ls1021atwr boot issue
1,721件の閲覧回数
matt8156
I am trying to load a new OS image onto the LS1021ATWR development board and having a few problems.
I have downloaded and installed the QorIQ SDK V2.0-1703 including the "image" iso. I have built the core and minimal OS images and attempted to boot from the SDcard by loading the images to a ramdisk and booting from this. However i get a few errors once the filesystem is mounted which include:
Bad inittab entry at line 5
and
can't open /dev/si: No such file or directory
can't open /dev/~~: No such file or directory
can't open /dev/l0: No such file or directory
can't open /dev/l1: No such file or directory
can't open /dev/l2: No such file or directory
can't open /dev/l3: No such file or directory
can't open /dev/l4: No such file or directory
I have tried the same test using the pre-built images from the SDK Images iso and get the same errors.
I have also compared the inittab file to that pre-installed in the NOR flash on the development card and line 5 appears to be identical.
My uboot environment for testing against the pre-built images is
baudrate=115200
bootargs=‘root=/dev/ram0 rw rootdelay=5 ramdisk_size=40000000 console=ttyS0,115200’
bootcmd=mmcinfo;ext2load mmc 0:2 $loadaddr /boot/$bootfile;ext2load mmc 0:2 $fdtaddr /boot/$fdtfile;ext2load mmc 0:2 $fsaddr /$filesystemfile;bootm $loadaddr $fsaddr $fdtaddr
bootdelay=3
bootfile=uImage-ls1021atwr_image.bin
dnsip=10.192.130.201
eth1addr=00:04:9f:04:e1:f9
eth2addr=00:04:9f:04:e1:fa
ethact=eTSEC3
ethaddr=00:04:9f:04:e1:f8
ethprime=eTSEC3
fdt_high=0xffffffff
fdtaddr=8f000000
fdtcontroladdr=bef0ed34
fdtfile=uImage-ls1021a-twr_image.dtb
filesystemfile=fsl-image-core-ls1021atwr-20160514210716.rootfs.ext2.gz.u-boot
fsaddr=88000000
gatewayip=10.193.20.254
initrd_high=0xffffffff
ipaddr=10.193.20.191
loadaddr=83000000
netmask=255.255.255.0
scsidevs=0
serverip=10.192.208.233
stderr=serial
stdin=serial
stdout=serial
and i have attached a log of the boot sequence.
Any ideas?
Matt
Original Attachment has been moved to: boot.txt.zip
タグ(2)
5 返答(返信)
1,466件の閲覧回数
Pavel
Find u-boot image files in the following folder:
QorIQ-SDK-V2.0-20160527-yocto/build_ls1021atwr/tmp/deploy/images/ls1021atwr
Find the following file:
u-boot-sdcard-ifc-2016.09+fslgit-r0.bin
See the Section 4.4.4.7 of nXP SDK 2.0-1703 documentation:
http://www.nxp.com/docs/en/supporting-information/QORIQ-SDK-2.0-IC-REV0.pdf
Pavel Chubakov
1,466件の閲覧回数
matt8156
Thanks for your replies, I fixed my issue by reinstalling the QorIQ SDK and rebuilding the OS. Updating Uboot was not necessary.
This worked for both the LS1046ARDB and LS1021ATWR.
Matt
1,466件の閲覧回数
matt8156
OK, There do not seem to be any pre-built images for the ls1021atwr in the V2.0-1703 download.
I have built the images myself but which one should i use? the instructions you refer to do not define the file.
I would guess it is u-boot-nor.bin?
1,466件の閲覧回数
Pavel
Test your board using u-boot on SD card from the QorIQ SDK V2.0-1703.
Find the "Programming U-boot to SD card" in the Section 4.4.4.7 of NXP SDK 2.0-1703 documentation:
Pavel Chubakov
1,466件の閲覧回数
matt8156
It appears i'm having the same issue with the LS1046ARDB.
i get the same errors after the kernel starts up:
and
I can't get your pre-built images to work because you don't provide the rootfs which i need to load from the SDCard on this target
Any further suggestions?
Matt
