cfg_dram_type value used in LS1043ARDB-PD reference board
Search instead for
Abhilash_PV
What is the cfg_dram_type value used in LS1043ARDB-PD reference board? I could not see any assignment to cfg_dram_type in the CPLD code. Otherwise where is it in the source code defined to specify the DDR type?
ufedor
cfg_dram_type is not controlled by the CPLD - refer to the LS1043ARDB schematics, Sheet 4, R376.
ufedor
Abhilash_PV
Thank you for the quick response.
