
[ 1.078718] 013: GICv3: CPU13: found redistributor 601 region 0:0x00000000063a0000
[ 1.086376] 013: GICv3: CPU13: using allocated LPI pending table @0x0000002758dd0000
[ 1.094212] 013: CPU13: Booted secondary processor 0x0000000601 [0x410fd083]
[ 1.146195] 014: Detected PIPT I-cache on CPU14
[ 1.150791] 014: GICv3: CPU14: found redistributor 700 region 0:0x00000000063c0000
[ 1.158451] 014: GICv3: CPU14: using allocated LPI pending table @0x0000002758de0000
[ 1.166290] 014: CPU14: Booted secondary processor 0x0000000700 [0x410fd083]
[ 1.218247] 015: Detected PIPT I-cache on CPU15
[ 1.222837] 015: GICv3: CPU15: found redistributor 701 region 0:0x00000000063e0000
[ 1.230495] 015: GICv3: CPU15: using allocated LPI pending table @0x0000002758df0000
[ 1.238331] 015: CPU15: Booted secondary processor 0x0000000701 [0x410fd083]
[ 1.245497] 000: smp: Brought up 1 node, 16 CPUs
[ 1.250173] 000: SMP: Total of 16 processors activated.
[ 1.255458] 000: CPU features: detected: 32-bit EL0 Support
[ 1.261096] 000: CPU features: detected: CRC32 instructions
[ 1.278069] 000: CPU: All CPU(s) started at EL2
[ 1.282680] 000: alternatives: patching kernel code
[ 1.288275] 000: devtmpfs: initialized
[ 1.294374] 000: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 1.304679] 000: futex hash table entries: 4096 (order: 7, 524288 bytes, linear)
[ 1.314996] 000: xor: measuring software checksum speed
[ 1.360313] 000: 8regs : 8464.000 MB/sec
[ 1.405008] 009: 32regs : 8644.000 MB/sec
[ 1.449024] 009: arm64_neon: 8430.000 MB/sec
[ 1.453690] 009: xor: using function: 32regs (8644.000 MB/sec)
[ 1.459593] 009: pinctrl core: initialized pinctrl subsystem
[ 1.465768] 009: DMI not present or invalid.
[ 1.470261] 009: NET: Registered protocol family 16
[ 1.475919] 009: DMA: preallocated 256 KiB pool for atomic allocations
[ 1.482525] 009: audit: initializing netlink subsys (disabled)
[ 1.488505] 013: audit: type=2000 audit(1.416:1): state=initialized audit_enabled=0 res=1
[ 1.496784] 009: cpuidle: using governor menu
[ 1.501392] 009: hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 1.509212] 009: Serial: AMBA PL011 UART driver
[ 1.513833] 009: imx mu driver is registered.
[ 1.518245] 009: imx rpmsg driver is registered.
[ 1.523785] 009: Machine: NXP Layerscape LX2160ARDB
[ 1.528719] 009: SoC family: QorIQ LX2160A
[ 1.532857] 009: SoC ID: svr:0x87360010, Revision: 1.0
[ 1.539205] 009: 21c0000.serial: ttyAMA0 at MMIO 0x21c0000 (irq = 20, base_baud = 0) is a SBSA
[ 1.547923] 009: printk: console [ttyAMA0] enabled
[ 1.552765] 009: printk: bootconsole [pl11] disabled
[ 0.000000] 000: Booting Linux on physical CPU 0x0000000000 [0x410fd083]
[ 0.000000] 000: Linux version 5.4.3-rt1-00002-g7331d03169b1 (root@fbubuntu) (gcc version 7.5.0 (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04)) #1 SMP PREEMPT_RT Thu May 14 10:45:24 CST 2020
[ 0.000000] 000: Machine model: NXP Layerscape LX2160ARDB
[ 0.000000] 000: earlycon: pl11 at MMIO32 0x00000000021c0000 (options '')
[ 0.000000] 000: DMA32 [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] 000: Normal [mem 0x0000000100000000-0x000000277fffffff]
[ 0.022195] 000: Calibrating delay loop (skipped), value calculated using timer frequency.. 50.00 BogoMIPS (lpj=100000)
[ 1.558043] 009: sbsa-uart 21d0000.serial: aliased and non-aliased serial devices found in device tree. Serial port enumeration may be unpredictable.
