When programming layerscape CPU with Code warrior programmer is native JTAG used or is the protocol SWD? I need to know wether JTAG TDI connection is required or not.
best regards,
Tom
已解决! 转到解答。
Correct.
Only JTAG functions of signals are used.
Does the codewarrior programmer for layerscape with 10-pin arm debug connector only support JTAG or also SWD?
Which processor is in question?
Have you read the processor Design Checklist document?
It is for LS1043A CPU, i see nothing about SWD in checklist/reference manual so i guess it's not supported.
We will just implement the 10-pin JTAG connector.
You wrote:> wether JTAG TDI connection is required or not.The request is not clear. TDI is essential JTAG signal.
