ls1021a standalone power reset control signals (JTAG related)
jiye
Contributor V
I have a standalone ls1021a and instead of using CPLD to do the board bring up I used atmega328p
Please refer to my below thread as well:
1021a board bring up replace CPLD with Atmega328P
I need help with this really important question regarding my current design:
(1) Do I have to include HRESET in my  design as I see from the AN4878:
(2) If (1) is the case What is the signalling sequence needed on the PORESET and HRESET lines of the LS1021A to properly bring it out of reset and enable it to detect the JTAG interface?
(3) Also this
By saying " to bring the processor out of reset" , under what conditions does the processor is out of reset
Tags (3)
ufedor
Only PORESET_B is essential during POR sequence - refer to the QorIQ LS1021A Reference Manual, 4.4.1 Power-on reset sequence.
HRESET_B is not needed for JTAG interface proper operation.
jiye
Contributor V
Could you take a look at the very last one of
https://community.nxp.com/message/1243669?commentID=1243669#comment-1243669
I just want to know does Hard coded RCW relates my failure.
Also when first time I establish the connection from JTAG to my device. Is Hard code RCW needed to establish the connection.
I try to compare my log between my device and the eva board ls1021atwr board.
I found the log from the ls1021atwr board as shown in the attachment but I am not sure if it has RCW related content in it
what does this log tell me ?
CCS Windows Release Build 479.0.0.181125-p0
verbose logging
CCSAPI connection #1 from DESKTOP-TPGTACL closed at Tue Dec 10 12:33:09 2019
CCSAPI connection #1 accepted from DESKTOP-TPGTACL at Tue Dec 10 12:34:07 2019
check_min_version(serverh=0,*version)
  api version: 00000004 00000006
get_connection_count(serverh=0,cc_index=0,*count)
  count:1
available_connections(serverh=0,*count,*cc)
  connections: {0,73,0xa9fe9118}
cc_version(serverh=0,cc_index=0,index=0,*version)
get_config_chain(serverh=0,cc=0)
config_server(config_reg=0,config_data=0x00002710)
config_chain(serverh=0,cc=0,count=3,*devlist,*generic)
  devlist: ls1020a,dap,sap2
write_register(coreh.{serverh=0,cc_index=0,chain_pos=0},index=0,size=4,*reg)
  reg: 0000009B
config_template(coreh.{serverh=0,cc_index=0,chain_pos=0},config_reg=4096,config_data=0x00000001)
reset_to_debug(serverh=0,cc=0)
  reg: 0000009B
write_register(coreh.{serverh=0,cc_index=0,chain_pos=0},index=4102,size=4,*reg)
  reg: F0025A00
write_register(coreh.{serverh=0,cc_index=0,chain_pos=0},index=4103,size=4,*reg)
  reg: 21046000
write_register(coreh.{serverh=0,cc_index=0,chain_pos=0},index=4104,size=4,*reg)
  reg: 00000000
write_register(coreh.{serverh=0,cc_index=0,chain_pos=0},index=4105,size=4,*reg)
  reg: 00000000