[ 1.558048] 009: 21d0000.serial: ttyAMA1 at MMIO 0x21d0000 (irq = 21, base_baud = 0) is a SBSA
[ 1.562277] 009: fsl_mc_bus 80c000000.fsl-mc: MC firmware version: 10.16.2
[ 1.564880] 009: fsl_mc_dprc dprc.1: DMA mask not set
[ 1.577177] 009: HugeTLB registered 1.00 GiB page size, pre-allocated 2 pages
[ 1.577183] 009: HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 1.577185] 009: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 1.577187] 009: HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 1.578514] 009: cryptd: max_cpu_qlen set to 1000
[ 1.653163] 000: raid6: neonx8 gen() 4865 MB/s
[ 1.721200] 010: raid6: neonx8 xor() 4131 MB/s
[ 1.789235] 009: raid6: neonx4 gen() 4039 MB/s
[ 1.857275] 000: raid6: neonx4 xor() 3788 MB/s
[ 1.925328] 010: raid6: neonx2 gen() 3205 MB/s
[ 1.993359] 011: raid6: neonx2 xor() 3804 MB/s
[ 2.061399] 010: raid6: neonx1 gen() 2458 MB/s
[ 2.129439] 011: raid6: neonx1 xor() 2803 MB/s
[ 2.197502] 009: raid6: int64x8 gen() 2164 MB/s
[ 2.265517] 000: raid6: int64x8 xor() 1814 MB/s
[ 2.333572] 010: raid6: int64x4 gen() 2509 MB/s
[ 2.401590] 011: raid6: int64x4 xor() 1849 MB/s
[ 2.469642] 010: raid6: int64x2 gen() 1684 MB/s
[ 2.537658] 011: raid6: int64x2 xor() 1680 MB/s
[ 2.605719] 010: raid6: int64x1 gen() 1231 MB/s
[ 2.673738] 009: raid6: int64x1 xor() 1104 MB/s
[ 2.673740] 009: raid6: using algorithm neonx8 gen() 4865 MB/s
[ 2.673741] 009: raid6: .... xor() 4131 MB/s, rmw enabled
[ 2.673743] 009: raid6: using neon recovery algorithm
[ 2.673982] 009: ACPI: Interpreter disabled.
[ 2.674554] 009: iommu: Default domain type: Passthrough (set via kernel command line)
[ 2.674633] 009: vgaarb: loaded
[ 2.674787] 009: SCSI subsystem initialized
[ 2.674962] 009: usbcore: registered new interface driver usbfs
[ 2.674977] 009: usbcore: registered new interface driver hub
[ 2.675028] 009: usbcore: registered new device driver usb
[ 2.675266] 009: imx-i2c 2000000.i2c: can't get pinctrl, bus recovery not supported
[ 2.675353] 009: i2c i2c-0: IMX I2C adapter registered
[ 2.675460] 009: imx-i2c 2040000.i2c: can't get pinctrl, bus recovery not supported
[ 2.675531] 009: i2c i2c-1: IMX I2C adapter registered
[ 2.675716] 009: mc: Linux media interface: v0.10
[ 2.675726] 009: videodev: Linux video capture interface: v2.00
[ 2.675751] 009: pps_core: LinuxPPS API ver. 1 registered
[ 2.675753] 009: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 2.675757] 009: PTP clock support registered
[ 2.675795] 009: EDAC MC: Ver: 3.0.0
[ 2.676163] 009: No BMan portals available!
[ 2.676300] 009: QMan: Allocated lookup table at (____ptrval____), entry count 65537
[ 2.676361] 009: No QMan portals available!
[ 2.676446] 009: No USDPAA memory, no 'fsl,usdpaa-mem' in device-tree
[ 2.676610] 009: FPGA manager framework
[ 2.676652] 009: Advanced Linux Sound Architecture Driver Initialized.
[ 2.677161] 009: clocksource: Switched to clocksource arch_sys_counter
[ 2.677242] 009: VFS: Disk quotas dquot_6.6.0
[ 2.677269] 009: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 2.677365] 009: pnp: PnP ACPI: disabled
[ 2.679957] 009: thermal_sys: Registered thermal governor 'step_wise'
[ 2.679959] 009: thermal_sys: Registered thermal governor 'power_allocator'
[ 2.680153] 009: NET: Registered protocol family 2
[ 2.680356] 009: tcp_listen_portaddr_hash hash table entries: 16384 (order: 8, 1048576 bytes, linear)
[ 2.680594] 009: TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 2.681473] 000: TCP bind hash table entries: 65536 (order: 9, 3670016 bytes, linear)
[ 2.682186] 000: TCP: Hash tables configured (established 262144 bind 65536)
[ 2.682310] 000: UDP hash table entries: 16384 (order: 9, 2097152 bytes, linear)
[ 2.682774] 000: UDP-Lite hash table entries: 16384 (order: 9, 2097152 bytes, linear)
[ 2.683361] 000: NET: Registered protocol family 1
[ 2.683618] 000: RPC: Registered named UNIX socket transport module.
[ 2.683621] 000: RPC: Registered udp transport module.
[ 2.683622] 000: RPC: Registered tcp transport module.
