When I was using the LX2160A device, I had this problem, which caused my process dump.
I noticed this error when something went wrong,
Is there something wrong with this? My kernel version is 5.4.3 and my MC version is 10.24
Jul 23 02:01:34 EMB3 kernel: [ 34.649572] fsl_dpaa2_eth dpni.3 eth6: dpni_set_taildrop(FQ) failed
Jul 23 02:01:40 EMB3 kernel: [ 34.659931] fsl_dpaa2_eth dpni.3 eth6: Link Event: state down
Aug 17 14:19:37 EMB3 kernel: [ 2425.445052] fsl_dpaa2_ptp dprtc.0: dprtc_clear_irq_status err -110
Br
Below is my full startup log
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] Linux version 5.4.3 (root@kdsys-compile) (gcc version 7.4.1 20181213 [linaro-7.4-2019.02 revision 56ec6f6b99cc167ff0c2f8e1a2eed33b1edc85d4] (Linaro GCC 7.4-2019.02)) #1 SMP PREEMPT Tue Aug 6 14:11:59 CST 2024
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] Machine model: NXP Layerscape LX2160ARDB
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] earlycon: pl11 at MMIO32 0x00000000021c0000 (options '')
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] printk: bootconsole [pl11] enabled
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] efi: Getting EFI parameters from FDT:
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] efi: UEFI not found.
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] cma: Reserved 320 MiB at 0x00000000e7c00000
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] NUMA: No NUMA configuration found
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x000000277fffffff]
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] NUMA: NODE_DATA [mem 0x277c1e1800-0x277c1e2fff]
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] Zone ranges:
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] DMA32 [mem 0x0000000080000000-0x00000000ffffffff]
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] Normal [mem 0x0000000100000000-0x000000277fffffff]
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] Movable zone start for each node
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] Early memory node ranges
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fbdfffff]
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] node 0: [mem 0x0000002080000000-0x000000277fffffff]
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000277fffffff]
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] psci: probing for conduit method from DT.
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] psci: PSCIv1.1 detected in firmware.
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] psci: Using standard PSCI v0.2 function IDs
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] psci: SMC Calling Convention v1.1
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] percpu: Embedded 24 pages/cpu s59928 r8192 d30184 u98304
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] Detected PIPT I-cache on CPU0
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] CPU features: detected: GIC system register CPU interface
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] CPU features: detected: EL2 vector hardening
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] Speculative Store Bypass Disable mitigation not required
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 7724544
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] Policy zone: Normal
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] Kernel command line: console=ttyAMA0,115200 root=/dev/ram0 earlycon=pl011,mmio32,0x21c0000 ramdisk_size=0x2000000 default_hugepagesz=1024m hugepagesz=1024m hugepages=2 pci=pcie_bus_perf
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] software IO TLB: mapped [mem 0xe3c00000-0xe7c00000] (64MB)
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] Memory: 28230040K/31389696K available (18428K kernel code, 2482K rwdata, 8592K rodata, 5888K init, 989K bss, 2831976K reserved, 327680K cma-reserved)
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] rcu: Preemptible hierarchical RCU implementation.
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] Tasks RCU enabled.
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] GICv3: 256 SPIs implemented
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] GICv3: 0 Extended SPIs implemented
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] GICv3: Distributor has no Range Selector support
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] GICv3: 16 PPIs implemented
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] GICv3: no VLPI support, no direct LPI support
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000006200000
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] ITS [mem 0x06020000-0x0603ffff]
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] ITS@0x0000000006020000: allocated 65536 Devices @275a880000 (flat, esz 8, psz 64K, shr 0)
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] ITS: using cache flushing for cmd queue
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] GICv3: Using preallocated redistributor tables
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] GICv3: using LPI property table @0x000000277fe00000
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] GICv3: CPU0: using reserved LPI pending table @0x000000277fe10000
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] random: get_random_bytes called from start_kernel+0x2c0/0x464 with crng_init=0
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] arch_timer: cp15 timer(s) running at 25.00MHz (phys).
Jul 23 02:01:12 EMB3 kernel: [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x5c409fb33, max_idle_ns: 440795203156 ns
Jul 23 02:01:12 EMB3 kernel: [ 0.000001] sched_clock: 56 bits at 25MHz, resolution 39ns, wraps every 4398046511103ns
Jul 23 02:01:12 EMB3 kernel: [ 0.008416] Console: colour dummy device 80x25
Jul 23 02:01:12 EMB3 kernel: [ 0.012943] Calibrating delay loop (skipped), value calculated using timer frequency.. 50.00 BogoMIPS (lpj=100000)
Jul 23 02:01:12 EMB3 kernel: [ 0.023410] pid_max: default: 32768 minimum: 301
Jul 23 02:01:12 EMB3 kernel: [ 0.028156] LSM: Security Framework initializing
Jul 23 02:01:12 EMB3 kernel: [ 0.032951] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
Jul 23 02:01:12 EMB3 kernel: [ 0.040694] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
Jul 23 02:01:12 EMB3 kernel: [ 0.072823] ASID allocator initialised with 32768 entries
Jul 23 02:01:12 EMB3 kernel: [ 0.086290] rcu: Hierarchical SRCU implementation.
Jul 23 02:01:12 EMB3 kernel: [ 0.099165] Platform MSI: gic-its@6020000 domain created
Jul 23 02:01:12 EMB3 kernel: [ 0.104574] PCI/MSI: /interrupt-controller@6000000/gic-its@6020000 domain created
Jul 23 02:01:12 EMB3 kernel: [ 0.112165] fsl-mc MSI: /interrupt-controller@6000000/gic-its@6020000 domain created
Jul 23 02:01:12 EMB3 kernel: [ 0.120437] EFI services will not be available.
Jul 23 02:01:12 EMB3 kernel: [ 0.133022] smp: Bringing up secondary CPUs ...
Jul 23 02:01:12 EMB3 kernel: [ 0.169738] Detected PIPT I-cache on CPU1
Jul 23 02:01:12 EMB3 kernel: [ 0.169755] GICv3: CPU1: found redistributor 1 region 0:0x0000000006220000
Jul 23 02:01:12 EMB3 kernel: [ 0.169767] GICv3: CPU1: using reserved LPI pending table @0x000000277fe20000
Jul 23 02:01:12 EMB3 kernel: [ 0.169879] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