write_register(coreh.{serverh=0,cc_index=0,chain_pos=0},index=4106,size=4,*reg)
  reg: 00000000
write_register(coreh.{serverh=0,cc_index=0,chain_pos=0},index=4107,size=4,*reg)
  reg: 18000000
write_register(coreh.{serverh=0,cc_index=0,chain_pos=0},index=4108,size=4,*reg)
  reg: 00080000
write_register(coreh.{serverh=0,cc_index=0,chain_pos=0},index=4109,size=4,*reg)
  reg: 481B7340
write_register(coreh.{serverh=0,cc_index=0,chain_pos=0},index=4110,size=4,*reg)
  reg: 00000000
write_register(coreh.{serverh=0,cc_index=0,chain_pos=0},index=4111,size=4,*reg)
  reg: 00000000
core_run_mode(serverh=0,*mode)
read_register(coreh.{serverh=0,cc_index=0,chain_pos=9},index=12319,count=1,size=4,*reg)
  reg: 000001D3
read_register(coreh.{serverh=0,cc_index=0,chain_pos=9},index=4130,count=1,size=4,*reg)
  reg: 03086013
write_register(coreh.{serverh=0,cc_index=0,chain_pos=9},index=8510,size=4,*reg)
  reg: FFFFFFFF
write_register(coreh.{serverh=0,cc_index=0,chain_pos=9},index=8509,size=4,*reg)
  reg: 0000000F
write_register(coreh.{serverh=0,cc_index=0,chain_pos=9},index=8703,size=4,*reg)
  reg: 00000000
read_register(coreh.{serverh=0,cc_index=0,chain_pos=9},index=8703,count=1,size=4,*reg)
  reg: 00000000
  reg: 03086013
read_register(coreh.{serverh=0,cc_index=0,chain_pos=9},index=8509,count=1,size=4,*reg)
  reg: 0000000F
read_register(coreh.{serverh=0,cc_index=0,chain_pos=9},index=8510,count=1,size=4,*reg)
  reg: FFFFFFFF
  reg: 000001D3
  reg: 03086013
  reg: 00000000
  reg: 000001D3
  reg: 03086013
  reg: 03086013
  reg: 00000000
  reg: 000001D3
  reg: 03086013
  reg: 03086013
  reg: 000001D3
read_register(coreh.{serverh=0,cc_index=0,chain_pos=9},index=2031872,count=1,size=4,*reg)
  reg: 00C50878
read_memory(coreh.{serverh=0,cc_index=0,chain_pos=9},
  addr.{addr_hi=0x00000000,addr_lo=0x00000000,size=4,space=0},count=256,*data)
  data: 18F09FE5 18F09FE5 18F09FE5 18F09FE5
  data: C0170000 0C120000 50120000 94120000
  data: D8120000 1C130000 60130000 A4130000
  data: 68392781 3031300D 06096086 48016503
  data: 04020105 00042000 61626300 BA7816BF
  data: 8F01CFEA 414140DE 5DAE2223 B00361A3
  data: 96177A9C B410FF61 F20015AD 61626364
  data: 62636465 63646566 64656667 65666768
  data: 66676869 6768696A 68696A6B 696A6B6C
  data: 6A6B6C6D 6B6C6D6E 6C6D6E6F 6D6E6F70
  data: 6E6F7071 248D6A61 D20638B8 E5C02693
  data: 0C3E6039 A33CE459 64FF2167 F6ECEDD4
  data: 19DB06C1 0B7027FC BB0726BE 207FF02D
  data: 1A7FBAF2 7FACC734 37569C94 31673B3C
  data: 1D8CCC06 45FEFC59 BC9687D4 C594C169
write_register(coreh.{serverh=0,cc_index=0,chain_pos=9},index=2031872,size=4,*reg)
  reg: 00050078
  reg: 00C50878
  reg: 03086013
  reg: 0000000F
  reg: FFFFFFFF
  reg: 000001D3
  reg: FFFFFFFF
  reg: FFFFFFFF
  reg: FFFFFFFF
  reg: 0000000F