[ 2.683623] 000: RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.683627] 000: PCI: CLS 0 bytes, default 64
[ 2.684574] 000: hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 2.684690] 000: kvm [1]: IPA Size Limit: 44bits
[ 2.685086] 000: kvm [1]: vgic-v2@c0e0000
[ 2.685102] 000: kvm [1]: GIC system register CPU interface enabled
[ 2.685281] 000: kvm [1]: vgic interrupt IRQ1
[ 2.685445] 000: kvm [1]: Hyp mode initialized successfully
[ 2.686508] 000: Initialise system trusted keyrings
[ 2.686569] 000: workingset: timestamp_bits=44 max_order=23 bucket_order=0
[ 2.689385] 000: squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.689668] 000: NFS: Registering the id_resolver key type
[ 2.689677] 000: Key type id_resolver registered
[ 2.689679] 000: Key type id_legacy registered
[ 2.689683] 000: nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 2.689694] 000: jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 2.689854] 000: fuse: init (API version 7.31)
[ 2.689994] 000: 9p: Installing v9fs 9p2000 file system support
[ 2.697213] 000: Key type asymmetric registered
[ 2.697216] 000: Asymmetric key parser 'x509' registered
[ 2.697231] 000: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 2.697299] 000: io scheduler mq-deadline registered
[ 2.697301] 000: io scheduler kyber registered
[ 2.700621] 000: layerscape-pcie-gen4 3600000.pcie: host bridge /soc/pcie@3600000 ranges:
[ 2.700634] 000: layerscape-pcie-gen4 3600000.pcie: MEM 0x9040000000..0x907fffffff -> 0x40000000
[ 3.700824] 000: layerscape-pcie-gen4 3600000.pcie: link never came up
[ 3.700827] 000: layerscape-pcie-gen4 3600000.pcie: link bring-up failed
[ 3.700828] 000: layerscape-pcie-gen4 3600000.pcie: Fail to probe
[ 3.700868] 000: layerscape-pcie-gen4: probe of 3600000.pcie failed with error -110
[ 3.700913] 000: layerscape-pcie-gen4 3800000.pcie: host bridge /soc/pcie@3800000 ranges:
[ 3.700921] 000: layerscape-pcie-gen4 3800000.pcie: MEM 0xa040000000..0xa07fffffff -> 0x40000000
[ 4.701096] 000: layerscape-pcie-gen4 3800000.pcie: link never came up
[ 4.701098] 000: layerscape-pcie-gen4 3800000.pcie: link bring-up failed
[ 4.701100] 000: layerscape-pcie-gen4 3800000.pcie: Fail to probe
[ 4.701133] 000: layerscape-pcie-gen4: probe of 3800000.pcie failed with error -110
[ 4.701435] 000: EINJ: ACPI disabled.
[ 4.703410] 000: Bus freq driver module loaded
[ 4.705781] 000: Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 4.706546] 000: SuperH (H)SCI(F) driver initialized
[ 4.706715] 000: msm_serial: driver initialized
[ 4.707669] 000: arm-smmu 5000000.iommu: probing hardware configuration...
[ 4.707672] 000: arm-smmu 5000000.iommu: SMMUv2 with:
[ 4.707675] 000: arm-smmu 5000000.iommu: stage 1 translation
[ 4.707677] 000: arm-smmu 5000000.iommu: stage 2 translation
[ 4.707679] 000: arm-smmu 5000000.iommu: nested translation
[ 4.707680] 000: arm-smmu 5000000.iommu: coherent table walk
[ 4.707682] 000: arm-smmu 5000000.iommu: (IDR0.CTTW overridden by FW configuration)
[ 4.707684] 000: arm-smmu 5000000.iommu: stream matching with 128 register groups
[ 4.707688] 000: arm-smmu 5000000.iommu: 64 context banks (0 stage-2 only)
[ 4.707691] 000: arm-smmu 5000000.iommu: Supported page sizes: 0x61311000
[ 4.707693] 000: arm-smmu 5000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.707695] 000: arm-smmu 5000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.713854] 000: brd: module loaded
[ 4.718946] 009: loop: module loaded
[ 4.719866] 009: imx ahci driver is registered.
[ 4.720019] 009: ahci-qoriq 3200000.sata: 3200000.sata supply ahci not found, using dummy regulator
[ 4.720049] 009: ahci-qoriq 3200000.sata: 3200000.sata supply phy not found, using dummy regulator
[ 4.720069] 009: ahci-qoriq 3200000.sata: 3200000.sata supply target not found, using dummy regulator
[ 4.720134] 009: ahci-qoriq 3200000.sata: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[ 4.720138] 009: ahci-qoriq 3200000.sata: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[ 4.724467] 009: scsi host0: ahci-qoriq
[ 4.724587] 009: ata1: SATA max UDMA/133 mmio [mem 0x03200000-0x0320ffff] port 0x100 irq 28
[ 4.724639] 009: ahci-qoriq 3210000.sata: 3210000.sata supply ahci not found, using dummy regulator
[ 4.724662] 009: ahci-qoriq 3210000.sata: 3210000.sata supply phy not found, using dummy regulator
[ 4.724680] 009: ahci-qoriq 3210000.sata: 3210000.sata supply target not found, using dummy regulator
[ 4.724740] 009: ahci-qoriq 3210000.sata: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[ 4.724743] 009: ahci-qoriq 3210000.sata: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[ 4.729031] 009: scsi host1: ahci-qoriq
[ 4.729107] 009: ata2: SATA max UDMA/133 mmio [mem 0x03210000-0x0321ffff] port 0x100 irq 29
[ 4.729181] 009: ahci-qoriq 3220000.sata: 3220000.sata supply ahci not found, using dummy regulator
[ 4.729209] 009: ahci-qoriq 3220000.sata: 3220000.sata supply phy not found, using dummy regulator
[ 4.729228] 009: ahci-qoriq 3220000.sata: 3220000.sata supply target not found, using dummy regulator
[ 4.729274] 009: ahci-qoriq 3220000.sata: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[ 4.729277] 009: ahci-qoriq 3220000.sata: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[ 4.733582] 009: scsi host2: ahci-qoriq
[ 4.733658] 009: ata3: SATA max UDMA/133 mmio [mem 0x03220000-0x0322ffff] port 0x100 irq 30
[ 4.733707] 009: ahci-qoriq 3230000.sata: 3230000.sata supply ahci not found, using dummy regulator