Jul 23 02:01:12 EMB3 kernel: [ 0.201754] Detected PIPT I-cache on CPU2
Jul 23 02:01:12 EMB3 kernel: [ 0.201769] GICv3: CPU2: found redistributor 100 region 0:0x0000000006240000
Jul 23 02:01:12 EMB3 kernel: [ 0.201781] GICv3: CPU2: using reserved LPI pending table @0x000000277fe30000
Jul 23 02:01:12 EMB3 kernel: [ 0.201896] CPU2: Booted secondary processor 0x0000000100 [0x410fd083]
Jul 23 02:01:12 EMB3 kernel: [ 0.233777] Detected PIPT I-cache on CPU3
Jul 23 02:01:12 EMB3 kernel: [ 0.233787] GICv3: CPU3: found redistributor 101 region 0:0x0000000006260000
Jul 23 02:01:12 EMB3 kernel: [ 0.233798] GICv3: CPU3: using reserved LPI pending table @0x000000277fe40000
Jul 23 02:01:12 EMB3 kernel: [ 0.233907] CPU3: Booted secondary processor 0x0000000101 [0x410fd083]
Jul 23 02:01:12 EMB3 kernel: [ 0.265807] Detected PIPT I-cache on CPU4
Jul 23 02:01:12 EMB3 kernel: [ 0.265821] GICv3: CPU4: found redistributor 200 region 0:0x0000000006280000
Jul 23 02:01:12 EMB3 kernel: [ 0.265833] GICv3: CPU4: using reserved LPI pending table @0x000000277fe50000
Jul 23 02:01:12 EMB3 kernel: [ 0.265945] CPU4: Booted secondary processor 0x0000000200 [0x410fd083]
Jul 23 02:01:12 EMB3 kernel: [ 0.297830] Detected PIPT I-cache on CPU5
Jul 23 02:01:12 EMB3 kernel: [ 0.297842] GICv3: CPU5: found redistributor 201 region 0:0x00000000062a0000
Jul 23 02:01:12 EMB3 kernel: [ 0.297852] GICv3: CPU5: using reserved LPI pending table @0x000000277fe60000
Jul 23 02:01:12 EMB3 kernel: [ 0.297962] CPU5: Booted secondary processor 0x0000000201 [0x410fd083]
Jul 23 02:01:12 EMB3 kernel: [ 0.329862] Detected PIPT I-cache on CPU6
Jul 23 02:01:12 EMB3 kernel: [ 0.329877] GICv3: CPU6: found redistributor 300 region 0:0x00000000062c0000
Jul 23 02:01:12 EMB3 kernel: [ 0.329890] GICv3: CPU6: using reserved LPI pending table @0x000000277fe70000
Jul 23 02:01:12 EMB3 kernel: [ 0.330002] CPU6: Booted secondary processor 0x0000000300 [0x410fd083]
Jul 23 02:01:12 EMB3 kernel: [ 0.361886] Detected PIPT I-cache on CPU7
Jul 23 02:01:12 EMB3 kernel: [ 0.361899] GICv3: CPU7: found redistributor 301 region 0:0x00000000062e0000
Jul 23 02:01:12 EMB3 kernel: [ 0.361910] GICv3: CPU7: using reserved LPI pending table @0x000000277fe80000
Jul 23 02:01:12 EMB3 kernel: [ 0.362020] CPU7: Booted secondary processor 0x0000000301 [0x410fd083]
Jul 23 02:01:12 EMB3 kernel: [ 0.393918] Detected PIPT I-cache on CPU8
Jul 23 02:01:12 EMB3 kernel: [ 0.393936] GICv3: CPU8: found redistributor 400 region 0:0x0000000006300000
Jul 23 02:01:12 EMB3 kernel: [ 0.393949] GICv3: CPU8: using reserved LPI pending table @0x000000277fe90000
Jul 23 02:01:12 EMB3 kernel: [ 0.394059] CPU8: Booted secondary processor 0x0000000400 [0x410fd083]
Jul 23 02:01:12 EMB3 kernel: [ 0.425940] Detected PIPT I-cache on CPU9
Jul 23 02:01:12 EMB3 kernel: [ 0.425956] GICv3: CPU9: found redistributor 401 region 0:0x0000000006320000
Jul 23 02:01:12 EMB3 kernel: [ 0.425967] GICv3: CPU9: using reserved LPI pending table @0x000000277fea0000
Jul 23 02:01:12 EMB3 kernel: [ 0.426076] CPU9: Booted secondary processor 0x0000000401 [0x410fd083]
Jul 23 02:01:12 EMB3 kernel: [ 0.457981] Detected PIPT I-cache on CPU10
Jul 23 02:01:12 EMB3 kernel: [ 0.458000] GICv3: CPU10: found redistributor 500 region 0:0x0000000006340000
Jul 23 02:01:12 EMB3 kernel: [ 0.458013] GICv3: CPU10: using reserved LPI pending table @0x000000277feb0000
Jul 23 02:01:12 EMB3 kernel: [ 0.458127] CPU10: Booted secondary processor 0x0000000500 [0x410fd083]
Jul 23 02:01:12 EMB3 kernel: [ 0.489997] Detected PIPT I-cache on CPU11
Jul 23 02:01:12 EMB3 kernel: [ 0.490014] GICv3: CPU11: found redistributor 501 region 0:0x0000000006360000
Jul 23 02:01:12 EMB3 kernel: [ 0.490025] GICv3: CPU11: using reserved LPI pending table @0x000000277fec0000
Jul 23 02:01:12 EMB3 kernel: [ 0.490135] CPU11: Booted secondary processor 0x0000000501 [0x410fd083]
Jul 23 02:01:12 EMB3 kernel: [ 0.522029] Detected PIPT I-cache on CPU12
Jul 23 02:01:12 EMB3 kernel: [ 0.522050] GICv3: CPU12: found redistributor 600 region 0:0x0000000006380000
Jul 23 02:01:12 EMB3 kernel: [ 0.522063] GICv3: CPU12: using reserved LPI pending table @0x000000277fed0000
Jul 23 02:01:12 EMB3 kernel: [ 0.522175] CPU12: Booted secondary processor 0x0000000600 [0x410fd083]
Jul 23 02:01:12 EMB3 kernel: [ 0.554052] Detected PIPT I-cache on CPU13
Jul 23 02:01:12 EMB3 kernel: [ 0.554071] GICv3: CPU13: found redistributor 601 region 0:0x00000000063a0000
Jul 23 02:01:12 EMB3 kernel: [ 0.554082] GICv3: CPU13: using reserved LPI pending table @0x000000277fee0000
Jul 23 02:01:12 EMB3 kernel: [ 0.554191] CPU13: Booted secondary processor 0x0000000601 [0x410fd083]
Jul 23 02:01:12 EMB3 kernel: [ 0.586085] Detected PIPT I-cache on CPU14
Jul 23 02:01:12 EMB3 kernel: [ 0.586107] GICv3: CPU14: found redistributor 700 region 0:0x00000000063c0000
Jul 23 02:01:12 EMB3 kernel: [ 0.586120] GICv3: CPU14: using reserved LPI pending table @0x000000277fef0000
Jul 23 02:01:12 EMB3 kernel: [ 0.586233] CPU14: Booted secondary processor 0x0000000700 [0x410fd083]
Jul 23 02:01:12 EMB3 kernel: [ 0.618107] Detected PIPT I-cache on CPU15
Jul 23 02:01:12 EMB3 kernel: [ 0.618127] GICv3: CPU15: found redistributor 701 region 0:0x00000000063e0000
Jul 23 02:01:12 EMB3 kernel: [ 0.618138] GICv3: CPU15: using reserved LPI pending table @0x000000277ff00000
Jul 23 02:01:12 EMB3 kernel: [ 0.618247] CPU15: Booted secondary processor 0x0000000701 [0x410fd083]
Jul 23 02:01:12 EMB3 kernel: [ 0.618286] smp: Brought up 1 node, 16 CPUs
Jul 23 02:01:12 EMB3 kernel: [ 0.999031] SMP: Total of 16 processors activated.
Jul 23 02:01:12 EMB3 kernel: [ 1.003901] CPU features: detected: 32-bit EL0 Support
Jul 23 02:01:12 EMB3 kernel: [ 1.009102] CPU features: detected: CRC32 instructions
Jul 23 02:01:12 EMB3 kernel: [ 1.014347] CPU: All CPU(s) started at EL2
Jul 23 02:01:12 EMB3 kernel: [ 1.018535] alternatives: patching kernel code
Jul 23 02:01:12 EMB3 kernel: [ 1.023707] devtmpfs: initialized
Jul 23 02:01:12 EMB3 kernel: [ 1.029237] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Jul 23 02:01:12 EMB3 kernel: [ 1.039096] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
Jul 23 02:01:12 EMB3 kernel: [ 1.048848] xor: measuring software checksum speed
Jul 23 02:01:12 EMB3 kernel: [ 1.093716] 8regs : 8478.000 MB/sec
Jul 23 02:01:12 EMB3 kernel: [ 1.137958] 32regs : 8535.000 MB/sec
Jul 23 02:01:12 EMB3 kernel: [ 1.182199] arm64_neon: 8435.000 MB/sec
Jul 23 02:01:12 EMB3 kernel: [ 1.186423] xor: using function: 32regs (8535.000 MB/sec)
Jul 23 02:01:12 EMB3 kernel: [ 1.191881] pinctrl core: initialized pinctrl subsystem
Jul 23 02:01:12 EMB3 kernel: [ 1.197586] DMI not present or invalid.
Jul 23 02:01:12 EMB3 kernel: [ 1.201619] NET: Registered protocol family 16
Jul 23 02:01:12 EMB3 kernel: [ 1.206739] DMA: preallocated 256 KiB pool for atomic allocations
Jul 23 02:01:12 EMB3 kernel: [ 1.212902] audit: initializing netlink subsys (disabled)
Jul 23 02:01:12 EMB3 kernel: [ 1.218428] audit: type=2000 audit(1.020:1): state=initialized audit_enabled=0 res=1
Jul 23 02:01:12 EMB3 kernel: [ 1.226269] cpuidle: using governor menu
Jul 23 02:01:12 EMB3 kernel: [ 1.230420] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
Jul 23 02:01:12 EMB3 kernel: [ 1.237826] Serial: AMBA PL011 UART driver
Jul 23 02:01:12 EMB3 kernel: [ 1.242002] imx mu driver is registered.
Jul 23 02:01:12 EMB3 kernel: [ 1.245969] imx rpmsg driver is registered.