  reg: 0000000F
  reg: 0000000F
write_register(coreh.{serverh=0,cc_index=0,chain_pos=9},index=2031890,size=4,*reg)
  reg: 00000C00
read_register(coreh.{serverh=0,cc_index=0,chain_pos=9},index=2031890,count=1,size=4,*reg)
  reg: 00000C00
write_register(coreh.{serverh=0,cc_index=0,chain_pos=9},index=2031874,size=4,*reg)
  reg: 0FFFFFFF
read_register(coreh.{serverh=0,cc_index=0,chain_pos=9},index=2031874,count=1,size=4,*reg)
  reg: 00F00000
write_register(coreh.{serverh=0,cc_index=0,chain_pos=9},index=1734656,size=4,*reg)
  reg: 40000000
read_register(coreh.{serverh=0,cc_index=0,chain_pos=9},index=1734656,count=1,size=4,*reg)
  reg: 40000000
write_register(coreh.{serverh=0,cc_index=0,chain_pos=15},index=192,size=4,*reg)
  reg: 00000000
read_register(coreh.{serverh=0,cc_index=0,chain_pos=15},index=192,count=1,size=4,*reg)
  reg: 00000000
write_memory(coreh.{serverh=0,cc_index=0,chain_pos=9},
  addr.{addr_hi=0x00000000,addr_lo=0x01185000,size=4,space=1},count=4,*data)
  data: 00000003
  addr.{addr_hi=0x00000000,addr_lo=0x01EE00A4,size=4,space=1},count=4,*data)
  data: 87081120
  addr.{addr_hi=0x00000000,addr_lo=0x02100000,size=4,space=1},count=4,*data)
  data: 00000001
  addr.{addr_hi=0x00000000,addr_lo=0x02110000,size=4,space=1},count=4,*data)
  data: 00000001
  reg: 00C50878
  addr.{addr_hi=0x00000000,addr_lo=0x01550000,size=4,space=0},count=4,*data)
  data: 000F4000
  addr.{addr_hi=0x00000000,addr_lo=0x01550108,size=4,space=0},count=4,*data)
  data: 00000000
  data: 000F0000
  addr.{addr_hi=0x00000000,addr_lo=0x01550180,size=4,space=0},count=4,*data)
  data: 41000000
  addr.{addr_hi=0x00000000,addr_lo=0x01550184,size=4,space=0},count=4,*data)
  data: 41000000
  addr.{addr_hi=0x00000000,addr_lo=0x01550188,size=4,space=0},count=4,*data)
  data: 42000000
  addr.{addr_hi=0x00000000,addr_lo=0x0155018C,size=4,space=0},count=4,*data)
  data: 42000000
  addr.{addr_hi=0x00000000,addr_lo=0x01550020,size=4,space=0},count=4,*data)
  data: 00000000
  addr.{addr_hi=0x00000000,addr_lo=0x01570200,size=4,space=1},count=4,*data)
  data: 00000000
  addr.{addr_hi=0x00000000,addr_lo=0x0157015C,size=4,space=0},count=4,*data)
  data: 00000803
  addr.{addr_hi=0x00000000,addr_lo=0x01530018,size=4,space=0},count=4,*data)
  data: 00000000
  addr.{addr_hi=0x00000000,addr_lo=0x0153001C,size=4,space=0},count=4,*data)
  data: 7FB00085
  addr.{addr_hi=0x00000000,addr_lo=0x015300AC,size=4,space=0},count=4,*data)
  data: FFFF0000
  addr.{addr_hi=0x00000000,addr_lo=0x0153013C,size=4,space=0},count=4,*data)
  data: 0000800C
  addr.{addr_hi=0x00000000,addr_lo=0x015301F0,size=4,space=0},count=4,*data)
  data: F00F000F
  addr.{addr_hi=0x00000000,addr_lo=0x015301F4,size=4,space=0},count=4,*data)
  data: FF003F00