[ 4.733729] 009: ahci-qoriq 3230000.sata: 3230000.sata supply phy not found, using dummy regulator
[ 4.733747] 009: ahci-qoriq 3230000.sata: 3230000.sata supply target not found, using dummy regulator
[ 4.733794] 009: ahci-qoriq 3230000.sata: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[ 4.733798] 009: ahci-qoriq 3230000.sata: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[ 4.738079] 009: scsi host3: ahci-qoriq
[ 4.738158] 009: ata4: SATA max UDMA/133 mmio [mem 0x03230000-0x0323ffff] port 0x100 irq 31
[ 4.739180] 009: spi-nor spi0.0: found mt35xu512aba, expected m25p80
[ 4.739189] 009: spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
[ 4.740025] 009: spi-nor spi0.1: found mt35xu512aba, expected m25p80
[ 4.740031] 009: spi-nor spi0.1: mt35xu512aba (65536 Kbytes)
[ 4.741462] 009: libphy: Fixed MDIO Bus: probed
[ 4.741760] 009: tun: Universal TUN/TAP device driver, 1.6
[ 4.742044] 009: thunder_xcv, ver 1.0
[ 4.742058] 009: thunder_bgx, ver 1.0
[ 4.742070] 009: nicpf, ver 1.0
[ 4.742230] 009: libphy: Freescale XGMAC MDIO Bus: probed
[ 4.746387] 009: libphy: Freescale XGMAC MDIO Bus: probed
[ 4.750851] 009: Freescale FM module, FMD API version 21.1.0
[ 4.750901] 009: Freescale FM Ports module
[ 4.750902] 009: fsl_mac: fsl_mac: FSL FMan MAC API based driver
[ 4.750940] 009: fsl_dpa: FSL DPAA Ethernet driver
[ 4.750971] 009: fsl_advanced: FSL DPAA Advanced drivers:
[ 4.750972] 009: fsl_proxy: FSL DPAA Proxy initialization driver
[ 4.751001] 009: fsl_oh: FSL FMan Offline Parsing port driver
[ 4.751246] 009: hclge is initializing
[ 4.751247] 009: hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 4.751249] 009: hns3: Copyright (c) 2017 Huawei Corporation.
[ 4.751268] 009: e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[ 4.751269] 009: e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 4.751285] 009: e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 4.751286] 009: e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.751301] 009: igb: Intel(R) Gigabit Ethernet Network Driver - version 5.6.0-k
[ 4.751303] 009: igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.751315] 009: igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 4.751316] 009: igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 4.751429] 009: sky2: driver version 1.30
[ 4.751625] 009: usbcore: registered new interface driver r8152
[ 4.751637] 009: usbcore: registered new interface driver asix
[ 4.751649] 009: usbcore: registered new interface driver ax88179_178a
[ 4.751841] 009: VFIO - User Level meta-driver version: 0.3
[ 4.756014] 009: dwc3 3100000.usb: Failed to get clk 'ref': -2
[ 4.756289] 009: dwc3 3110000.usb: Failed to get clk 'ref': -2
[ 4.756934] 009: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 4.756936] 009: ehci-pci: EHCI PCI platform driver
[ 4.756948] 009: ehci-platform: EHCI generic platform driver
[ 4.756987] 009: ehci-orion: EHCI orion driver
[ 4.757021] 009: ehci-exynos: EHCI EXYNOS driver
[ 4.757051] 009: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.757058] 009: ohci-pci: OHCI PCI platform driver
[ 4.757070] 009: ohci-platform: OHCI generic platform driver
[ 4.757107] 009: ohci-exynos: OHCI EXYNOS driver
[ 4.757340] 012: xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 4.757350] 012: xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 4.757412] 012: xhci-hcd xhci-hcd.0.auto: hcc params 0x0220f66d hci version 0x100 quirks 0x0000000002010810
[ 4.757492] 012: xhci-hcd xhci-hcd.0.auto: irq 26, io mem 0x03100000
[ 4.757855] 012: hub 1-0:1.0: USB hub found
[ 4.757869] 013: hub 1-0:1.0: 1 port detected
[ 4.757998] 012: xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 4.758003] 012: xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 4.758007] 012: xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 4.758256] 013: hub 2-0:1.0: USB hub found
[ 4.758269] 012: hub 2-0:1.0: 1 port detected
[ 4.758432] 013: xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 4.758438] 013: xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
[ 4.758517] 013: xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f66d hci version 0x100 quirks 0x0000000002010810
[ 4.758578] 013: xhci-hcd xhci-hcd.1.auto: irq 27, io mem 0x03110000
[ 4.758882] 013: hub 3-0:1.0: USB hub found
[ 4.758896] 012: hub 3-0:1.0: 1 port detected
[ 4.759016] 013: xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 4.759021] 013: xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
[ 4.759025] 013: xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[ 4.759268] 012: hub 4-0:1.0: USB hub found
[ 4.759281] 013: hub 4-0:1.0: 1 port detected
[ 4.759521] 012: usbcore: registered new interface driver usb-storage
[ 4.760690] 012: ftm-alarm 2800000.timer: registered as rtc1
[ 4.765478] 012: rtc-pcf2127-i2c 1-0051: registered as rtc0
[ 4.765735] 012: i2c /dev entries driver
[ 4.766803] 012: i2c i2c-0: Added multiplexed i2c bus 2
[ 4.766883] 012: i2c i2c-0: Added multiplexed i2c bus 3
[ 4.767028] 012: i2c i2c-0: Added multiplexed i2c bus 4
[ 4.767215] 012: i2c i2c-0: Added multiplexed i2c bus 5
[ 4.767296] 012: i2c i2c-0: Added multiplexed i2c bus 6
[ 4.767376] 012: i2c i2c-0: Added multiplexed i2c bus 7
[ 4.767452] 012: i2c i2c-0: Added multiplexed i2c bus 8
[ 4.767536] 012: i2c i2c-0: Added multiplexed i2c bus 9
[ 4.767539] 012: pca954x 0-0077: registered 8 multiplexed busses for I2C mux pca9547
[ 4.768767] 012: sbsa-gwdt 23a0000.watchdog: Initialized with 30s timeout @ 25000050 Hz, action=0.
