ls1046adb firmware with yocto
ashutoshharry
Hi @yipingwang
can you please share steps to upload uboot and other binaries on nxp 1046ardb dev boards i downloaded
nxp-real-time-edge package and binaries names are below
rcw (folder)
nxp-image-real-time-edge-ls1046ardb.wic.bz2
nxp-image-real-time-edge-ls1046ardb.rootfs.tar.bz2
nxp-image-real-time-edge-ls1046ardb.manifest
Image-ls1046ardb.bin
fsl-ls1046a-rdb-usdpaa.dtb
fsl-ls1046a-rdb-sdk-jailhouse-with-dpaa.dtb
fsl-ls1046a-rdb-sdk-jailhouse.dtb
fsl-ls1046a-rdb-sdk.dtb
fsl-ls1046a-rdb.dtb
fsl_fman_ucode_ls1046_r1.0_108_4_9.bin
fsl_fman_ucode_ls1046_r1.0_106_4_18.bin
atf (folder)
ashutoshharry
final solutions
tftp 0xa0000000 bl2_qspi.pbl
sf erase 0x0 +$filesize && sf write 0xa0000000 0x0 $filesize
tftp 0xa0000000 fip_uboot.bin
sf erase 0x100000 +$filesize && sf write 0xa0000000 0x100000 $filesize
tftp 0xa0000000 fsl_fman_ucode.bin
sf erase 900000 +$filesize && sf write 0xa0000000 900000 $filesize
tftp 0xa0000000 fitImage_new.bin
sf erase 0x1000000 +$filesize
sf write 0xa0000000 0x1000000 $filesize
cpld reset altbank
ashutoshharry
hi @swati_gupta
can you please help in this case.
ashutoshharry
Hi @yipingwang
so finaly i landed on last question i have nxp real time edge software with me that i want to flash on ls1046ardb board, below are images please give steps or any supported document
 rcw (folder)
fsl-ls1046a-rdb.dtb
atf (folder)
ashutoshharry
hi @yipingwang
i am able to get SPL binaries can you please give me steps to flash below component from yocto into ls1046ardb board
1) uboot and SPL
    u-boot-spl.bin
    u-boot.bin
2) Image-ls1046ardb.bin (i think full image with roots and kernel)
ashutoshharry
final solutions
cpld reset altbank
