Need Help: LS1046ARDB - Tx Interrupt in IM mode
3,738 次查看
srak
In document, there is information about Rx interrupt (RxF Interrupt, RxBD busy Interrupt) but I could not find information on Tx interrupt. How to check for Tx complete event or Tx ready event?
3,591 次查看
LFGP
unfortunately there is no dedicate interrupt to handle what you want,
please follow to the next link in order to get an idea to develop your own interrupt
https://developer.arm.com/documentation/den0024/a/AArch64-Exception-Handling/Interrupt-handling
5 回复数
3,649 次查看
srak
You can use theBSYfield in theFMBM_TST—Tx Statusregister.
How to enable interrupt for this field? I could not find interrupt details in document.
3,701 次查看
srak
Not using LPUART. I am using Ethernet - Independent mode. Any Tx interrupt available for Ethernet?
3,592 次查看
LFGP
3,681 次查看
LFGP
You can use the BSY field in the FMBM_TST—Tx Status register.
Please go to the section BMI Tx Port Registers in the LS1046 DPAA reference manual, page 552
use the next link for the DPAA
https://www.nxp.com/products/processors-and-microcontrollers/arm-processors/layerscape-processors/la...
3,718 次查看
LFGP
if you are using LPUART you can read the field TXEMPT in the LPUART FIFO Register.
Please go to the section 24.3.7 LPUART FIFO Register (LPUARTx_FIFO) in the reference manual to get more info about it.