[ 4.770854] 012: qoriq_cpufreq: Freescale QorIQ CPU frequency scaling driver
[ 4.771461] 012: sdhci: Secure Digital Host Controller Interface driver
[ 4.771462] 012: sdhci: Copyright(c) Pierre Ossman
[ 4.771600] 012: Synopsys Designware Multimedia Card Interface Driver
[ 4.771891] 012: sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.797584] 013: mmc0: SDHCI controller on 2140000.esdhc [2140000.esdhc] using ADMA 64-bit
[ 4.823754] 013: mmc1: SDHCI controller on 2150000.esdhc [2150000.esdhc] using ADMA 64-bit
[ 4.826293] 013: caam 8000000.crypto: device ID = 0x0a1a020000000000 (Era 10)
[ 4.826302] 013: caam 8000000.crypto: job rings = 3, qi = 1
[ 4.846196] 000: caam algorithms registered in /proc/crypto
[ 4.849007] 000: caam 8000000.crypto: caam pkc algorithms registered in /proc/crypto
[ 4.849315] 000: caam_jr 8010000.jr: registering rng-caam
[ 4.858326] 010: usbcore: registered new interface driver usbhid
[ 4.858331] 010: usbhid: USB HID core driver
[ 4.859691] 010: No fsl,qman node
[ 4.859696] 010: Freescale USDPAA process driver
[ 4.859698] 010: fsl-usdpaa: no region found
[ 4.859701] 010: Freescale USDPAA process IRQ driver
[ 4.862227] 010: optee: probing for conduit method from DT.
[ 4.862232] 010: optee: api uid mismatch
[ 4.866133] 010: NET: Registered protocol family 26
[ 4.866163] 010: u32 classifier
[ 4.866165] 010: input device check on
[ 4.866166] 010: Actions configured
[ 4.867166] 010: Initializing XFRM netlink socket
[ 4.867514] 010: NET: Registered protocol family 10
[ 4.868212] 010: Segment Routing with IPv6
[ 4.868277] 010: sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 4.868701] 010: NET: Registered protocol family 17
[ 4.868719] 010: NET: Registered protocol family 15
[ 4.868757] 010: Bridge firewalling registered
[ 4.868926] 010: 8021q: 802.1Q VLAN Support v1.8
[ 4.868941] 010: lib80211: common routines for IEEE802.11 drivers
[ 4.869042] 010: 9pnet: Installing 9P2000 support
[ 4.869064] 010: tsn generic netlink module v1 init...
[ 4.869109] 010: Key type dns_resolver registered
[ 4.869612] 011: registered taskstats version 1
[ 4.869614] 011: Loading compiled-in X.509 certificates
[ 4.870618] 011: Btrfs loaded, crc32c=crc32c-generic
[ 4.872076] 011: fsl_mc_dprc dprc.1: Adding to iommu group 0
[ 4.926528] 013: mmc1: new HS400 MMC card at address 0001
[ 4.926789] 011: fsl_dpaa2_eth dpni.1: Adding to iommu group 0
[ 4.926841] 011: fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 4.926901] 011: fsl_dpaa2_eth dpni.0: Adding to iommu group 0
[ 4.926926] 011: fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 4.926975] 011: fsl_mc_allocator dpbp.1: Adding to iommu group 0
[ 4.927024] 011: fsl_mc_allocator dpbp.0: Adding to iommu group 0
[ 4.927038] 013: mmcblk1: mmc1:0001 R1J59E 116 GiB
[ 4.927075] 011: dpaa2_mac dpmac.18: Adding to iommu group 0
[ 4.927089] 011: fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 4.927132] 011: dpaa2_mac dpmac.17: Adding to iommu group 0
[ 4.927151] 011: fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 4.927185] 013: mmcblk1boot0: mmc1:0001 R1J59E partition 1 8.00 MiB
[ 4.927197] 011: dpaa2_mac dpmac.6: Adding to iommu group 0
[ 4.927212] 011: fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 4.927255] 011: dpaa2_mac dpmac.5: Adding to iommu group 0
[ 4.927267] 011: fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 4.927307] 011: dpaa2_mac dpmac.4: Adding to iommu group 0
[ 4.927308] 013: mmcblk1boot1: mmc1:0001 R1J59E partition 2 8.00 MiB
[ 4.927345] 011: fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 4.927428] 011: dpaa2_mac dpmac.3: Adding to iommu group 0
[ 4.927441] 011: fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 4.927472] 013: mmcblk1rpmb: mmc1:0001 R1J59E partition 3 4.00 MiB, chardev (508:0)
