MC34VR500 hard-coded internal configuration for LS1021A
deepaknaiknavar
I was looking into MC34VR500V3ES PMIC for powering LS1021A.
This chip has a hardcoded configuration for DDR 4 VTT termination of 0.6V which can eliminate my I2C requirement.
But this does not provide the 1.35V (X1VDD, required for Serdes) on any outputs.
I assume i need to use an external LDO for 1.35V if i do not use I2C. Is it correct?
r8070z
Yes, it is correct.
r8070z
Yes, it is correct.
deepaknaiknavar
Thanks Serguei !!
I was having another question- why the PMIC (MC34VR500V3ES) does not provide 1.35V in hard coded config that is required for the serdes supply.
I had this question because i believe it is a customized chip for LS1021A with DDR4 interface and ideally should not need additional LDO.