Jul 23 02:01:12 EMB3 kernel: [ 1.251078] Machine: NXP Layerscape LX2160ARDB
Jul 23 02:01:12 EMB3 kernel: [ 1.255567] SoC family: QorIQ LX2160A
Jul 23 02:01:12 EMB3 kernel: [ 1.259260] SoC ID: svr:0x87361020, Revision: 2.0
Jul 23 02:01:12 EMB3 kernel: [ 1.265693] sbsa_uart_probe: line: 0, mapbase: 0x21c0000
Jul 23 02:01:12 EMB3 kernel: [ 1.271073] 21c0000.serial: ttyAMA0 at MMIO 0x21c0000 (irq = 22, base_baud = 0) is a SBSA
Jul 23 02:01:12 EMB3 kernel: [ 1.279344] printk: console [ttyAMA0] enabled
Jul 23 02:01:12 EMB3 kernel: [ 1.288085] printk: bootconsole [pl11] disabled
Jul 23 02:01:12 EMB3 kernel: [ 1.297425] sbsa_uart_probe: line: 1, mapbase: 0x21d0000
Jul 23 02:01:12 EMB3 kernel: [ 1.302732] 21d0000.serial: ttyAMA1 at MMIO 0x21d0000 (irq = 23, base_baud = 0) is a SBSA
Jul 23 02:01:12 EMB3 kernel: [ 1.311106] sbsa_uart_probe: line: 2, mapbase: 0x21e0000
Jul 23 02:01:12 EMB3 kernel: [ 1.316412] 21e0000.serial: ttyAMA2 at MMIO 0x21e0000 (irq = 24, base_baud = 0) is a SBSA
Jul 23 02:01:12 EMB3 kernel: [ 1.324787] sbsa_uart_probe: line: 3, mapbase: 0x21f0000
Jul 23 02:01:12 EMB3 kernel: [ 1.330093] 21f0000.serial: ttyAMA3 at MMIO 0x21f0000 (irq = 25, base_baud = 0) is a SBSA
Jul 23 02:01:12 EMB3 kernel: [ 1.342122] fsl_mc_bus 80c000000.fsl-mc: MC firmware version: 10.24.0
Jul 23 02:01:12 EMB3 kernel: [ 1.351141] fsl_mc_dprc dprc.1: DMA mask not set
Jul 23 02:01:12 EMB3 kernel: [ 1.368053] HugeTLB registered 1.00 GiB page size, pre-allocated 2 pages
Jul 23 02:01:12 EMB3 kernel: [ 1.374755] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
Jul 23 02:01:12 EMB3 kernel: [ 1.381446] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
Jul 23 02:01:12 EMB3 kernel: [ 1.388137] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
Jul 23 02:01:12 EMB3 kernel: [ 1.396211] cryptd: max_cpu_qlen set to 1000
Jul 23 02:01:12 EMB3 kernel: [ 1.470887] raid6: neonx8 gen() 4847 MB/s
Jul 23 02:01:12 EMB3 kernel: [ 1.543191] raid6: neonx8 xor() 4169 MB/s
Jul 23 02:01:12 EMB3 kernel: [ 1.615495] raid6: neonx4 gen() 4160 MB/s
Jul 23 02:01:12 EMB3 kernel: [ 1.687792] raid6: neonx4 xor() 3863 MB/s
Jul 23 02:01:12 EMB3 kernel: [ 1.760094] raid6: neonx2 gen() 3262 MB/s
Jul 23 02:01:12 EMB3 kernel: [ 1.832395] raid6: neonx2 xor() 3664 MB/s
Jul 23 02:01:12 EMB3 kernel: [ 1.904706] raid6: neonx1 gen() 2487 MB/s
Jul 23 02:01:12 EMB3 kernel: [ 1.977009] raid6: neonx1 xor() 2754 MB/s
Jul 23 02:01:12 EMB3 kernel: [ 2.049326] raid6: int64x8 gen() 2169 MB/s
Jul 23 02:01:12 EMB3 kernel: [ 2.121354] raid6: int64x8 xor() 1792 MB/s
Jul 23 02:01:12 EMB3 kernel: [ 2.193377] raid6: int64x4 gen() 2511 MB/s
Jul 23 02:01:12 EMB3 kernel: [ 2.265411] raid6: int64x4 xor() 1819 MB/s
Jul 23 02:01:12 EMB3 kernel: [ 2.337452] raid6: int64x2 gen() 1683 MB/s
Jul 23 02:01:12 EMB3 kernel: [ 2.409470] raid6: int64x2 xor() 1639 MB/s
Jul 23 02:01:12 EMB3 kernel: [ 2.481529] raid6: int64x1 gen() 1229 MB/s
Jul 23 02:01:12 EMB3 kernel: [ 2.553537] raid6: int64x1 xor() 1106 MB/s
Jul 23 02:01:12 EMB3 kernel: [ 2.557796] raid6: using algorithm neonx8 gen() 4847 MB/s
Jul 23 02:01:12 EMB3 kernel: [ 2.563183] raid6: .... xor() 4169 MB/s, rmw enabled
Jul 23 02:01:12 EMB3 kernel: [ 2.568136] raid6: using neon recovery algorithm
Jul 23 02:01:12 EMB3 kernel: [ 2.573004] ACPI: Interpreter disabled.
Jul 23 02:01:12 EMB3 kernel: [ 2.577451] iommu: Default domain type: Passthrough
Jul 23 02:01:12 EMB3 kernel: [ 2.582473] vgaarb: loaded
Jul 23 02:01:12 EMB3 kernel: [ 2.585319] SCSI subsystem initialized
Jul 23 02:01:12 EMB3 kernel: [ 2.589220] usbcore: registered new interface driver usbfs
Jul 23 02:01:12 EMB3 kernel: [ 2.594711] usbcore: registered new interface driver hub
Jul 23 02:01:12 EMB3 kernel: [ 2.600055] usbcore: registered new device driver usb
Jul 23 02:01:12 EMB3 kernel: [ 2.605291] imx-i2c 2000000.i2c: can't get pinctrl, bus recovery not supported
Jul 23 02:01:12 EMB3 kernel: [ 2.612585] i2c i2c-0: IMX I2C adapter registered
Jul 23 02:01:12 EMB3 kernel: [ 2.617339] imx-i2c 2010000.i2c: can't get pinctrl, bus recovery not supported
Jul 23 02:01:12 EMB3 kernel: [ 2.624615] i2c i2c-1: IMX I2C adapter registered
Jul 23 02:01:12 EMB3 kernel: [ 2.629375] imx-i2c 2020000.i2c: can't get pinctrl, bus recovery not supported
Jul 23 02:01:12 EMB3 kernel: [ 2.636620] i2c i2c-2: IMX I2C adapter registered
Jul 23 02:01:12 EMB3 kernel: [ 2.641377] imx-i2c 2030000.i2c: can't get pinctrl, bus recovery not supported
Jul 23 02:01:12 EMB3 kernel: [ 2.648652] i2c i2c-3: IMX I2C adapter registered
Jul 23 02:01:12 EMB3 kernel: [ 2.653411] imx-i2c 2040000.i2c: can't get pinctrl, bus recovery not supported
Jul 23 02:01:12 EMB3 kernel: [ 2.660716] i2c i2c-4: IMX I2C adapter registered
Jul 23 02:01:12 EMB3 kernel: [ 2.665466] imx-i2c 2050000.i2c: can't get pinctrl, bus recovery not supported
Jul 23 02:01:12 EMB3 kernel: [ 2.672741] i2c i2c-5: IMX I2C adapter registered
Jul 23 02:01:12 EMB3 kernel: [ 2.677651] mc: Linux media interface: v0.10
Jul 23 02:01:12 EMB3 kernel: [ 2.681920] videodev: Linux video capture interface: v2.00
Jul 23 02:01:12 EMB3 kernel: [ 2.687421] pps_core: LinuxPPS API ver. 1 registered
Jul 23 02:01:12 EMB3 kernel: [ 2.692375] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Jul 23 02:01:12 EMB3 kernel: [ 2.701499] PTP clock support registered
Jul 23 02:01:12 EMB3 kernel: [ 2.705451] EDAC MC: Ver: 3.0.0
Jul 23 02:01:12 EMB3 kernel: [ 2.708989] No BMan portals available!
Jul 23 02:01:12 EMB3 kernel: [ 2.712885] QMan: Allocated lookup table at (____ptrval____), entry count 65537
Jul 23 02:01:12 EMB3 kernel: [ 2.720259] No QMan portals available!
Jul 23 02:01:12 EMB3 kernel: [ 2.724103] No USDPAA memory, no 'fsl,usdpaa-mem' in device-tree
Jul 23 02:01:12 EMB3 kernel: [ 2.730275] FPGA manager framework
Jul 23 02:01:12 EMB3 kernel: [ 2.733699] Advanced Linux Sound Architecture Driver Initialized.