[ 4.927492] 011: dpaa2_mac dpmac.2: Adding to iommu group 0
[ 4.927505] 011: fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 4.927547] 011: dpaa2_caam dpseci.0: Adding to iommu group 0
[ 4.927608] 011: fsl_mc_dprc dprc.1: No more resources of type dpmcp left
[ 4.954245] 011: fsl_mc_allocator dpmcp.35: Adding to iommu group 0
[ 4.955355] 011: fsl_mc_allocator dpmcp.34: Adding to iommu group 0
[ 4.956413] 011: fsl_mc_allocator dpmcp.33: Adding to iommu group 0
[ 4.957499] 011: fsl_mc_allocator dpmcp.32: Adding to iommu group 0
[ 4.958614] 011: fsl_mc_allocator dpmcp.31: Adding to iommu group 0
[ 4.959670] 011: fsl_mc_allocator dpmcp.30: Adding to iommu group 0
[ 4.960758] 011: fsl_mc_allocator dpmcp.29: Adding to iommu group 0
[ 4.961830] 011: fsl_mc_allocator dpmcp.28: Adding to iommu group 0
[ 4.962890] 011: fsl_mc_allocator dpmcp.27: Adding to iommu group 0
[ 4.963949] 011: fsl_mc_allocator dpmcp.26: Adding to iommu group 0
[ 4.965018] 011: fsl_mc_allocator dpmcp.25: Adding to iommu group 0
[ 4.966152] 011: fsl_mc_allocator dpmcp.24: Adding to iommu group 0
[ 4.967212] 011: fsl_mc_allocator dpmcp.23: Adding to iommu group 0
[ 4.968297] 011: fsl_mc_allocator dpmcp.22: Adding to iommu group 0
[ 4.969365] 011: fsl_mc_allocator dpmcp.21: Adding to iommu group 0
[ 4.970428] 011: fsl_mc_allocator dpmcp.20: Adding to iommu group 0
[ 4.971488] 011: fsl_mc_allocator dpmcp.19: Adding to iommu group 0
[ 4.972554] 011: fsl_mc_allocator dpmcp.18: Adding to iommu group 0
[ 4.973627] 011: fsl_mc_allocator dpmcp.17: Adding to iommu group 0
[ 4.974688] 011: fsl_mc_allocator dpmcp.16: Adding to iommu group 0
[ 4.975747] 011: fsl_mc_allocator dpmcp.15: Adding to iommu group 0
[ 4.976814] 011: fsl_mc_allocator dpmcp.14: Adding to iommu group 0
[ 4.977885] 011: fsl_mc_allocator dpmcp.13: Adding to iommu group 0
[ 4.978947] 011: fsl_mc_allocator dpmcp.12: Adding to iommu group 0
[ 4.980008] 011: fsl_mc_allocator dpmcp.11: Adding to iommu group 0
[ 4.981075] 011: fsl_mc_allocator dpmcp.10: Adding to iommu group 0
[ 4.982207] 011: fsl_mc_allocator dpmcp.9: Adding to iommu group 0
[ 4.983270] 011: fsl_mc_allocator dpmcp.8: Adding to iommu group 0
[ 4.984350] 011: fsl_mc_allocator dpmcp.7: Adding to iommu group 0
[ 4.985421] 011: fsl_mc_allocator dpmcp.6: Adding to iommu group 0
[ 4.986486] 011: fsl_mc_allocator dpmcp.5: Adding to iommu group 0
[ 4.987547] 011: fsl_mc_allocator dpmcp.4: Adding to iommu group 0
[ 4.988607] 011: fsl_mc_allocator dpmcp.3: Adding to iommu group 0
[ 4.990748] 011: fsl_mc_allocator dpmcp.2: Adding to iommu group 0
[ 4.991874] 011: fsl_mc_allocator dpmcp.1: Adding to iommu group 0
[ 4.991928] 011: fsl_dpaa2_ptp dprtc.0: Adding to iommu group 0
[ 4.994196] 011: ptp_qoriq: device tree node missing required elements, try automatic configuration
[ 4.994374] 011: pps pps0: new PPS source ptp0
[ 4.997530] 011: fsl_mc_dpio dpio.15: Adding to iommu group 0
[ 5.001265] 011: fsl_mc_dpio dpio.15: probed
[ 5.004887] 011: fsl_mc_dpio dpio.14: Adding to iommu group 0
[ 5.008599] 011: fsl_mc_dpio dpio.14: probed
[ 5.012251] 011: fsl_mc_dpio dpio.13: Adding to iommu group 0
[ 5.015971] 011: fsl_mc_dpio dpio.13: probed
[ 5.019632] 011: fsl_mc_dpio dpio.12: Adding to iommu group 0
[ 5.023361] 011: fsl_mc_dpio dpio.12: probed
[ 5.027017] 011: fsl_mc_dpio dpio.11: Adding to iommu group 0
[ 5.030749] 011: fsl_mc_dpio dpio.11: probed
[ 5.034392] 011: fsl_mc_dpio dpio.10: Adding to iommu group 0
[ 5.038104] 011: fsl_mc_dpio dpio.10: probed
[ 5.041761] 011: fsl_mc_dpio dpio.9: Adding to iommu group 0
[ 5.045486] 011: fsl_mc_dpio dpio.9: probed
[ 5.049125] 011: fsl_mc_dpio dpio.8: Adding to iommu group 0
