how to config the DPAA's default share-mac to dpdk/user mode?
1,138 次查看
pakydu
I used the ls1043a-qds soc, and lsdk21.08 to build my gateway produce. I want to use share-mac and vsp to config the network:
1. just ptp package will be used linux kernel network stack(special rule.).
2. other package will be used dpdk/user space(default rule).
I still can't config dts and policy xml to meet my function. I refer to the NXP document which are default rule for linux kernel network statck, and special rule for dpdk. But we want the special rule(ptp packerage) for linux kernel network stack, the default rule is dpdk.
Can someone gave me suggestion? I attached my dts and policy xml.
Thanks.
3 回复数
357 次查看
tdelgrande
Hello @pakydu,
Do you mind sharing the solution?
Thanks!
1,098 次查看
LFGP
dear @pakydu ,
please go to the next link
https://community.nxp.com/t5/P-Series-Knowledge-Base/Shared-MAC-and-MAC-less-Implementation-in-DPAA-...
to get an example about your doubt
1,082 次查看
pakydu
Thanks for your replay. I had fixed it by local FAE's help.
