SDK 1.7: Freescale Custom Embedded Hypervisor
2,799 次查看
cpark
Does LS1021A support the following feature?  If yes, could you share some information and documents?
  • Freescale Custom Embedded Hypervisor multicore system for AMP based partitioning
That was mentioned on the following web page:
Linux® SDK for QorIQ Processors v1.7|Freescale
Chan Park
7 回复数
2,197 次查看
scottwood
The Freescale Embedded Hypervisor does not support ARM chips.  KVM is supported on LS1021A.
2,197 次查看
cpark
Is there any other alternative for AMP based partitioning for LS1021A?  Technically, it seems feasible to run Linux on one core and RTOS on the other core.  Can I use KVM for this partitioning too?
2,197 次查看
lunminliang
Hello Chan Park,
KVM is kernel-based virtual machine, while AMP is asynchronous multi-processing, running multiple operating system images on different processors of the same machine without virtualization... What do you mean by AMP here?
Lunmin
2,196 次查看
scottwood
I think they mean they want a lightweight partitioning hypervisor rather than something as heavy as Linux+KVM.  We don't currently have a supported product for this on ARM, but you may want to look at the Jailhouse hypervisor.
2,196 次查看
cpark
Thanks Lunmin and Scott for sharing information.
Yes, what I'm looking for is a lightweight partitioning (with or without Hypervisor) to run Linux on one core and RTOS(or bare metal) on the other core.
Jailhouse hypervisor looks great, but it seems to require PSCI support for CPU offlining, which is not supported by LS1, I guess.
2,196 次查看
lunminliang
Hello Chan Park,
According to QorIQ-SDK-1.7 on line document, in Section 10.3 KVM/QEMU (ARM), options of enabling PSCI:
Kernel features --->
        [*] Support for the ARM Power State Coordination Interface (PSCI)
Here is the link:
Freescale Technical Information Center
Lunmin
2,196 次查看
scottwood
What are you claiming that this will accomplish?
