LX2160A cannot self-host build debian 12 flex-build
1,437件の閲覧回数
bezeria
I am buildig the latest flex-build from github.
By cross-compiling via docker, I managed to build an image.
However, when trying to build the same image of flex-build on the LX2160A itself, I get the error after a while:
Building pktgen_dpdk ...
The Meson build system
Version: 1.0.1
Source dir: /root/flexbuild/components_lsdk2506/apps/networking/pktgen_dpdk
Build dir: /root/flexbuild/components_lsdk2506/apps/networking/pktgen_dpdk/build_debian_arm64
Build type: cross build
Program cat found: YES (/usr/bin/cat)
Project name: pktgen
Project version: 23.06.1
C compiler for the host machine: gcc -march=armv8-a+crc+crypto -fstack-protector-strong -O2 --sysroot=/root/flexbuild/build_lsdk2506/rfs/rootfs_lsdk2506_debian_server_arm64 (gcc 12.2.0 "gcc (Debian 12.2.0-14+deb12u1) 12.2.0")
C linker for the host machine: gcc -march=armv8-a+crc+crypto -fstack-protector-strong -O2 --sysroot=/root/flexbuild/build_lsdk2506/rfs/rootfs_lsdk2506_debian_server_arm64 ld.bfd 2.40
C compiler for the build machine: ccache cc (gcc 12.2.0 "cc (Debian 12.2.0-14+deb12u1) 12.2.0")
C linker for the build machine: cc ld.bfd 2.40
Build machine cpu family: aarch64
Build machine cpu: aarch64
Host machine cpu family: aarch64
Host machine cpu: aarch64
Target machine cpu family: aarch64
Target machine cpu: aarch64
Compiler for C supports arguments -mavx: NO
Compiler for C supports arguments -mavx2: NO
Compiler for C supports arguments -Wno-pedantic: YES
Compiler for C supports arguments -Wno-format-truncation: YES
Found pkg-config: /usr/bin/pkg-config (1.8.1)
Found CMake: NO
Run-time dependency libdpdk found: NO
meson.build:70:1: ERROR: Dependency lookup for libdpdk with method 'pkgconfig' failed: Could not generate cargs for libdpdk:
Package jansson was not found in the pkg-config search path.
Perhaps you should add the directory containing `jansson.pc'
to the PKG_CONFIG_PATH environment variable
Package 'jansson', required by 'libdpdk', not found
1,314件の閲覧回数
yipingwang
Confirmed with the LSDK development team.
Building debian on the target board is not supported.
%3CLINGO-SUB%20id%3D%22lingo-sub-2202060%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELX2160A%E3%81%AFDebian%2012%20flex-build%E3%82%92%E3%82%BB%E3%83%AB%E3%83%95%E3%83%9B%E3%82%B9%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2202060%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Egithub%20%E3%81%8B%E3%82%89%E6%9C%80%E6%96%B0%E3%81%AE%20flex-build%20%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Edocker%20%E7%B5%8C%E7%94%B1%E3%81%A7%E3%82%AF%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81LX2160A%20%E8%87%AA%E4%BD%93%E3%81%A7%20flex-build%20%E3%81%AE%E5%90%8C%E3%81%98%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%97%E3%81%B0%E3%82%89%E3%81%8F%E3%81%99%E3%82%8B%E3%81%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20pktgen_dpdk%20...%3CBR%20%2F%3E%20Meson%E3%83%93%E3%83%AB%E3%83%89%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3CBR%20%2F%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%201.0.1%3CBR%20%2F%3E%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%3A%20%2Froot%2Fflexbuild%2Fcomponents_lsdk2506%2Fapps%2Fnetworking%2Fpktgen_dpdk%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%89%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%3A%20%2Froot%2Fflexbuild%2Fcomponents_lsdk2506%2Fapps%2Fnetworking%2Fpktgen_dpdk%2Fbuild_debian_arm64%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%89%E3%82%BF%E3%82%A4%E3%83%97%3A%20%E3%82%AF%E3%83%AD%E3%82%B9%E3%83%93%E3%83%AB%E3%83%89%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%20cat%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3A%20%E3%81%AF%E3%81%84%20(%2Fusr%2Fbin%2Fcat)%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E5%90%8D%3A%20pktgen%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%2023.06.1%3CBR%20%2F%3E%E3%83%9B%E3%82%B9%E3%83%88%E3%83%9E%E3%82%B7%E3%83%B3%E7%94%A8%E3%81%AEC%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