Jul 23 02:01:12 EMB3 kernel: [ 2.740269] clocksource: Switched to clocksource arch_sys_counter
Jul 23 02:01:12 EMB3 kernel: [ 2.746442] VFS: Disk quotas dquot_6.6.0
Jul 23 02:01:12 EMB3 kernel: [ 2.750388] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Jul 23 02:01:12 EMB3 kernel: [ 2.757327] pnp: PnP ACPI: disabled
Jul 23 02:01:12 EMB3 kernel: [ 2.763307] thermal_sys: Registered thermal governor 'step_wise'
Jul 23 02:01:12 EMB3 kernel: [ 2.763309] thermal_sys: Registered thermal governor 'power_allocator'
Jul 23 02:01:12 EMB3 kernel: [ 2.769719] NET: Registered protocol family 2
Jul 23 02:01:12 EMB3 kernel: [ 2.780802] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
Jul 23 02:01:12 EMB3 kernel: [ 2.789656] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Jul 23 02:01:12 EMB3 kernel: [ 2.798532] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
Jul 23 02:01:12 EMB3 kernel: [ 2.806319] TCP: Hash tables configured (established 262144 bind 65536)
Jul 23 02:01:12 EMB3 kernel: [ 2.813002] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
Jul 23 02:01:12 EMB3 kernel: [ 2.820172] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
Jul 23 02:01:12 EMB3 kernel: [ 2.827861] NET: Registered protocol family 1
Jul 23 02:01:12 EMB3 kernel: [ 2.832399] RPC: Registered named UNIX socket transport module.
Jul 23 02:01:12 EMB3 kernel: [ 2.838313] RPC: Registered udp transport module.
Jul 23 02:01:12 EMB3 kernel: [ 2.843007] RPC: Registered tcp transport module.
Jul 23 02:01:12 EMB3 kernel: [ 2.847701] RPC: Registered tcp NFSv4.1 backchannel transport module.
Jul 23 02:01:12 EMB3 kernel: [ 2.854134] PCI: CLS 0 bytes, default 64
Jul 23 02:01:12 EMB3 kernel: [ 2.858111] Trying to unpack rootfs image as initramfs...
Jul 23 02:01:12 EMB3 kernel: [ 3.412098] Freeing initrd memory: 26504K
Jul 23 02:01:12 EMB3 kernel: [ 3.416887] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
Jul 23 02:01:12 EMB3 kernel: [ 3.425188] kvm [1]: IPA Size Limit: 44bits
Jul 23 02:01:12 EMB3 kernel: [ 3.429714] kvm [1]: vgic-v2@c0e0000
Jul 23 02:01:12 EMB3 kernel: [ 3.433282] kvm [1]: GIC system register CPU interface enabled
Jul 23 02:01:12 EMB3 kernel: [ 3.439272] kvm [1]: vgic interrupt IRQ1
Jul 23 02:01:12 EMB3 kernel: [ 3.443353] kvm [1]: Hyp mode initialized successfully
Jul 23 02:01:12 EMB3 kernel: [ 3.473436] Initialise system trusted keyrings
Jul 23 02:01:12 EMB3 kernel: [ 3.477934] workingset: timestamp_bits=44 max_order=23 bucket_order=0
Jul 23 02:01:12 EMB3 kernel: [ 3.484821] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Jul 23 02:01:12 EMB3 kernel: [ 3.490794] NFS: Registering the id_resolver key type
Jul 23 02:01:12 EMB3 kernel: [ 3.495844] Key type id_resolver registered
Jul 23 02:01:12 EMB3 kernel: [ 3.500017] Key type id_legacy registered
Jul 23 02:01:12 EMB3 kernel: [ 3.504021] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Jul 23 02:01:12 EMB3 kernel: [ 3.510721] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
Jul 23 02:01:12 EMB3 kernel: [ 3.516924] fuse: init (API version 7.31)
Jul 23 02:01:12 EMB3 kernel: [ 3.521010] 9p: Installing v9fs 9p2000 file system support
Jul 23 02:01:12 EMB3 kernel: [ 3.534297] Key type asymmetric registered
Jul 23 02:01:12 EMB3 kernel: [ 3.538386] Asymmetric key parser 'x509' registered
Jul 23 02:01:12 EMB3 kernel: [ 3.543268] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
Jul 23 02:01:12 EMB3 kernel: [ 3.550717] io scheduler mq-deadline registered
Jul 23 02:01:12 EMB3 kernel: [ 3.555242] io scheduler kyber registered
Jul 23 02:01:12 EMB3 kernel: [ 3.562888] layerscape-pcie 3500000.pcie: host bridge /soc/pcie@3500000 ranges:
Jul 23 02:01:12 EMB3 kernel: [ 3.570198] layerscape-pcie 3500000.pcie: MEM 0x8840000000..0x887fffffff -> 0x40000000
Jul 23 02:01:12 EMB3 kernel: [ 3.578362] layerscape-pcie 3500000.pcie: PCI host bridge to bus 0000:00
Jul 23 02:01:12 EMB3 kernel: [ 3.585055] pci_bus 0000:00: root bus resource [bus 00-ff]
Jul 23 02:01:12 EMB3 kernel: [ 3.590533] pci_bus 0000:00: root bus resource [mem 0x8840000000-0x887fffffff] (bus address [0x40000000-0x7fffffff])
Jul 23 02:01:12 EMB3 kernel: [ 3.601058] pci 0000:00:00.0: [1957:8d90] type 01 class 0x060400
Jul 23 02:01:12 EMB3 kernel: [ 3.607080] pci 0000:00:00.0: reg 0x38: [mem 0x8840000000-0x88400007ff pref]
Jul 23 02:01:12 EMB3 kernel: [ 3.614158] pci 0000:00:00.0: supports D1 D2
Jul 23 02:01:12 EMB3 kernel: [ 3.618419] pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot
Jul 23 02:01:12 EMB3 kernel: [ 3.625608] pci 0000:00:00.0: BAR 6: assigned [mem 0x8840000000-0x88400007ff pref]
Jul 23 02:01:12 EMB3 kernel: [ 3.633170] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
Jul 23 02:01:12 EMB3 kernel: [ 3.638398] pci 0000:00:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 256
Jul 23 02:01:12 EMB3 kernel: [ 3.646897] layerscape-pcie 3600000.pcie: host bridge /soc/pcie@3600000 ranges:
Jul 23 02:01:12 EMB3 kernel: [ 3.654203] layerscape-pcie 3600000.pcie: MEM 0x9040000000..0x907fffffff -> 0x40000000
Jul 23 02:01:12 EMB3 kernel: [ 3.662348] layerscape-pcie 3600000.pcie: PCI host bridge to bus 0001:00
Jul 23 02:01:12 EMB3 kernel: [ 3.669041] pci_bus 0001:00: root bus resource [bus 00-ff]
Jul 23 02:01:12 EMB3 kernel: [ 3.674519] pci_bus 0001:00: root bus resource [mem 0x9040000000-0x907fffffff] (bus address [0x40000000-0x7fffffff])
Jul 23 02:01:12 EMB3 kernel: [ 3.685042] pci 0001:00:00.0: [1957:8d90] type 01 class 0x060400
Jul 23 02:01:12 EMB3 kernel: [ 3.691051] pci 0001:00:00.0: reg 0x10: [mem 0x00000000-0x00ffffff]
Jul 23 02:01:12 EMB3 kernel: [ 3.697312] pci 0001:00:00.0: reg 0x14: [mem 0x00000000-0x03ffffff]
Jul 23 02:01:12 EMB3 kernel: [ 3.703573] pci 0001:00:00.0: reg 0x38: [mem 0x9048000000-0x9048ffffff pref]
Jul 23 02:01:12 EMB3 kernel: [ 3.710647] pci 0001:00:00.0: supports D1 D2
Jul 23 02:01:12 EMB3 kernel: [ 3.714908] pci 0001:00:00.0: PME# supported from D0 D1 D2 D3hot
Jul 23 02:01:12 EMB3 kernel: [ 3.721611] pci 0001:01:00.0: [cb10:5236] type 00 class 0x078000
Jul 23 02:01:12 EMB3 kernel: [ 3.727879] pci 0001:01:00.0: reg 0x10: [mem 0x9049000000-0x9049003fff 64bit pref]
Jul 23 02:01:12 EMB3 kernel: [ 3.735546] pci 0001:01:00.0: reg 0x18: [mem 0x9049010000-0x904901ffff 64bit pref]
Jul 23 02:01:12 EMB3 kernel: [ 3.743210] pci 0001:01:00.0: reg 0x20: [mem 0x9050000000-0x905fffffff 64bit pref]
Jul 23 02:01:12 EMB3 kernel: [ 3.751443] pci 0001:01:00.0: supports D1 D2
Jul 23 02:01:12 EMB3 kernel: [ 3.755703] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
Jul 23 02:01:12 EMB3 kernel: [ 3.772915] pci 0001:00:00.0: BAR 15: assigned [mem 0x9040000000-0x9057ffffff 64bit pref]
