OpenWRT 22.03.0 and MTU for ls1046ardb
1,188 次查看
Mefer1
In the new version, there is no way to raise the MTU in the kernel settings more than 1500 bytes. Are there any solutions to this problem. Previously it was possible to enable jambo frame. No option to choose FSL_SDK_DPA
1 回复
1,177 次查看
yipingwang
In Kernel configuration file target/linux/layerscape/armv8_64b/config-5.4, please modify CONFIG_FSL_FM_MAX_FRAME_SIZE=1522 according to your requirement.
标记 (1)
