Here is the output from serial console:
NOTICE: BL2: Built : 17:04:14, Jan 8 2020
NOTICE: BL2: v1.5(release):lx2160a-early-access-bsp0.6
ERROR: Invalid DIMM combination.
ERROR: Parsing DIMM
Error ERROR: DDR init failed.
NOTICE: Incorrect DRAM0 size is defined in platfor_def.h
This is factory configured LX2160ARDB rev2 board. The problem was first observed with CodeWarrior TAP attached that we purchased a week ago. However, the hang occurs even when CodeWarrior TAP is not attached. It happens on every single reboot.
The only way to be able to boot again is to unplug power and wait until D28 LED turns off. However, because gdb script that we want to use in order to debug linux kernel resets the board we are unable to do any debugging.
(gdb) source ~/lx2160.gdb
Configuring the debug probe
Connecting to LX2160A
connected successfully Halt system
Execute target initialization...
I also compiled debug atf; so a little more info is printed. Below again good (after power cable unplug) vs. bad boot (reset):
INFO: Index = 0 with loc_nod=13 and input nod=13
INFO: Index = 0 with loc_nod=13 and input nod=30
INFO: Index = 1 with loc_nod=30 and input nod=30
INFO: Index = 0 with loc_nod=4 and input nod=17
INFO: Index = 1 with loc_nod=7 and input nod=17
INFO: Index = 2 with loc_nod=10 and input nod=17
INFO: Index = 3 with loc_nod=17 and input nod=17
INFO: RCW BOOT SRC is FLEXSPI NOR
NOTICE: BL2: v1.5(debug):LSDK-20.12
NOTICE: BL2: Built : 10:56:21, Apr 6 2021
INFO: time base 10 ms
WARNING: tx_byte nodev 72
NOTICE: UDIMM 18ADF2G72AZ-3G2E1
INFO: Time after parsing SPD 828 ms
INFO: Loading image id=29 at address 0x18003000
INFO: Image id=29 loaded: 0x18003000 - 0x18009bd0
INFO: Loading image id=31 at address 0x18003000
INFO: Image id=31 loaded: 0x18003000 - 0x180036d0
INFO: Loading image id=30 at address 0x18003000
INFO: Image id=30 loaded: 0x18003000 - 0x1800994c
INFO: Loading image id=32 at address 0x18003000
INFO: Image id=32 loaded: 0x18003000 - 0x180035bc
NOTICE: DDR4 UDIMM with 2-rank 64-bit bus (x8)
INFO: Time before programming controller 2990 ms
NOTICE: 32 GB DDR4, 64-bit, CL=17, ECC on, 256B, CS0+CS1
INFO: Time used by DDR driver 5837 ms
INFO: Configuring TrustZone Controller
INFO: Value of region base = ffe00000
INFO: Value of region base = 1ffe00000
INFO: Value of region base = fbe00000
INFO: Value of region base = 2880000000
INFO: BL2: Doing platform setup
INFO: BL2: Loading image id 3
INFO: Loading image id=3 at address 0xfbe00000
INFO: Image id=3 loaded: 0xfbe00000 - 0xfbe0e17c
INFO: BL2: Loading image id 5
INFO: Loading image id=5 at address 0x82000000
INFO: Image id=5 loaded: 0x82000000 - 0x820c73e1
NOTICE: BL2: Booting BL31
INFO: Entry point address = 0xfbe00000
INFO: SPSR = 0x3cd
NOTICE: BL31: v1.5(debug):LSDK-20.12
NOTICE: BL31: Built : 10:57:32, Apr 6 2021
NOTICE: Welcome to LX2160 BL31 Phase
INFO: GICv3 without legacy support detected. ARM GICV3 driver initialized in EL3
INFO: BL31: Initializing runtime services
INFO: BL31: cortex_a72: CPU workaround for 859971 was applied
INFO: BL31: cortex_a72: CPU workaround for cve_2017_5715 was applied
INFO: BL31: cortex_a72: CPU workaround for cve_2018_3639 was applied
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0x82000000
INFO: SPSR = 0x3c9
U-Boot 2020.04 (Apr 06 2021 - 10:12:51 -0400)
SoC: LX2160ACE Rev2.0 (0x87360020)
Clock Configuration:
CPU0(A72):2000 MHz CPU1(A72):2000 MHz CPU2(A72):2000 MHz
CPU3(A72):2000 MHz CPU4(A72):2000 MHz CPU5(A72):2000 MHz
CPU6(A72):2000 MHz CPU7(A72):2000 MHz CPU8(A72):2000 MHz
CPU9(A72):2000 MHz CPU10(A72):2000 MHz CPU11(A72):2000 MHz
CPU12(A72):2000 MHz CPU13(A72):2000 MHz CPU14(A72):2000 MHz
CPU15(A72):2000 MHz