Jul 23 02:01:12 EMB3 kernel: [ 3.781090] pci 0001:00:00.0: BAR 1: assigned [mem 0x9058000000-0x905bffffff]
Jul 23 02:01:12 EMB3 kernel: [ 3.788219] pci 0001:00:00.0: BAR 0: assigned [mem 0x905c000000-0x905cffffff]
Jul 23 02:01:12 EMB3 kernel: [ 3.795347] pci 0001:00:00.0: BAR 6: assigned [mem 0x905d000000-0x905dffffff pref]
Jul 23 02:01:12 EMB3 kernel: [ 3.802909] pci 0001:01:00.0: BAR 4: assigned [mem 0x9040000000-0x904fffffff 64bit pref]
Jul 23 02:01:12 EMB3 kernel: [ 3.811058] pci 0001:01:00.0: BAR 2: assigned [mem 0x9050000000-0x905000ffff 64bit pref]
Jul 23 02:01:12 EMB3 kernel: [ 3.819206] pci 0001:01:00.0: BAR 0: assigned [mem 0x9050010000-0x9050013fff 64bit pref]
Jul 23 02:01:12 EMB3 kernel: [ 3.827354] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
Jul 23 02:01:12 EMB3 kernel: [ 3.832573] pci 0001:00:00.0: bridge window [mem 0x9040000000-0x9057ffffff 64bit pref]
Jul 23 02:01:12 EMB3 kernel: [ 3.840661] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 256
Jul 23 02:01:12 EMB3 kernel: [ 3.849186] pci 0001:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 256
Jul 23 02:01:12 EMB3 kernel: [ 3.857690] layerscape-pcie 3700000.pcie: host bridge /soc/pcie@3700000 ranges:
Jul 23 02:01:12 EMB3 kernel: [ 3.864998] layerscape-pcie 3700000.pcie: MEM 0x9840000000..0x987fffffff -> 0x40000000
Jul 23 02:01:12 EMB3 kernel: [ 3.873150] layerscape-pcie 3700000.pcie: PCI host bridge to bus 0002:00
Jul 23 02:01:12 EMB3 kernel: [ 3.879844] pci_bus 0002:00: root bus resource [bus 00-ff]
Jul 23 02:01:12 EMB3 kernel: [ 3.885321] pci_bus 0002:00: root bus resource [mem 0x9840000000-0x987fffffff] (bus address [0x40000000-0x7fffffff])
Jul 23 02:01:12 EMB3 kernel: [ 3.895841] pci 0002:00:00.0: [1957:8d90] type 01 class 0x060400
Jul 23 02:01:12 EMB3 kernel: [ 3.901861] pci 0002:00:00.0: reg 0x38: [mem 0x9840000000-0x98400007ff pref]
Jul 23 02:01:12 EMB3 kernel: [ 3.908935] pci 0002:00:00.0: supports D1 D2
Jul 23 02:01:12 EMB3 kernel: [ 3.913197] pci 0002:00:00.0: PME# supported from D0 D1 D2 D3hot
Jul 23 02:01:12 EMB3 kernel: [ 3.920352] pci 0002:00:00.0: BAR 6: assigned [mem 0x9840000000-0x98400007ff pref]
Jul 23 02:01:12 EMB3 kernel: [ 3.927912] pci 0002:00:00.0: PCI bridge to [bus 01-ff]
Jul 23 02:01:12 EMB3 kernel: [ 3.933139] pci 0002:00:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 256
Jul 23 02:01:12 EMB3 kernel: [ 3.942147] EINJ: ACPI disabled.
Jul 23 02:01:12 EMB3 kernel: [ 3.947644] Bus freq driver module loaded
Jul 23 02:01:12 EMB3 kernel: [ 3.954128] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
Jul 23 02:01:12 EMB3 kernel: [ 3.961185] SuperH (H)SCI(F) driver initialized
Jul 23 02:01:12 EMB3 kernel: [ 3.965917] msm_serial: driver initialized
Jul 23 02:01:12 EMB3 kernel: [ 3.971062] arm-smmu 5000000.iommu: probing hardware configuration...
Jul 23 02:01:12 EMB3 kernel: [ 3.977500] arm-smmu 5000000.iommu: SMMUv2 with:
Jul 23 02:01:12 EMB3 kernel: [ 3.982109] arm-smmu 5000000.iommu: stage 1 translation
Jul 23 02:01:12 EMB3 kernel: [ 3.987411] arm-smmu 5000000.iommu: stage 2 translation
Jul 23 02:01:12 EMB3 kernel: [ 3.992712] arm-smmu 5000000.iommu: nested translation
Jul 23 02:01:12 EMB3 kernel: [ 3.997927] arm-smmu 5000000.iommu: coherent table walk
Jul 23 02:01:12 EMB3 kernel: [ 4.003229] arm-smmu 5000000.iommu: (IDR0.CTTW overridden by FW configuration)
Jul 23 02:01:12 EMB3 kernel: [ 4.010529] arm-smmu 5000000.iommu: stream matching with 128 register groups
Jul 23 02:01:12 EMB3 kernel: [ 4.017654] arm-smmu 5000000.iommu: 64 context banks (0 stage-2 only)
Jul 23 02:01:12 EMB3 kernel: [ 4.024173] arm-smmu 5000000.iommu: Supported page sizes: 0x61311000
Jul 23 02:01:12 EMB3 kernel: [ 4.030606] arm-smmu 5000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
Jul 23 02:01:12 EMB3 kernel: [ 4.037036] arm-smmu 5000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
Jul 23 02:01:12 EMB3 kernel: [ 4.048614] brd: module loaded
Jul 23 02:01:12 EMB3 kernel: [ 4.055916] loop: module loaded
Jul 23 02:01:12 EMB3 kernel: [ 4.059190] ********eeprom at24 driver probed********
Jul 23 02:01:12 EMB3 kernel: [ 4.064242] at24 4-0053: 8192 byte 24c64 EEPROM, writable, 32 bytes/write
Jul 23 02:01:12 EMB3 kernel: [ 4.071927] imx ahci driver is registered.
Jul 23 02:01:12 EMB3 kernel: [ 4.077226] spi-nor spi1.1: found gd25q64, ID: c8 40 17 00 00 00
Jul 23 02:01:12 EMB3 kernel: [ 4.083228] spi-nor spi1.1: found gd25q64, expected mx25l25635e
Jul 23 02:01:12 EMB3 kernel: [ 4.090851] spi-nor spi1.1: gd25q64 (8192 Kbytes)
Jul 23 02:01:12 EMB3 kernel: [ 4.095552] spi-nor spi1.1: mtd .name = spi1.1, .size = 0x800000 (8MiB), .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
Jul 23 02:01:12 EMB3 kernel: [ 4.109471] spi-nor spi3.0: found mt35xu512aba, ID: 2c 5b 1a 00 00 00
Jul 23 02:01:12 EMB3 kernel: [ 4.115912] spi-nor spi3.0: found mt35xu512aba, expected m25p80
Jul 23 02:01:12 EMB3 kernel: [ 4.121828] spi-nor spi3.0: mt35xu512aba (65536 Kbytes)
Jul 23 02:01:12 EMB3 kernel: [ 4.127045] spi-nor spi3.0: mtd .name = 20c0000.spi, .size = 0x4000000 (64MiB), .erasesize = 0x00020000 (128KiB) .numeraseregions = 0
Jul 23 02:01:12 EMB3 kernel: [ 4.141533] libphy: Fixed MDIO Bus: probed
Jul 23 02:01:12 EMB3 kernel: [ 4.145911] tun: Universal TUN/TAP device driver, 1.6
Jul 23 02:01:12 EMB3 kernel: [ 4.151267] thunder_xcv, ver 1.0
Jul 23 02:01:12 EMB3 kernel: [ 4.154504] thunder_bgx, ver 1.0
Jul 23 02:01:12 EMB3 kernel: [ 4.157736] nicpf, ver 1.0
Jul 23 02:01:12 EMB3 kernel: [ 4.160605] libphy: Freescale XGMAC MDIO Bus: probed
Jul 23 02:01:12 EMB3 kernel: [ 4.166732] fsl-fman_xmdio 8b96000.mdio: Created smi dev: smi-0
Jul 23 02:01:12 EMB3 kernel: [ 4.172709] libphy: Freescale XGMAC MDIO Bus: probed
Jul 23 02:01:12 EMB3 kernel: [ 4.177697] fsl-fman_xmdio 8b97000.mdio: Created smi dev: smi-1
Jul 23 02:01:12 EMB3 kernel: [ 4.183683] Freescale FM module, FMD API version 21.1.0
Jul 23 02:01:12 EMB3 kernel: [ 4.188959] Freescale FM Ports module
Jul 23 02:01:12 EMB3 kernel: [ 4.192612] fsl_mac: fsl_mac: FSL FMan MAC API based driver
Jul 23 02:01:12 EMB3 kernel: [ 4.198218] fsl_dpa: FSL DPAA Ethernet driver
Jul 23 02:01:12 EMB3 kernel: [ 4.202599] fsl_advanced: FSL DPAA Advanced drivers:
Jul 23 02:01:12 EMB3 kernel: [ 4.207555] fsl_proxy: FSL DPAA Proxy initialization driver
Jul 23 02:01:12 EMB3 kernel: [ 4.213150] fsl_oh: FSL FMan Offline Parsing port driver
Jul 23 02:01:12 EMB3 kernel: [ 4.218719] hclge is initializing
Jul 23 02:01:12 EMB3 kernel: [ 4.222026] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
Jul 23 02:01:12 EMB3 kernel: [ 4.229237] hns3: Copyright (c) 2017 Huawei Corporation.
