Which Hardware to set up a TSN Demonstrator
groenvit
I want to set up a TSN demonstrator.
In the NXP demos mostly the LS1028A is used.
I am now a bit confused regarding the board designation.
Is the LS1028A-TSN or LS1028A-RDB used in that case?
Where are the differences? I can't see LS1028A-TSN anywhere as a product, only in the documentation.
From my research the best way would be the LS1028A-RDB board with OpenIL, are there any other recommendations (e.g. LS1021-TSN) different from this for building a demonstrator?
Thanks in advance