Bus: 700 MHz DDR: 2400 MT/s
Reset Configuration Word (RCW):
00000000: 50636338 20500050 00000000 00000000
00000010: 00000000 0c010000 00000000 00000000
00000020: 036001a0 00002580 00000000 00000096
00000030: 00000000 00000000 00000000 00000000
00000040: 00000000 00000000 00000000 00000000
00000050: 00000000 00000000 00000000 00000000
00000060: 00000000 00000000 00027000 00000000
00000070: 08b30010 00150020
Model: NXP Layerscape LX2160ARDB Board
Board: LX2160ACE Rev2.0-RDB, wait_for_sr_state: Arbitration lost sr=13 cr=18 state=202
i2c_init_transfer: failed for chip 0x66 retry=0
i2c_init_transfer: failed for chip 0x66 retry=1
i2c_init_transfer: failed for chip 0x66 retry=2
i2c_init_transfer: give up i2c_regs=0x2000000
Board version: O, boot from wait_for_sr_state: Arbitration lost sr=13 cr=18 state=202
invalid setting, xmap: 7
FPGA: v255.255
SERDES1 Reference: Clock1 = 161.13MHz Clock2 = 161.13MHz
SERDES2 Reference: Clock1 = 100MHz Clock2 = 100MHz
SERDES3 Reference: Clock1 = 100MHz Clock2 = 100MHz
i2c_init_transfer: failed for chip 0x77 retry=0
i2c_init_transfer: failed for chip 0x77 retry=1
i2c_init_transfer: failed for chip 0x77 retry=2
PCA: failed to select proper channel
core voltage not adjusted
DRAM: 31.9 GiB
DDR 31.9 GiB (DDR4, 64-bit, CL=17, ECC on)
DDR Controller Interleaving Mode: 256B
DDR Chip-Select Interleaving Mode: CS0+CS1
WDT: Started with servicing (30s timeout)
Using SERDES1 Protocol: 19 (0x13)
Using SERDES2 Protocol: 5 (0x5)
Using SERDES3 Protocol: 2 (0x2)
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Loading Environment from SPI Flash... SF: Detected mt35xu512aba with page size 256 Bytes, erase size 128 KiB, total 64 MiB
OK
EEPROM: wait_for_sr_state: Arbitration lost sr=13 cr=18 state=202
i2c_init_transfer: failed for chip 0x57 retry=0
i2c_init_transfer: failed for chip 0x57 retry=1
i2c_init_transfer: failed for chip 0x57 retry=2
Read failed.
In: serial_pl01x
Out: serial_pl01x
Err: serial_pl01x
Net: wait_for_sr_state: Arbitration lost sr=13 cr=18 state=202
i2c_init_transfer: failed for chip 0x75 retry=0
i2c_init_transfer: failed for chip 0x75 retry=1
i2c_init_transfer: failed for chip 0x75 retry=2
i2c_init_transfer: failed for chip 0x50 retry=0
i2c_init_transfer: failed for chip 0x50 retry=1
i2c_init_transfer: failed for chip 0x50 retry=2
CS4223: Using software initialization...
CS4223: edc/gain/equalization settings: host: CX/4dB/4dB, line: SR/4dB/4dB
FSL_MDIO1:0 is connected to DPMAC5@25g-aui. Reconnecting to DPMAC6@25g-aui
PCIe1: pcie@3400000 disabled
PCIe2: pcie@3500000 disabled
PCIe3: pcie@3600000 Root Complex: no link
PCIe4: pcie@3700000 disabled
PCIe5: pcie@3800000 Root Complex: no link
PCIe6: pcie@3900000 disabled
DPMAC2@xlaui4, DPMAC3@xgmii
Warning: DPMAC3@xgmii (eth1) using random MAC address - 52:23:68:86:bf:ca
, DPMAC4@xgmii
Warning: DPMAC4@xgmii (eth2) using random MAC address - 26:5a:83:20:8b:3e
, DPMAC5@25g-aui
Warning: DPMAC5@25g-aui (eth3) using random MAC address - aa:d9:10:eb:e1:95
, DPMAC6@25g-aui
Warning: DPMAC6@25g-aui (eth4) using random MAC address - 8e:c9:23:32:a8:51
, DPMAC17@rgmii-id [PRIME]
Warning: DPMAC17@rgmii-id (eth5) using random MAC address - f2:b5:c3:62:57:78
, DPMAC18@rgmii-id
Warning: DPMAC18@rgmii-id (eth6) using random MAC address - 7e:da:3b:bb:1a:e3
device 0 offset 0x640000, size 0x80000
SF: 524288 bytes @ 0x640000 Read: OK
device 0 offset 0xa00000, size 0x300000
SF: 3145728 bytes @ 0xa00000 Read: OK
device 0 offset 0xe00000, size 0x100000
SF: 1048576 bytes @ 0xe00000 Read: OK
crc32+
fsl-mc: Booting Management Complex ... SUCCESS
fsl-mc: Management Complex booted (version: 10.24.0, boot status: 0x1)
Hit any key to stop autoboot: 0
=> reset
resetting ...