Jul 23 02:01:12 EMB3 kernel: [ 4.234559] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
Jul 23 02:01:12 EMB3 kernel: [ 4.241597] e1000: Copyright (c) 1999-2006 Intel Corporation.
Jul 23 02:01:12 EMB3 kernel: [ 4.247348] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
Jul 23 02:01:12 EMB3 kernel: [ 4.253170] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
Jul 23 02:01:12 EMB3 kernel: [ 4.259096] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.6.0-k
Jul 23 02:01:12 EMB3 kernel: [ 4.266047] igb: Copyright (c) 2007-2014 Intel Corporation.
Jul 23 02:01:12 EMB3 kernel: [ 4.271622] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
Jul 23 02:01:12 EMB3 kernel: [ 4.279441] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
Jul 23 02:01:12 EMB3 kernel: [ 4.285476] sky2: driver version 1.30
Jul 23 02:01:12 EMB3 kernel: [ 4.289360] usbcore: registered new interface driver r8152
Jul 23 02:01:12 EMB3 kernel: [ 4.294847] usbcore: registered new interface driver asix
Jul 23 02:01:12 EMB3 kernel: [ 4.300247] usbcore: registered new interface driver ax88179_178a
Jul 23 02:01:12 EMB3 kernel: [ 4.306508] VFIO - User Level meta-driver version: 0.3
Jul 23 02:01:12 EMB3 kernel: [ 4.311819] dwc3 3100000.usb: Adding to iommu group 0
Jul 23 02:01:12 EMB3 kernel: [ 4.316909] dwc3 3100000.usb: Failed to get clk 'ref': -2
Jul 23 02:01:12 EMB3 kernel: [ 4.322564] dwc3 3110000.usb: Adding to iommu group 1
Jul 23 02:01:12 EMB3 kernel: [ 4.327636] dwc3 3110000.usb: Failed to get clk 'ref': -2
Jul 23 02:01:12 EMB3 kernel: [ 4.333705] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jul 23 02:01:12 EMB3 kernel: [ 4.340229] ehci-pci: EHCI PCI platform driver
Jul 23 02:01:12 EMB3 kernel: [ 4.344679] ehci-platform: EHCI generic platform driver
Jul 23 02:01:12 EMB3 kernel: [ 4.349941] ehci-orion: EHCI orion driver
Jul 23 02:01:12 EMB3 kernel: [ 4.353982] ehci-exynos: EHCI EXYNOS driver
Jul 23 02:01:12 EMB3 kernel: [ 4.358189] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Jul 23 02:01:12 EMB3 kernel: [ 4.364364] ohci-pci: OHCI PCI platform driver
Jul 23 02:01:12 EMB3 kernel: [ 4.368812] ohci-platform: OHCI generic platform driver
Jul 23 02:01:12 EMB3 kernel: [ 4.374070] ohci-exynos: OHCI EXYNOS driver
Jul 23 02:01:12 EMB3 kernel: [ 4.378397] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
Jul 23 02:01:12 EMB3 kernel: [ 4.383883] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
Jul 23 02:01:12 EMB3 kernel: [ 4.391589] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220f66d hci version 0x100 quirks 0x0000000002010810
Jul 23 02:01:12 EMB3 kernel: [ 4.400991] xhci-hcd xhci-hcd.0.auto: irq 30, io mem 0x03100000
Jul 23 02:01:12 EMB3 kernel: [ 4.407181] hub 1-0:1.0: USB hub found
Jul 23 02:01:12 EMB3 kernel: [ 4.410936] hub 1-0:1.0: 1 port detected
Jul 23 02:01:12 EMB3 kernel: [ 4.414958] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
Jul 23 02:01:12 EMB3 kernel: [ 4.420440] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
Jul 23 02:01:12 EMB3 kernel: [ 4.428089] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
Jul 23 02:01:12 EMB3 kernel: [ 4.434789] hub 2-0:1.0: USB hub found
Jul 23 02:01:12 EMB3 kernel: [ 4.438540] hub 2-0:1.0: 1 port detected
Jul 23 02:01:12 EMB3 kernel: [ 4.442584] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
Jul 23 02:01:12 EMB3 kernel: [ 4.448067] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
Jul 23 02:01:12 EMB3 kernel: [ 4.455789] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f66d hci version 0x100 quirks 0x0000000002010810
Jul 23 02:01:12 EMB3 kernel: [ 4.465189] xhci-hcd xhci-hcd.1.auto: irq 31, io mem 0x03110000
Jul 23 02:01:12 EMB3 kernel: [ 4.471323] hub 3-0:1.0: USB hub found
Jul 23 02:01:12 EMB3 kernel: [ 4.475076] hub 3-0:1.0: 1 port detected
Jul 23 02:01:12 EMB3 kernel: [ 4.479086] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
Jul 23 02:01:12 EMB3 kernel: [ 4.484567] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
Jul 23 02:01:12 EMB3 kernel: [ 4.492215] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
Jul 23 02:01:12 EMB3 kernel: [ 4.498906] hub 4-0:1.0: USB hub found
Jul 23 02:01:12 EMB3 kernel: [ 4.502657] hub 4-0:1.0: 1 port detected
Jul 23 02:01:12 EMB3 kernel: [ 4.506786] usbcore: registered new interface driver usb-storage
Jul 23 02:01:12 EMB3 kernel: [ 4.514063] ftm-alarm 2800000.timer: registered as rtc1
Jul 23 02:01:12 EMB3 kernel: [ 4.519662] i2c /dev entries driver
Jul 23 02:01:12 EMB3 kernel: [ 4.525389] sbsa-gwdt 23a0000.watchdog: Initialized with 30s timeout @ 25000050 Hz, action=0.