  addr.{addr_hi=0x00000000,addr_lo=0x015301F8,size=4,space=0},count=4,*data)
  data: 0F3C00FF
  addr.{addr_hi=0x00000000,addr_lo=0x015301FC,size=4,space=0},count=4,*data)
  data: 00000000
  addr.{addr_hi=0x00000000,addr_lo=0x0153000C,size=4,space=0},count=4,*data)
  data: 00000000
  addr.{addr_hi=0x00000000,addr_lo=0x01530010,size=4,space=0},count=4,*data)
  data: 60000101
  addr.{addr_hi=0x00000000,addr_lo=0x015300A0,size=4,space=0},count=4,*data)
  data: F8000000
  addr.{addr_hi=0x00000000,addr_lo=0x01530130,size=4,space=0},count=4,*data)
  data: 0000800C
  addr.{addr_hi=0x00000000,addr_lo=0x015301C0,size=4,space=0},count=4,*data)
  data: 40050005
  addr.{addr_hi=0x00000000,addr_lo=0x015301C4,size=4,space=0},count=4,*data)
  data: 35001A13
  addr.{addr_hi=0x00000000,addr_lo=0x015301C8,size=4,space=0},count=4,*data)
  data: 0410381C
  addr.{addr_hi=0x00000000,addr_lo=0x015301CC,size=4,space=0},count=4,*data)
  data: 00000000
  addr.{addr_hi=0x00000000,addr_lo=0x10000000,size=4,space=0},count=32768,*data)
  data: 04000000 14000000 03000000 474E5500
  data: 8CB710F9 E7ADD3B2 671A7CF9 F955BD69
  data: 9B6DE210 00000000 00000000 00000000
  data: 00000000 00000000 00000000 00000000
  data: 00482DE9 04B08DE2 08D04DE2 08000BE5
  data: 08301BE5 000053E3 010000CA 0030A0E3
  data: 060000EA 08301BE5 013043E2 0300A0E1
  data: F2FFFFEB 0020A0E1 08301BE5 033082E0
  data: 0300A0E1 04D04BE2 0088BDE8 00482DE9
  data: 04B08DE2 10D04DE2 10000BE5 0030A0E3
  data: 08300BE5 10301BE5 013003E2 000053E3
  data: 0200000A 0130A0E3 08300BE5 0C0000EA
  data: 10301BE5 672606E3 662646E3 9302C1E0
  data: C111A0E1 C32FA0E1 012062E0 1410A0E3
  data: 910202E0 032062E0 0200A0E1 D3FFFFEB
  data: 08000BE5 08301BE5 0300A0E1 04D04BE2
  data: 0088BDE8 00482DE9 04B08DE2 08D04DE2
  data: 0030A0E3 08300BE5 08001BE5 DAFFFFEB
  data: 08301BE5 013083E2 08300BE5 F9FFFFEA
  data: CA0000EB 1600B0E3 471F8FE2 563412EF
  data: 14019FE5 001090E5 000051E3 0100001A
  data: 20119FE5 001080E5 081090E5 0C2090E5
  data: 000051E3 0000000A 01D0A0E1 000052E3
  data: 0000000A 01AC82E2 0010B0E3 01B0A0E1
  data: 0170A0E1 D4009FE5 D4209FE5 002052E0
  data: B50000EB 1B0100EB 1500B0E3 CC108FE2
  data: 563412EF C4109FE5 0000B0E3 01002DE9
  data: 0130D1E4 000053E3 1100000A 200053E3
  data: FAFFFF0A 220053E3 27005313 0320A001
  data: 2020A013 01104112 02002DE9 010090E2
  data: 0130D1E4 000053E3 0500000A 030052E1
  data: FAFFFF1A 0020B0E3 013051E2 0020C3E5
  data: EAFFFFEA 0D10A0E1 00218DE0 0D30A0E1
  data: 030052E1 04401285 00509385 04502285
  data: 04408384 F9FFFF8A 07D0CDE3 0040B0E1
  data: 0150B0E1 2C009FE5 000050E3 0100000A
  data: 24009FE5 00F020E3 00F020E3 0400B0E1
  data: 0510B0E1 AAFFFFEB 00F020E3 08250010
  data: 00800010 E8800010 00000000 00000000
