I'm a new user for NXP LX2160ARDB, also for DPDK programming, my project is using LX2160.
1. current environment already exists dprc.1
When I execute the command, "/usr/local/dpdk/dpaa2/dynamic_dpl.sh dpmac.3"
The result is,
root@localhost:~# ls-listni
dprc.1/dpni.1 (interface: eth0, end point: dpmac.2)
dprc.1/dpni.0 (interface: eth1, end point: dpmac.17)
dprc.1/dprc.2/dpni.2 (end point: dpmac.3)
But I find there's no interface for dpmac.3.
2.If I execute the command after reboot, "ls-addni dpmac.3", not the above command.
root@localhost:~# ls-addni dpmac.3
Created interface: eth2 (object:dpni.2, endpoint: dpmac.3)
dprc.1/dpni.2 (interface: eth2, end point: dpmac.3)
I know there's a difference about dprc, How can do dpni.2 belonging to dprc.2 have a ethernet interface?
Hello Lichang Wu,
dpni.2 belonging to dprc.2 is assigned to DPDK, so Linux cannot see it(no interface). dprc.1 is assigned to Linux.
Yiping
