The QuadSPI documentation are not complet
-Chapter 28.4.2.12 Serial Flash Address Register (QuadSPI_SFAR) is referenced to a none existing Table 1
-Chapter 28.4.2.17 TX Buffer Data Register (QuadSPI_TBDR) is referenced to a none existing Table 1
-Chapter 28.4.2.19 Flag Register (QuadSPI_FR ) is referenced to a none existing Table 1
-Chapter 28.4.2.27 RX Buffer Data Register (QuadSPI_RBDRn) is referenced to a none existing Table 1
Do you have another complete documentations which includes the referenced tables.
Specially the section of "list of legal instructions" and "table for the related commands" are the point of interrest
Sincerely Roland
Solved! Go to Solution.
Correction - Table 28-10. Serial Flash Address Assignment
Correction - Table 28-19. Byte Ordering in Individual Flash Mode
Correction - Table 28-17. Instruction set
The typos will be fixed in the next RM revision.