  data: 18250010 FF000000 E8800010 00000000
  data: 0EC0A0E1 110000EB 1C0000EB 230000EB
  data: 0000A0E3 170F08EE D50F07EE 100F13EE
  data: 0000E0E3 100F03EE 100F11EE 0102C0E3
  data: 100F01EE 1E0000EB 490000EB 3D0000EB
  data: 4D0000EB 240000EB 3F0000EB 1CFF2FE1
  data: 0E80A0E1 304F11EE 404084E3 304F01EE
  data: 6FF07FF5 18FF2FE1 0E80A0E1 304F11EE
  data: 4040C4E3 304F01EE 6FF07FF5 18FF2FE1
  data: 0E80A0E1 100F11EE 010AC0E3 0400C0E3
  data: 0100C0E3 020BC0E3 100F01EE 18FF2FE1
  data: 0E80A0E1 100F11EE 0200C0E3 100F01EE
  data: 18FF2FE1 0E80A0E1 0040A0E3 504F02EE
  data: 434F8FE2 004094E5 014084E2 084084E3
  data: 404084E3 104F02EE 18FF2FE1 0E80A0E1
  data: 100F11EE 010080E3 100F01EE 18FF2FE1
  data: 0E80A0E1 300F1FEE 100080E3 300F0FEE
  data: 300F1FEE 010A80E3 010580E3 300F0FEE
  data: 300F1FEE 400080E3 300F0FEE 300F1FEE
  data: 020B80E3 300F0FEE 300F1FEE 020680E3
  data: 300F0FEE 18FF2FE1 0E80A0E1 100F11EE
  data: 010A80E3 100F01EE 18FF2FE1 0E80A0E1
  data: 100F11EE 040080E3 020B80E3 100F01EE
  data: 18FF2FE1 0E80A0E1 300F30EE 030010E3
  data: 0000A0E3 150F071E 18FF2FE1 0E80A0E1
  data: 100F50EE 0010A0E3 010000E0 100F50EE
  data: 100F30EE 3C309FE5 A00603E0 0010A0E3
  data: 0030A0E3 012FA0E1 832282E1 562F07EE
  data: 013083E2 030050E1 F9FFFFCA 011081E2
  data: 040051E3 F5FFFF1A 0000A0E3 D50F07EE
  data: 18FF2FE1 00400010 FF010000 00F020E3
  data: 0EB0A0E1 85FFFFEB 1BFF2FE1 030010E3
  data: 10402DE9 3700000A 000052E3 012042E2
  data: 1080BD08 71E0EFE6 0030A0E1 020000EA
  data: 000052E3 0C20A0E1 1080BD08 01E0C3E4
  data: 030013E3 01C042E2 F8FFFF1A 030052E3
  data: 2000009A 71E0EFE6 0F0052E3 0EE48EE1
  data: 0EE88EE1 1000009A 10C083E2 0240A0E1
  data: 104044E2 10E00CE5 0F0054E3 0CE00CE5
  data: 08E00CE5 10C08CE2 14E00CE5 F7FFFF8A
  data: 10C042E2 0F2002E2 0FC0CCE3 030052E3
  data: 10C08CE2 0C3083E0 0A00009A 0340A0E1
  data: 02C0A0E1 04C04CE2 04E084E4 03005CE3
  data: FBFFFF8A 04C042E2 032002E2 03C0CCE3
  data: 04C08CE2 0C3083E0 000052E3 1080BD08
  data: 7110EFE6 022083E0 0110C3E4 020053E1
  data: FCFFFF1A 1080BDE8 0030A0E1 D2FFFFEA
  data: 183602E3 10402DE9 003041E3 0040A0E1
  data: 000093E5 000050E3 0200000A 383090E5
  data: 000053E3 0D00000A 000054E3 0700000A
  datacore_run_mode(serverh=0,*mode)
  reg: 10000130
  reg: 10000130
  addr.{addr_hi=0x00000000,addr_lo=0x10000100,size=4,space=0},count=256,*data)
write_register(coreh.{serverh=0,cc_index=0,chain_pos=9},index=4103,size=4,*reg)
  reg: 04000004
  addr.{addr_hi=0x00000000,addr_lo=0x10000104,size=4,space=0},count=4,*data)
  data: 00482DE9
  data: 700020E1
  data: 700020E1
run_core(coreh.{serverh=0,cc_index=0,chain_pos=9})
  reg: 10000130
  reg: 000001D3
  reg: 03084017
  reg: 03084017
  reg: 03086017
  reg: 00000008
  reg: 200001D3
  reg: 03086017
  reg: 03086017
