how to rebuild lx2160a uboot independently
1,563件の閲覧回数
156614400
when I change the uboot code,   I change  the  flexbuild_lsdk2004_update_290520\packages\firmware\u-boot\board\freescale\lx2160a\eth_lx2160ardb.c,  and other code files,   add some printf info,    how to rebuild lx2160a uboot  independently ???
1  this only rebuild atf,   can not rebuild the uboot  code   (\packages\firmware\u-boot\   )
flex-builder -c atf -m lx2160ardb_rev2 -b sd (build uboot-based ATF image for sd boot)
flex-builder -i mkfw -m lx2160ardb_rev2 -b sd
2  below CMD  also can not rebuild the uboot code,
flex-builder -c uboot -m lx2160ardb_rev2 -b sd
flex-builder -c u-boot -m lx2160ardb_rev2 -b sd
thanks
1,539件の閲覧回数
yipingwang
Please remove folder "build/firmware/u-boot/lx2160ardb/output/", then run flex-builder command.