Jul 23 02:01:12 EMB3 kernel: [ 4.535861] qoriq_cpufreq: Freescale QorIQ CPU frequency scaling driver
Jul 23 02:01:12 EMB3 kernel: [ 4.543051] sdhci: Secure Digital Host Controller Interface driver
Jul 23 02:01:12 EMB3 kernel: [ 4.549239] sdhci: Copyright(c) Pierre Ossman
Jul 23 02:01:12 EMB3 kernel: [ 4.553763] Synopsys Designware Multimedia Card Interface Driver
Jul 23 02:01:12 EMB3 kernel: [ 4.560107] sdhci-pltfm: SDHCI platform and OF driver helper
Jul 23 02:01:12 EMB3 kernel: [ 4.566052] sdhci-esdhc 2140000.esdhc: Adding to iommu group 2
Jul 23 02:01:12 EMB3 kernel: [ 4.597348] mmc0: SDHCI controller on 2140000.esdhc [2140000.esdhc] using ADMA 64-bit
Jul 23 02:01:12 EMB3 kernel: [ 4.606345] ledtrig-cpu: registered to indicate activity on CPUs
Jul 23 02:01:12 EMB3 kernel: [ 4.612936] caam 8000000.crypto: device ID = 0x0a1a020000000000 (Era 10)
Jul 23 02:01:12 EMB3 kernel: [ 4.619646] caam 8000000.crypto: job rings = 3, qi = 1
Jul 23 02:01:12 EMB3 kernel: [ 4.626403] caam_jr 8010000.jr: Adding to iommu group 3
Jul 23 02:01:12 EMB3 kernel: [ 4.670389] random: fast init done
Jul 23 02:01:12 EMB3 kernel: [ 4.712097] mmc0: new HS400 MMC card at address 0001
Jul 23 02:01:12 EMB3 kernel: [ 4.717387] mmcblk0: mmc0:0001 G1M15M 19.8 GiB
Jul 23 02:01:12 EMB3 kernel: [ 4.722067] mmcblk0boot0: mmc0:0001 G1M15M partition 1 31.5 MiB
Jul 23 02:01:12 EMB3 kernel: [ 4.728130] mmcblk0boot1: mmc0:0001 G1M15M partition 2 31.5 MiB
Jul 23 02:01:12 EMB3 kernel: [ 4.732300] usb usb1-port1: over-current condition
Jul 23 02:01:12 EMB3 kernel: [ 4.734110] mmcblk0rpmb: mmc0:0001 G1M15M partition 3 4.00 MiB, chardev (506:0)
Jul 23 02:01:12 EMB3 kernel: [ 4.747050] mmcblk0: p1
Jul 23 02:01:12 EMB3 kernel: [ 4.756419] caam algorithms registered in /proc/crypto
Jul 23 02:01:12 EMB3 kernel: [ 4.764330] usb usb2-port1: over-current condition
Jul 23 02:01:12 EMB3 kernel: [ 4.786458] caam 8000000.crypto: caam pkc algorithms registered in /proc/crypto
Jul 23 02:01:12 EMB3 kernel: [ 4.794041] caam_jr 8010000.jr: registering rng-caam
Jul 23 02:01:12 EMB3 kernel: [ 4.796292] usb usb3-port1: over-current condition
Jul 23 02:01:12 EMB3 kernel: [ 4.799091] caam_jr 8020000.jr: Adding to iommu group 4
Jul 23 02:01:12 EMB3 kernel: [ 4.812517] caam_jr 8030000.jr: Adding to iommu group 5
Jul 23 02:01:12 EMB3 kernel: [ 4.821060] usbcore: registered new interface driver usbhid
Jul 23 02:01:12 EMB3 kernel: [ 4.826638] usbhid: USB HID core driver
Jul 23 02:01:12 EMB3 kernel: [ 4.828301] usb usb4-port1: over-current condition
Jul 23 02:01:12 EMB3 kernel: [ 4.831116] No fsl,qman node
Jul 23 02:01:12 EMB3 kernel: [ 4.838126] Freescale USDPAA process driver
Jul 23 02:01:12 EMB3 kernel: [ 4.842307] fsl-usdpaa: no region found
Jul 23 02:01:12 EMB3 kernel: [ 4.846135] Freescale USDPAA process IRQ driver
Jul 23 02:01:12 EMB3 kernel: [ 4.851868] optee: probing for conduit method from DT.
Jul 23 02:01:12 EMB3 kernel: [ 4.857002] optee: api uid mismatch
Jul 23 02:01:12 EMB3 kernel: [ 4.860928] fpga-spi spi1.0: ********fpga_spi_probe********
Jul 23 02:01:12 EMB3 kernel: [ 4.866493] fpga-spi spi1.0: FPGA SPI protocol lsb first (emb3)
Jul 23 02:01:12 EMB3 kernel: [ 4.872412] fpga-spi spi1.0: cs from DT: 0
Jul 23 02:01:12 EMB3 kernel: [ 4.876501] fpga_ioport_init
Jul 23 02:01:12 EMB3 kernel: [ 4.879428] fpga_misc_init
Jul 23 02:01:12 EMB3 kernel: [ 4.882264] ********gnss uart driver probed********
Jul 23 02:01:12 EMB3 kernel: [ 4.887138] gnss_probe: gnss tty_id is 1
Jul 23 02:01:12 EMB3 kernel: [ 4.891233] ********hspc ptp spi driver probed mode [3]********
Jul 23 02:01:12 EMB3 kernel: [ 4.897145] ********hspc ptp spi irq gpio probed ********
Jul 23 02:01:12 EMB3 kernel: [ 4.902558] acs9521 spi1.2: ptp slave_int gpio pin: 426
Jul 23 02:01:12 EMB3 kernel: [ 4.907775] acs9521 spi1.2: cs from DT: 2
Jul 23 02:01:12 EMB3 kernel: [ 4.911872] ********SFP driver probed********
Jul 23 02:01:12 EMB3 kernel: [ 4.916312] sfp 0-0050: probe ok!
Jul 23 02:01:12 EMB3 kernel: [ 4.919645] ********SFP driver probed********
Jul 23 02:01:12 EMB3 kernel: [ 4.924073] sfp 1-0050: probe ok!
Jul 23 02:01:12 EMB3 kernel: [ 4.927411] ********SFP driver probed********
Jul 23 02:01:12 EMB3 kernel: [ 4.931836] sfp 3-0050: probe ok!
Jul 23 02:01:12 EMB3 kernel: [ 4.935215] ********pxe1610 driver probed********
Jul 23 02:01:12 EMB3 kernel: [ 4.941837] NET: Registered protocol family 26
Jul 23 02:01:12 EMB3 kernel: [ 4.946294] u32 classifier
Jul 23 02:01:12 EMB3 kernel: [ 4.948998] input device check on
Jul 23 02:01:12 EMB3 kernel: [ 4.952653] Actions configured
Jul 23 02:01:12 EMB3 kernel: [ 4.956512] Initializing XFRM netlink socket
Jul 23 02:01:12 EMB3 kernel: [ 4.960829] NET: Registered protocol family 10
Jul 23 02:01:12 EMB3 kernel: [ 4.965630] Segment Routing with IPv6
Jul 23 02:01:12 EMB3 kernel: [ 4.969322] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
Jul 23 02:01:12 EMB3 kernel: [ 4.975432] NET: Registered protocol family 17
Jul 23 02:01:12 EMB3 kernel: [ 4.979877] NET: Registered protocol family 15
Jul 23 02:01:12 EMB3 kernel: [ 4.984337] Bridge firewalling registered
Jul 23 02:01:12 EMB3 kernel: [ 4.988461] 8021q: 802.1Q VLAN Support v1.8
Jul 23 02:01:12 EMB3 kernel: [ 4.992650] lib80211: common routines for IEEE802.11 drivers
Jul 23 02:01:12 EMB3 kernel: [ 4.998335] 9pnet: Installing 9P2000 support
Jul 23 02:01:12 EMB3 kernel: [ 5.002619] tsn generic netlink module v1 init...