  reg: 200001D3
  reg: 00C5187D
read_register(coreh.{serverh=0,cc_index=0,chain_pos=9},index=2032130,count=1,size=4,*reg)
  reg: 00000000
read_register(coreh.{serverh=0,cc_index=0,chain_pos=9},index=2032128,count=1,size=4,*reg)
  reg: 10004049
  addr.{addr_hi=0x00000000,addr_lo=0x10004000,size=4,space=1},count=4,*data)
  data: 0E1C0100
  data: 0E1C0100
  reg: 00C5187D
read_register(coreh.{serverh=0,cc_index=0,chain_pos=9},index=2034688,count=1,size=4,*reg)
  reg: 00000000
read_register(coreh.{serverh=0,cc_index=0,chain_pos=9},index=8688,count=1,size=4,*reg)
  reg: 00000016
read_register(coreh.{serverh=0,cc_index=0,chain_pos=9},index=8689,count=1,size=4,*reg)
  reg: 1000025C
  reg: 10000140
  reg: 200001D3
read_register(coreh.{serverh=0,cc_index=0,chain_pos=9},index=12307,count=1,size=4,*reg)
  reg: 200001D3
  addr.{addr_hi=0x00000000,addr_lo=0x10004400,size=4,space=1},count=4,*data)
  data: 0E1C0110
  data: 0E1C0110
  data: 0088BDE8 700020E1 04B08DE2 08D04DE2
  addr.{addr_hi=0x00000000,addr_lo=0x1000025C,size=4,space=0},count=4,*data)
  data: 08250010
  addr.{addr_hi=0x00000000,addr_lo=0x10002508,size=4,space=0},count=16,*data)
  data: E8800010 E8800010 F0FF0110 E8800010
write_register(coreh.{serverh=0,cc_index=0,chain_pos=9},index=12319,size=4,*reg)
  reg: 200001D3
  reg: 10000140
  reg: 03086017
  reg: 00000008
  reg: 600001D3
  reg: 03086017
  reg: 03086017
  reg: 00000008
  reg: 600001D3
  reg: 03086017
  reg: 03086017
  reg: 600001D3
  reg: 00C5187D
  reg: 00000000
  reg: 10004049
  data: 0E1C0100
  data: 0E1C0100
  reg: 00C5187D
  reg: 00000000
  reg: 00000001
  reg: 1001FFC4
  reg: 10000640
  reg: 600001D3
  reg: 600001D3
  data: 0E1C0110
  data: 0E1C0110
  addr.{addr_hi=0x00000000,addr_lo=0x10000600,size=4,space=0},count=256,*data)
  data: 004085E5 7080BDE8 F0472DE9 F86402E3
  data: 10D04DE2 0390A0E3 006041E3 0040A0E3
  data: 04608DE5 0150A0E3 0C908DE5 04808DE2
  data: 08408DE5 0500A0E1 0810A0E1 563412EF
  data: 00A0A0E1 007008E3 0430A0E3 007041E3
  data: 04608DE5 00A087E5 0C908DE5 08308DE5
  data: 0500A0E1 0810A0E1 563412EF 0050A0E1
  data: 0000E0E3 0430A0E1 0C1087E2 085087E5
  data: 045087E5 830181E7 013083E2 140053E3
  data: 002008E3 002041E3 F9FFFF1A 001092E5
  data: 0030A0E3 145082E5 103082E5 0C1082E5
  data: 183082E5 10D08DE2 F087BDE8 70402DE9
  data: 0140A0E1 0260A0E1 10D04DE2 A3FFFFEB
  data: 08408DE5 04508DE2 0640A0E3 04008DE5
  data: 0C608DE5 0400A0E1 0510A0E1 563412EF
  data: 0040A0E1 0400A0E1 10D08DE2 7080BDE8
  addr.{addr_hi=0x00000000,addr_lo=0x1001FFC4,size=4,space=0},count=12,*data)
  data: F8240010 00000000 03000000
  addr.{addr_hi=0x00000000,addr_lo=0x100024F8,size=1,space=0},count=3,*data)
  data: 3A 74 74
write_register(coreh.{serverh=0,cc_index=0,chain_pos=9},index=8688,size=4,*reg)
