Hello everyone,
Can someone please suggest us the alternate for NX3DV42GU,115 (USB Switch ICs Dual high-speed USB 2.0 double-pole double-throw analog switch), which is having a very long lead time.
Thank You!
Hello Urmila,
Unfortunately there is not a suitable alternative IC available with a shorter lead time.
The NX3DV221GM,115 can also support USB2 application, but its lead time is also about 52 weeks.
Tomas