[ 5.052836] 011: fsl_mc_dpio dpio.8: probed
[ 5.056485] 011: fsl_mc_dpio dpio.7: Adding to iommu group 0
[ 5.060190] 011: fsl_mc_dpio dpio.7: probed
[ 5.063462] 000: ata1: SATA link down (SStatus 0 SControl 300)
[ 5.063859] 011: fsl_mc_dpio dpio.6: Adding to iommu group 0
[ 5.067581] 011: fsl_mc_dpio dpio.6: probed
[ 5.071239] 011: fsl_mc_dpio dpio.5: Adding to iommu group 0
[ 5.073575] 000: ata2: SATA link down (SStatus 0 SControl 300)
[ 5.074946] 011: fsl_mc_dpio dpio.5: probed
[ 5.075555] 009: ata3: SATA link down (SStatus 0 SControl 300)
[ 5.078617] 011: fsl_mc_dpio dpio.4: Adding to iommu group 0
[ 5.082335] 011: fsl_mc_dpio dpio.4: probed
[ 5.083517] 009: ata4: SATA link down (SStatus 0 SControl 300)
[ 5.085998] 011: fsl_mc_dpio dpio.3: Adding to iommu group 0
[ 5.089741] 011: fsl_mc_dpio dpio.3: probed
[ 5.093198] 015: usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 5.093373] 011: fsl_mc_dpio dpio.2: Adding to iommu group 0
[ 5.097100] 011: fsl_mc_dpio dpio.2: probed
[ 5.100733] 011: fsl_mc_dpio dpio.1: Adding to iommu group 0
[ 5.104463] 011: fsl_mc_dpio dpio.1: probed
[ 5.108118] 011: fsl_mc_dpio dpio.0: Adding to iommu group 0
[ 5.111859] 011: fsl_mc_dpio dpio.0: probed
[ 5.112421] 011: fsl_mc_allocator dpcon.31: Adding to iommu group 0
[ 5.112480] 011: fsl_mc_allocator dpcon.30: Adding to iommu group 0
[ 5.112535] 011: fsl_mc_allocator dpcon.29: Adding to iommu group 0
[ 5.112592] 011: fsl_mc_allocator dpcon.28: Adding to iommu group 0
[ 5.112649] 011: fsl_mc_allocator dpcon.27: Adding to iommu group 0
[ 5.112703] 011: fsl_mc_allocator dpcon.26: Adding to iommu group 0
[ 5.112762] 011: fsl_mc_allocator dpcon.25: Adding to iommu group 0
[ 5.112819] 011: fsl_mc_allocator dpcon.24: Adding to iommu group 0
[ 5.112873] 011: fsl_mc_allocator dpcon.23: Adding to iommu group 0
[ 5.112931] 011: fsl_mc_allocator dpcon.22: Adding to iommu group 0
[ 5.112990] 011: fsl_mc_allocator dpcon.21: Adding to iommu group 0
[ 5.113045] 011: fsl_mc_allocator dpcon.20: Adding to iommu group 0
[ 5.113103] 011: fsl_mc_allocator dpcon.19: Adding to iommu group 0
[ 5.113173] 011: fsl_mc_allocator dpcon.18: Adding to iommu group 0
[ 5.113232] 011: fsl_mc_allocator dpcon.17: Adding to iommu group 0
[ 5.113290] 011: fsl_mc_allocator dpcon.16: Adding to iommu group 0
[ 5.113346] 011: fsl_mc_allocator dpcon.15: Adding to iommu group 0
[ 5.113404] 011: fsl_mc_allocator dpcon.14: Adding to iommu group 0
[ 5.113462] 011: fsl_mc_allocator dpcon.13: Adding to iommu group 0
[ 5.113520] 011: fsl_mc_allocator dpcon.12: Adding to iommu group 0
[ 5.113577] 011: fsl_mc_allocator dpcon.11: Adding to iommu group 0
[ 5.113638] 011: fsl_mc_allocator dpcon.10: Adding to iommu group 0
[ 5.113699] 011: fsl_mc_allocator dpcon.9: Adding to iommu group 0
[ 5.113756] 011: fsl_mc_allocator dpcon.8: Adding to iommu group 0
[ 5.113814] 011: fsl_mc_allocator dpcon.7: Adding to iommu group 0
[ 5.113875] 011: fsl_mc_allocator dpcon.6: Adding to iommu group 0
[ 5.113933] 011: fsl_mc_allocator dpcon.5: Adding to iommu group 0
[ 5.113992] 011: fsl_mc_allocator dpcon.4: Adding to iommu group 0
[ 5.114053] 011: fsl_mc_allocator dpcon.3: Adding to iommu group 0
[ 5.114110] 011: fsl_mc_allocator dpcon.2: Adding to iommu group 0
[ 5.114172] 011: fsl_mc_allocator dpcon.1: Adding to iommu group 0
[ 5.114232] 011: fsl_mc_allocator dpcon.0: Adding to iommu group 0
[ 5.117430] 011: fsl_mc_dprc dprc.1: DPRC device bound to driver
[ 5.266761] 011: fsl_dpaa2_eth dpni.1: Probed interface eth0
[ 5.382491] 015: usb-storage 1-1:1.0: USB Mass Storage device detected
[ 5.382880] 015: scsi host4: usb-storage 1-1:1.0
[ 5.414899] 011: fsl_dpaa2_eth dpni.0: Probed interface eth1
[ 5.419476] 011: dpaa2_mac dpmac.18: Connected to rgmii-id PHY.