3A%20gcc%20-march%3Darmv8-a%2Bcrc%2Bcrypto%20-fstack-protector-strong%20-O2%20--sysroot%3D%2Froot%2Fflexbuild%2Fbuild_lsdk2506%2Frfs%2Frootfs_lsdk2506_debian_server_arm64%20(gcc%2012.2.0gcc%20(Debian%2012.2.0-14%2Bdeb12u1)12.2.0%22%3CBR%20%2F%3E%E3%83%9B%E3%82%B9%E3%83%88%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%AE%20C%20%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%3A%20gcc%20-march%3Darmv8-a%2Bcrc%2Bcrypto%20-fstack-protector-strong%20-O2%20--sysroot%3D%2Froot%2Fflexbuild%2Fbuild_lsdk2506%2Frfs%2Frootfs_lsdk2506_debian_server_arm64%20ld.bfd%202.40%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%89%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%AEC%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3A%20ccache%20cc%20(gcc%2012.2.0%E3%80%8Ccc%20(Debian%2012.2.0-14%2Bdeb12u1)12.2.0%22%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%89%E3%83%9E%E3%82%B7%E3%83%B3%E7%94%A8%E3%81%AEC%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%3A%20cc%20ld.bfd%202.40%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%89%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%AECPU%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%3A%20aarch64%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%89%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%AECPU%3A%20aarch64%3CBR%20%2F%3E%E3%83%9B%E3%82%B9%E3%83%88%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%AECPU%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%3A%20aarch64%3CBR%20%2F%3E%E3%83%9B%E3%82%B9%E3%83%88%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%AECPU%3A%20aarch64%3CBR%20%2F%3E%E5%AF%BE%E8%B1%A1%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%AECPU%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%3A%20aarch64%3CBR%20%2F%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%AECPU%3A%20aarch64%3CBR%20%2F%3E%20C%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AF%E5%BC%95%E6%95%B0%20-mavx%20%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%3A%20NO%3CBR%20%2F%3E%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AF%E5%BC%95%E6%95%B0-mavx2%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%3A%20NO%3CBR%20%2F%3E%20C%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AF%E5%BC%95%E6%95%B0%20-Wno-pedantic%20%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%3A%20%E3%81%AF%E3%81%84%3CBR%20%2F%3EC%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AF%E5%BC%95%E6%95%B0%20-Wno-format-truncation%20%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%3A%20YES%3CBR%20%2F%3E%20pkg-config%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3A%20%2Fusr%2Fbin%2Fpkg-config%20(1.8.1)%3CBR%20%2F%3E%20CMake%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3A%20%E3%81%84%E3%81%84%E3%81%88%3CBR%20%2F%3E%E5%AE%9F%E8%A1%8C%E6%99%82%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%20libdpdk%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3A%20%E3%81%84%E3%81%84%E3%81%88%3C%2FP%3E%3CP%3E%E3%83%A1%E3%82%BD%E3%83%B3.%E3%83%93%E3%83%AB%E3%83%89%3A70%3A1%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%A1%E3%82%BD%E3%83%83%E3%83%89%20'pkgconfig'%20%E3%81%AB%E3%82%88%E3%82%8B%20libdpdk%20%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%81%AE%E6%A4%9C%E7%B4%A2%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20libdpdk%20%E3%81%AE%20cargs%20%E3%82%92%E7%94%9F%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%20jansson%20%E3%81%8C%20pkg-config%20%E6%A4%9C%E7%B4%A2%E3%83%91%E3%82%B9%E3%81%AB%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%80%81%60jansson.pc'%E3%82%92%E5%90%AB%E3%82%80%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3CBR%20%2F%3E%20PKG_CONFIG_PATH%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%81%AB%3CBR%20%2F%3E'libdpdk'%20%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%20'jansson'%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2202060%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EQorIQ%20LS2%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
