The U-Boot does not start on the custom board using the LS1046A
1,091 次查看
Johnson_s
I am currently checking the boot process on a custom board using the LS1046A. After creating the PBL and U-Boot and writing them to the QSPI, the following log is output, and then nothing further is displayed:
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0x82000000
INFO: SPSR = 0x3c9
Since I have the LS1046ARDB on hand, I suspect that the hang is due to differences in hardware configuration. On the custom board, USB, SATA, and PCIe are not used, so they are not connected.
Are there any areas in the repository at https://github.com/nxp-qoriq/atf/tree/lf_v2.6 that might affect the operation? (DDR is functioning without any issues.)
1,001 次查看
yipingwang
Please comment “erratum_a009007()” in arch/arm/cpu/armv8/fsl-layerscape/soc.c in u-boot source code.
If it doesn't help, please debug BL31 and u-boot with CodeWarrior for ARMv8.
Probably the "Inspect(attaching to the running target)" will help the customer. Please refer to the Inspect icon marked red in attached file inspect.png. After click this icon, CodeWarrior will attach to the target board, not affect the software running on the target board.
Then the disassembly code which the target board is executing will be captured and displayed in CodeWarrior IDE, please refer to the attached file disassemble.png.
Then refer to the following document to debug BL31 and u-boot.
https://community.nxp.com/t5/Layerscape-Knowledge-Base/Debugging-ATF-and-u-boot-with-CodeWarrior-for...
1,002 次查看
yipingwang
%3CLINGO-SUB%20id%3D%22lingo-sub-2075706%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%20LS1046A%20%E7%9A%84%E5%AE%9A%E5%88%B6%E6%9D%BF%E4%B8%8A%E7%9A%84%20U-Boot%20%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2075706%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E7%9B%AE%E5%89%8D%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20LS1046A%20%E6%A3%80%E6%9F%A5%E5%AE%9A%E5%88%B6%E6%9D%BF%E4%B8%8A%E7%9A%84%E5%90%AF%E5%8A%A8%E8%BF%87%E7%A8%8B%E3%80%82%E5%88%9B%E5%BB%BAPBL%E5%92%8CU-Boot%E5%B9%B6%E5%86%99%E5%85%A5QSPI%E5%90%8E%EF%BC%8C%E8%BE%93%E5%87%BA%E5%A6%82%E4%B8%8B%E6%97%A5%E5%BF%97%EF%BC%8C%E4%B9%8B%E5%90%8E%E4%BE%BF%E6%97%A0%E4%BB%BB%E4%BD%95%E6%98%BE%E7%A4%BA%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E4%BF%A1%E6%81%AF%EF%BC%9ABL31%EF%BC%9A%E5%87%86%E5%A4%87%E4%BB%8E%20EL3%20%E9%80%80%E5%87%BA%E5%88%B0%E6%AD%A3%E5%B8%B8%E4%B8%96%E7%95%8C%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E4%BF%A1%E6%81%AF%EF%BC%9A%E5%85%A5%E5%8F%A3%E7%82%B9%E5%9C%B0%E5%9D%80%20%3D%200x82000000%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%E4%BF%A1%E6%81%AF%EF%BC%9ASPSR%20%3D%200x3c9%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%94%B1%E4%BA%8E%E6%88%91%E6%89%8B%E5%A4%B4%E6%9C%89%20LS1046ARDB%EF%BC%8C%E6%88%91%E6%80%80%E7%96%91%E6%8C%82%E8%B5%B7%E6%98%AF%E7%94%B1%E4%BA%8E%E7%A1%AC%E4%BB%B6%E9%85%8D%E7%BD%AE%E7%9A%84%E5%B7%AE%E5%BC%82%E9%80%A0%E6%88%90%E7%9A%84%E3%80%82%E5%9C%A8%E5%AE%9A%E5%88%B6%E6%9D%BF%E4%B8%8A%EF%BC%8CUSB%E3%80%81SATA%E3%80%81PCIe%E9%83%BD%E6%B2%A1%E6%9C%89