[ 5.424014] 011: dpaa2_mac dpmac.17: Connected to rgmii-id PHY.
[ 5.428022] 011: dpaa2_mac dpmac.6: Registered fixed PHY.
[ 5.431988] 011: dpaa2_mac dpmac.5: Registered fixed PHY.
[ 5.462314] 011: dpaa2_mac dpmac.4: Connected to usxgmii PHY.
[ 5.494351] 011: dpaa2_mac dpmac.3: Connected to usxgmii PHY.
[ 5.498451] 011: dpaa2_mac dpmac.2: Registered fixed PHY.
[ 5.500148] 011: dpaa2_caam dpseci.0: dpseci v5.3
[ 5.523650] 011: fsl_mc_dprc dprc.1 (unnamed net_device) (uninitialized): netif_napi_add() called with weight 512
[ 5.547623] 011: dpaa2_caam dpseci.0: algorithms registered in /proc/crypto
[ 5.550018] 011: dpaa2_caam dpseci.0: hash algorithms registered in /proc/crypto
[ 5.552010] 011: rtc-pcf2127-i2c 1-0051: setting system clock to 2020-05-14T08:41:57 UTC (1589445717)
[ 5.552284] 011: ALSA device list:
[ 5.552290] 011: No soundcards found.
[ 5.582394] 011: Waiting for root device PARTUUID=019d98bb-04...
[ 6.407399] 015: scsi 4:0:0:0: Direct-Access 8.07 PQ: 0 ANSI: 4
[ 6.408983] 015: sd 4:0:0:0: [sda] 31457280 512-byte logical blocks: (16.1 GB/15.0 GiB)
[ 6.409753] 014: sd 4:0:0:0: [sda] Write Protect is off
[ 6.410515] 015: sd 4:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 7.198083] 015: sda: sda1 sda2 sda3 sda4
[ 7.202058] 015: sd 4:0:0:0: [sda] Attached SCSI removable disk
[ 8.756746] 000: random: fast init done
[ 21.029722] 011: EXT4-fs (sda4): recovery complete
[ 22.136558] 010: EXT4-fs (sda4): mounted filesystem with ordered data mode. Opts: (null)
[ 22.136623] 010: VFS: Mounted root (ext4 filesystem) on device 8:4.
[ 22.139408] 011: devtmpfs: mounted
[ 22.142798] 011: Freeing unused kernel memory: 5824K
[ 22.143056] 011: Run /sbin/init as init process
[ 22.508617] 000: random: crng init done
[ 22.685095] 010: systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hi)
[ 22.690784] 011: systemd[1]: Detected architecture arm64.
Welcome to NXP LSDK 2004 main!
[ 22.742182] 010: systemd[1]: Set hostname to <localhost>.
[ 23.130603] 010: systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 23.130614] 010: systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 23.210672] 011: systemd[1]: Configuration file /lib/systemd/system/weston.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 23.267764] 011: systemd[1]: Configuration file /lib/systemd/system/fmc.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ OK ] Started Dispatch Password Requests to Console[ 23.321704] 011: systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Directory Watch.
[ 23.347327] 011: systemd[1]: Created slice System Slice.
[ OK ] Listening on fsck to fsckd communication Sock[ 23.357462] 011: systemd[1]: Listening on fsck to fsckd communication Socket.
et.
[ 23.361346] 011: switch cluster 0 cpu-freq governor to schedutil
[ 23.393276] 011: switch cluster 1 cpu-freq governor to schedutil
[ 23.572981] 009: EXT4-fs (sda4): re-mounted. Opts: errors=remount-ro
Mounting Boot Partition...
[ 24.074620] 015: systemd-journald[697]: Received request to flush runtime journal from PID 1
[ 25.266125] 015: systemd-journald[697]: File /var/log/journal/88792e6c2f004b9cbb23929dea8bf36c/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 29.133483] 015: EXT4-fs (sda2): recovery complete
[ 29.140686] 015: EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ OK ] Mounted Boot Partition.
[ 29.515441] 015: pfe: module is from the staging directory, the quality is unknown, you have been warned.
NXP LSDK 2004 main
localhost login:
NXP LSDK 2004 main
localhost login:
NXP LSDK 2004 main
Password:
Last login: Thu May 14 08:42:23 UTC 2020 on tty7
Welcome to NXP LSDK 2004 main (GNU/Linux 5.4.3-rt1-00002-g7331d03169b1 aarch64)
root@localhost:~#
root@localhost:~#
root@localhost:~#
root@localhost:~# ifconfig eth1 192.168.201.202
^C
2 packets transmitted, 0 received, 100% packet loss, time 1012ms
root@localhost:~# ping 192.168.201.237
PING 192.168.201.237 (192.168.201.237) 56(84) bytes of data.
^C
--- 192.168.201.237 ping statistics ---
2 packets transmitted, 0 received, 100% packet loss, time 1027ms
5,839 次查看
zhanghonghui
I have reference the reply from:
https://community.nxp.com/thread/496739
but there's no effert in my case.
