Running iperf3 issue with VPP on LX2160
jackho
I try to run iperf3 with VPP on LX2160 based on LSDK2108
I following the steps below link:
https://wiki.fd.io/view/VPP/HostStack/LDP/iperf
export VCL_CONFIG=/etc/vpp/vcl.conf
export LD_PRELOAD=/usr/lib/aarch64-linux-gnu/libvcl_ldpreload.so
then running iperf3, it will show the below LDP error:
# iperf3 -c 10.1.107.242 -p 5201
LDP<126771>: ERROR: ldp_constructor: failed!
Do you have any idea about this issue?
BR,
Jack Ho
khushbur
Hi @jackho
It's looks like configuration problem. Please configure your vcl.conf and startup.conf as described in below link.
https://fdio-vpp.readthedocs.io/en/latest/gettingstarted/users/configuring/startup.html#
Khushbu
