SSH Connection Lost [ LX 2160 ] [ LSDK 20.04 ]
312 次查看
Chidananda22
hi ,
I am using LX 2160 - LSDK 20.04 - MC 10.30 - Restool 2.4 [ Compatible 10.30 ]
Configured only dpmac.4 [ ssh connection - DPDMUX.0 ].
DPDMUX Rule Applied : UDP port 2152
When Data receive from outside on DPDK Port 0 : It is coming properly to application. [ Working Fine ]
When from application we are sending Packet on DPDK Port 0 SSH Connection Lost.
From Outside PING is also not working. It recovers after some time.
If Same packet I send over Kernel instated of DPDK everything is fine.
After setup recovery if I check /var/log/kern.log or syslog no clue.
Changed TX Port config to default but no success.
Can you please suggest how I need to debug further.
278 次查看
Chidananda22
thanks I will check the same.
282 次查看
yipingwang
Please check whether this problem could be replaced with LSDK 20.04 default MC firmware.
mc_10.20.4_lx2160a.itb
It seems that MC 10.30 is not compatible with DPDK provided in LSDK 20.04.