=INFO: Index = 0 with loc_nod=13 and input nod=13
WARNING: I2C arbitration lost
ERROR: Parsing DIMM Error
INFO: Value of region base = 7fdfffea
ASSERT: drivers/arm/tzc/tzc400.c:190
Seems the problems first start happening with these warnings: "WARNING: I2C arbitration lost"
They are coming from here: wait_for_state.
I just confirmed with the testing team, we never reproduced this problem on LX2160ARDB target boards in our board farm.
Please refer to the following switch setting for LX2160ARDB Rev 2.
If your problem remains, please contact your local FAE to exchange for another lX2160ARDB demo board, it seems that there is hardware problem with DDR PHY on your target board.
Yes, the switches are in correct position. I will contact FAE.
Please update u-boot to the latest LSDK 2012.
$ wget
https://www.nxp.com/lgfiles/sdk/lsdk2012/firmware_lx2160ardb_rev2_uboot_xspiboot.img
Under u-boot on the target board.
=> sf probe 0:0
=> tftp 0xa0000000 firmware_lx2160ardb_rev2_uboot_xspiboot.img
=> sf erase 0x0 +$filesize && sf write 0xa0000000 0x0 $filesize
This did not help:
NOTICE: BL2: v2.3():v2.3-LSDK-20.12
NOTICE: BL2: Built : 04:32:46, Dec 11 2020
NOTICE: 32 GB DDR4, 64-bit, CL=22, ECC on, 256B, CS0+CS1
NOTICE: BL31: v2.3():v2.3-LSDK-20.12
NOTICE: BL31: Built : 04:36:09, Dec 11 2020
NOTICE: Welcome to LX2160ARDB BL31 Phase
U-Boot 2020.04-gf46a944f71 (Dec 11 2020 - 04:35:59 +0800)
CPU0(A72):2200 MHz CPU1(A72):2200 MHz CPU2(A72):2200 MHz
CPU3(A72):2200 MHz CPU4(A72):2200 MHz CPU5(A72):2200 MHz
CPU6(A72):2200 MHz CPU7(A72):2200 MHz CPU8(A72):2200 MHz
CPU9(A72):2200 MHz CPU10(A72):2200 MHz CPU11(A72):2200 MHz
CPU12(A72):2200 MHz CPU13(A72):2200 MHz CPU14(A72):2200 MHz
CPU15(A72):2200 MHz
Bus: 750 MHz DDR: 3200 MT/s
00000000: 5883833c 24580058 00000000 00000000
Model: NXP Layerscape LX2160ARDB Board [113/492]
FPGA: v255.255
DRAM: 31.9 GiB
DDR 31.9 GiB (DDR4, 64-bit, CL=22, ECC on)
*** Warning - bad CRC, using default environment
Read failed.
In: serial_pl01x
Out: serial_pl01x
Err: serial_pl01x
DPMAC2@xlaui4
Warning: DPMAC2@xlaui4 (eth0) using random MAC address - fa:25:17:68:17:24
, DPMAC3@xgmii
Warning: DPMAC3@xgmii (eth1) using random MAC address - 8e:c4:cc:91:fa:02
, DPMAC4@xgmii
Warning: DPMAC4@xgmii (eth2) using random MAC address - b6:2f:89:0b:1e:3a
, DPMAC5@25g-aui
Warning: DPMAC5@25g-aui (eth3) using random MAC address - 32:a6:b3:b0:78:9e
, DPMAC6@25g-aui
Warning: DPMAC6@25g-aui (eth4) using random MAC address - d6:27:fe:c0:9a:0f
, DPMAC17@rgmii-id
Warning: DPMAC17@rgmii-id (eth5) using random MAC address - 7a:7a:34:30:a9:4a
, DPMAC18@rgmii-id
Warning: DPMAC18@rgmii-id (eth6) using random MAC address - 56:dc:08:d9:b0:1e
crc32+
=> reset
resetting ...
=>NOTICE: BL2: v2.3():v2.3-LSDK-20.12
NOTICE: Incorrect DRAM0 size is defined in platform_def.h
<hang>