  reg: 00000000
  reg: 600001D3
  reg: 10000640
  reg: 03086017
  reg: 00000008
  reg: 600001D3
  reg: 03086017
  reg: 03086017
  reg: 00000008
  reg: 600001D3
  reg: 03086017
  reg: 03086017
  reg: 600001D3
  reg: 00C5187D
  reg: 00000000
  reg: 10004049
  data: 0E1C0100
  data: 0E1C0100
  reg: 00C5187D
  reg: 00000000
  reg: 00000001
  reg: 1001FFC4
  reg: 1000066C
  reg: 600001D3
  reg: 600001D3
  data: 0E1C0110
  data: 0E1C0110
  data: F8240010 04000000 03000000
  data: 3A 74 74
  reg: 00000001
  reg: 600001D3
  reg: 1000066C
  reg: 03086017
  reg: 00000008
  reg: 200001D3
  reg: 03086017
  reg: 03086017
  reg: 00000008
  reg: 200001D3
  reg: 03086017
  reg: 03086017
  reg: 200001D3
  reg: 00C5187D
  reg: 00000000
  reg: 10004049
  data: 0E1C0100
  data: 0E1C0100
  reg: 00C5187D
  reg: 00000000
  reg: 00000015
  reg: 10000270
  reg: 100001A4
  reg: 200001D3
  reg: 200001D3
  data: 0E1C0110
  data: 0E1C0110
  addr.{addr_hi=0x00000000,addr_lo=0x10000270,size=4,space=0},count=8,*data)
  addr.{addr_hi=0x00000000,addr_lo=0x10002518,size=1,space=0},count=65,*data)
  data: 44 3A 5C 43 6F 64 65 57 61 72 72 69 6F 72 57 6F
  data: 72 6B 50 6C 61 63 65 5C 42 6F 6F 74 31 31 32 39
  data: 2D 63 6F 72 65 30 5C 4F 43 52 41 4D 5C 42 6F 6F
  data: 74 31 31 32 39 2D 63 6F 72 65 30 2E 65 6C 66 20
  data: 00
  addr.{addr_hi=0x00000000,addr_lo=0x10000274,size=4,space=0},count=4,*data)
  data: 41000000
  reg: 00000000
  reg: 200001D3
  reg: 100001A4
  reg: 0308600F
  reg: 10000104
  reg: 200001D3
  reg: 0308600F
  reg: 0308600F
  reg: 10000104
  reg: 200001D3
  reg: 0308600F
  reg: 0308600F
  reg: 200001D3
  reg: 00C5187D
  reg: 00000000
  reg: 10004049
  data: 0E1C0110
  data: 0E1C0110
  reg: 00C5187D
  reg: 00000000
  reg: 1001FFE8
  reg: 10000258
  reg: 200001D3
  data: 00482DE9
  data: 00482DE9
  addr.{addr_hi=0x00000000,addr_lo=0x10000200,size=4,space=0},count=256,*data)
  data: 18250010 41000000 E8800010 00000000
  addr.{addr_hi=0x00000000,addr_lo=0x1001FF00,size=4,space=0},count=256,*data)
  data: 6C8708CB 11CB7413 B09A23CE 519E8D88
  data: E2A974CC 0CD8C749 40CA9319 D2938063
  data: 9C148690 4393500C E2A451EA 00840034
  data: DDA4D4EE 1EE3B843 F879DF95 C6921DCD
  data: 5E45D90F 487F478A 12B83710 A307526E
  data: 611C1204 E4C66CC9 458F0153 62C115C8
  data: A83DAF7A 96E2EBE8 82E2C2EB A2B59098
  data: 14A2565A 83D365D1 9C1836B9 EA04609C
  data: BBBD33C2 DFF45123 DDF271F8 0B147D46
  data: EEA70A88 49CC09E7 E27018F6 ABFAF9AD
  data: 259315C3 85692321 5150858B 41C5E690
  data: 65083955 7FB04426 6E6DBFA9 DA293722
  data: 49672787 F8240010 04000000 03000000
  data: 49400010 CC6400C1 146500C1 00000000
  data: CC020010 946400C1 18250010 00000000
  data: 1AA5F6BE D3A32486 D972A52C 1A107CCA