%E7%94%A8%E5%88%B0%EF%BC%8C%E6%89%80%E4%BB%A5%E6%B2%A1%E6%9C%89%E8%BF%9E%E6%8E%A5%E3%80%82%3C%2FP%3E%3CP%3E%E5%AD%98%E5%82%A8%E5%BA%93%E4%B8%AD%E6%98%AF%E5%90%A6%E6%9C%89%E4%BB%BB%E4%BD%95%E5%8C%BA%E5%9F%9F%E4%BD%8D%E4%BA%8E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-qoriq%2Fatf%2Ftree%2Flf_v2.6%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-qoriq%2Fatf%2Ftree%2Flf_v2.6%3C%2FA%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E8%BF%99%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%BD%B1%E5%93%8D%E6%93%8D%E4%BD%9C%E5%90%97%EF%BC%9F%EF%BC%88DDR%20%E8%BF%90%E8%A1%8C%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E9%97%AE%E9%A2%98%E3%80%82%EF%BC%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2078975%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AU-Boot%20%E6%97%A0%E6%B3%95%E5%9C%A8%E4%BD%BF%E7%94%A8%20LS1046A%20%E7%9A%84%E5%AE%9A%E5%88%B6%E6%9D%BF%E4%B8%8A%E5%90%AF%E5%8A%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2078975%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AF%B7%E5%9C%A8%20u-boot%20%E6%BA%90%E4%BB%A3%E7%A0%81%E4%B8%AD%E7%9A%84%20arch%2Farm%2Fcpu%2Farmv8%2Ffsl-layerscape%2Fsoc.c%20%E4%B8%AD%E6%B3%A8%E9%87%8A%E2%80%9Cerratum_a009007()%E2%80%9D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%B2%A1%E6%9C%89%E5%B8%AE%E5%8A%A9%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%20CodeWarrior%20for%20ARMv8%20%E8%B0%83%E8%AF%95%20BL31%20%E5%92%8C%20u-boot%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%8F%AF%E8%83%BD%E2%80%9C%E6%A3%80%E6%9F%A5%EF%BC%88%E9%99%84%E5%8A%A0%E5%88%B0%E8%BF%90%E8%A1%8C%E7%9B%AE%E6%A0%87%EF%BC%89%E2%80%9D%E4%BC%9A%E5%AF%B9%E5%AE%A2%E6%88%B7%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%82%E8%AF%B7%E5%8F%82%E9%98%85%E9%99%84%E4%BB%B6%20inspect.png%20%E4%B8%AD%E6%A0%87%E8%AE%B0%E4%B8%BA%E7%BA%A2%E8%89%B2%E7%9A%84%E6%A3%80%E6%9F%A5%E5%9B%BE%E6%A0%87%E3%80%82%E7%82%B9%E5%87%BB%E8%AF%A5%E5%9B%BE%E6%A0%87%E5%90%8E%EF%BC%8CCodeWarrior%E5%B0%86%E4%BC%9A%E9%99%84%E5%8A%A0%E5%88%B0%E7%9B%AE%E6%A0%87%E6%9D%BF%E4%B8%8A%EF%BC%8C%E4%B8%8D%E4%BC%9A%E5%BD%B1%E5%93%8D%E7%9B%AE%E6%A0%87%E6%9D%BF%E4%B8%8A%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%E7%9A%84%E8%BD%AF%E4%BB%B6%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%84%B6%E5%90%8E%E7%9B%AE%E6%A0%87%E6%9D%BF%E6%AD%A3%E5%9C%A8%E6%89%A7%E8%A1%8C%E7%9A%84%E5%8F%8D%E6%B1%87%E7%BC%96%E4%BB%A3%E7%A0%81%E5%B0%86%E8%A2%AB%E6%8D%95%E8%8E%B7%E5%B9%B6%E6%98%BE%E7%A4%BA%E5%9C%A8CodeWarrior%20IDE%E4%B8%AD%EF%BC%8C%E8%AF%B7%E5%8F%82%E8%80%83%E9%99%84%E4%BB%B6disassemble.png%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%84%B6%E5%90%8E%E5%8F%82%E8%80%83%E4%B8%8B%E9%9D%A2%E7%9A%84%E6%96%87%E6%A1%A3%E6%9D%A5%E8%B0%83%E8%AF%95BL31%E5%92%8Cu-boot%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FLayerscape-Knowledge-Base%2FDebugging-ATF-and-u-boot-with-CodeWarrior-for-ARMv8%2Fta-p%2F1684233%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FLayerscape-Knowledge-Base%2FDebugging-ATF-and-u-boot-with-CodeWarrior-for-ARMv8%2Fta-p%2F1684233%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