Jul 23 02:01:12 EMB3 kernel: [ 5.007340] Key type dns_resolver registered
Jul 23 02:01:12 EMB3 kernel: [ 5.011806] registered taskstats version 1
Jul 23 02:01:12 EMB3 kernel: [ 5.015897] Loading compiled-in X.509 certificates
Jul 23 02:01:12 EMB3 kernel: [ 5.021502] Btrfs loaded, crc32c=crc32c-generic
Jul 23 02:01:12 EMB3 kernel: [ 5.027303] fsl_mc_dprc dprc.1: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.158595] fsl_dpaa2_eth dpni.9: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.164085] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
Jul 23 02:01:12 EMB3 kernel: [ 5.170489] fsl_dpaa2_eth dpni.8: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.175944] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
Jul 23 02:01:12 EMB3 kernel: [ 5.182337] fsl_dpaa2_eth dpni.7: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.187791] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
Jul 23 02:01:12 EMB3 kernel: [ 5.194184] fsl_dpaa2_eth dpni.6: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.199639] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
Jul 23 02:01:12 EMB3 kernel: [ 5.206033] fsl_dpaa2_eth dpni.5: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.211487] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
Jul 23 02:01:12 EMB3 kernel: [ 5.217879] fsl_dpaa2_eth dpni.4: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.223332] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
Jul 23 02:01:12 EMB3 kernel: [ 5.229722] fsl_dpaa2_eth dpni.3: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.235174] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
Jul 23 02:01:12 EMB3 kernel: [ 5.241566] fsl_dpaa2_eth dpni.2: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.247019] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
Jul 23 02:01:12 EMB3 kernel: [ 5.253408] fsl_dpaa2_eth dpni.1: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.258860] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
Jul 23 02:01:12 EMB3 kernel: [ 5.265252] fsl_dpaa2_eth dpni.0: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.270703] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
Jul 23 02:01:12 EMB3 kernel: [ 5.277101] fsl_mc_allocator dpbp.9: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.282800] fsl_mc_allocator dpbp.8: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.288499] fsl_mc_allocator dpbp.7: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.294194] fsl_mc_allocator dpbp.6: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.299888] fsl_mc_allocator dpbp.5: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.305584] fsl_mc_allocator dpbp.4: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.311279] fsl_mc_allocator dpbp.3: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.316974] fsl_mc_allocator dpbp.2: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.322669] fsl_mc_allocator dpbp.1: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.328365] fsl_mc_allocator dpbp.0: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.334064] dpaa2_mac dpmac.18: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.339292] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
Jul 23 02:01:12 EMB3 kernel: [ 5.345681] dpaa2_mac dpmac.17: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.350907] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
Jul 23 02:01:12 EMB3 kernel: [ 5.357290] dpaa2_mac dpmac.16: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.362518] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
Jul 23 02:01:12 EMB3 kernel: [ 5.368905] dpaa2_mac dpmac.14: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.374132] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
Jul 23 02:01:12 EMB3 kernel: [ 5.380517] dpaa2_mac dpmac.13: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.385748] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
Jul 23 02:01:12 EMB3 kernel: [ 5.392136] dpaa2_mac dpmac.12: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.397364] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
Jul 23 02:01:12 EMB3 kernel: [ 5.403748] dpaa2_mac dpmac.6: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.408889] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
Jul 23 02:01:12 EMB3 kernel: [ 5.415274] dpaa2_mac dpmac.5: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.420416] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
Jul 23 02:01:12 EMB3 kernel: [ 5.426801] dpaa2_mac dpmac.4: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.431942] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
Jul 23 02:01:12 EMB3 kernel: [ 5.438331] dpaa2_mac dpmac.3: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.443470] fsl_mc_dprc dprc.1: No more resources of type dpmcp left
Jul 23 02:01:12 EMB3 kernel: [ 5.450871] fsl_mc_allocator dpmcp.63: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.457750] fsl_mc_allocator dpmcp.62: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.464636] fsl_mc_allocator dpmcp.61: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.471513] fsl_mc_allocator dpmcp.60: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.478394] fsl_mc_allocator dpmcp.59: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.485284] fsl_mc_allocator dpmcp.58: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.492159] fsl_mc_allocator dpmcp.57: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.499038] fsl_mc_allocator dpmcp.56: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.505921] fsl_mc_allocator dpmcp.55: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.512805] fsl_mc_allocator dpmcp.54: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.519682] fsl_mc_allocator dpmcp.53: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.526563] fsl_mc_allocator dpmcp.52: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.533446] fsl_mc_allocator dpmcp.51: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.540331] fsl_mc_allocator dpmcp.50: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.547207] fsl_mc_allocator dpmcp.49: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.554087] fsl_mc_allocator dpmcp.48: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.560973] fsl_mc_allocator dpmcp.47: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.567852] fsl_mc_allocator dpmcp.46: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.574731] fsl_mc_allocator dpmcp.45: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.581613] fsl_mc_allocator dpmcp.44: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.588502] fsl_mc_allocator dpmcp.43: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.595378] fsl_mc_allocator dpmcp.42: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.602257] fsl_mc_allocator dpmcp.41: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.609147] fsl_mc_allocator dpmcp.40: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.616026] fsl_mc_allocator dpmcp.39: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.622905] fsl_mc_allocator dpmcp.38: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.629788] fsl_mc_allocator dpmcp.37: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.636674] fsl_mc_allocator dpmcp.36: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.643553] fsl_mc_allocator dpmcp.35: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.650432] fsl_mc_allocator dpmcp.34: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.657319] fsl_mc_allocator dpmcp.33: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.664200] fsl_mc_allocator dpmcp.32: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.671079] fsl_mc_allocator dpmcp.31: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.677958] fsl_mc_allocator dpmcp.30: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.684842] fsl_mc_allocator dpmcp.29: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.691724] fsl_mc_allocator dpmcp.28: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.698604] fsl_mc_allocator dpmcp.27: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.705485] fsl_mc_allocator dpmcp.26: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.712368] fsl_mc_allocator dpmcp.25: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.719251] fsl_mc_allocator dpmcp.24: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.726134] fsl_mc_allocator dpmcp.23: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.733019] fsl_mc_allocator dpmcp.22: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.739900] fsl_mc_allocator dpmcp.21: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.746782] fsl_mc_allocator dpmcp.20: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.753662] fsl_mc_allocator dpmcp.19: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.760549] fsl_mc_allocator dpmcp.18: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.767432] fsl_mc_allocator dpmcp.17: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.774315] fsl_mc_allocator dpmcp.16: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.781201] fsl_mc_allocator dpmcp.15: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.788083] fsl_mc_allocator dpmcp.14: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.794965] fsl_mc_allocator dpmcp.13: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.801849] fsl_mc_allocator dpmcp.12: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.808736] fsl_mc_allocator dpmcp.11: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.815618] fsl_mc_allocator dpmcp.10: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.822501] fsl_mc_allocator dpmcp.9: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.829338] fsl_mc_allocator dpmcp.8: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.836135] fsl_mc_allocator dpmcp.7: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.842937] fsl_mc_allocator dpmcp.6: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.849735] fsl_mc_allocator dpmcp.5: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.856542] fsl_mc_allocator dpmcp.4: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.863337] fsl_mc_allocator dpmcp.3: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.870134] fsl_mc_allocator dpmcp.2: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.876938] fsl_mc_allocator dpmcp.1: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.882732] fsl_dpaa2_ptp dprtc.0: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.890551] [DPAA2 TSU] : Time counter init
Jul 23 02:01:12 EMB3 kernel: [ 5.895026] pps pps0: new PPS source ptp0
Jul 23 02:01:12 EMB3 kernel: [ 5.902204] fsl_mc_dpio dpio.15: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.911176] fsl_mc_dpio dpio.15: probed
Jul 23 02:01:12 EMB3 kernel: [ 5.918725] fsl_mc_dpio dpio.14: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.927682] fsl_mc_dpio dpio.14: probed
Jul 23 02:01:12 EMB3 kernel: [ 5.935240] fsl_mc_dpio dpio.13: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.944168] fsl_mc_dpio dpio.13: probed
Jul 23 02:01:12 EMB3 kernel: [ 5.951608] fsl_mc_dpio dpio.12: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.960557] fsl_mc_dpio dpio.12: probed
Jul 23 02:01:12 EMB3 kernel: [ 5.967990] fsl_mc_dpio dpio.11: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.976937] fsl_mc_dpio dpio.11: probed
Jul 23 02:01:12 EMB3 kernel: [ 5.984383] fsl_mc_dpio dpio.10: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 5.993320] fsl_mc_dpio dpio.10: probed
Jul 23 02:01:12 EMB3 kernel: [ 6.000766] fsl_mc_dpio dpio.9: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.009566] fsl_mc_dpio dpio.9: probed
Jul 23 02:01:12 EMB3 kernel: [ 6.016945] fsl_mc_dpio dpio.8: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.025785] fsl_mc_dpio dpio.8: probed
Jul 23 02:01:12 EMB3 kernel: [ 6.033233] fsl_mc_dpio dpio.7: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.042050] fsl_mc_dpio dpio.7: probed
Jul 23 02:01:12 EMB3 kernel: [ 6.049428] fsl_mc_dpio dpio.6: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.058265] fsl_mc_dpio dpio.6: probed
Jul 23 02:01:12 EMB3 kernel: [ 6.065682] fsl_mc_dpio dpio.5: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.074504] fsl_mc_dpio dpio.5: probed
Jul 23 02:01:12 EMB3 kernel: [ 6.081867] fsl_mc_dpio dpio.4: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.090716] fsl_mc_dpio dpio.4: probed
Jul 23 02:01:12 EMB3 kernel: [ 6.098123] fsl_mc_dpio dpio.3: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.106943] fsl_mc_dpio dpio.3: probed
Jul 23 02:01:12 EMB3 kernel: [ 6.114313] fsl_mc_dpio dpio.2: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.123152] fsl_mc_dpio dpio.2: probed
Jul 23 02:01:12 EMB3 kernel: [ 6.130565] fsl_mc_dpio dpio.1: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.139386] fsl_mc_dpio dpio.1: probed
Jul 23 02:01:12 EMB3 kernel: [ 6.146747] fsl_mc_dpio dpio.0: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.155594] fsl_mc_dpio dpio.0: probed
Jul 23 02:01:12 EMB3 kernel: [ 6.159965] fsl_mc_allocator dpcon.127: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.166010] fsl_mc_allocator dpcon.126: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.172044] fsl_mc_allocator dpcon.125: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.178082] fsl_mc_allocator dpcon.124: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.184119] fsl_mc_allocator dpcon.123: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.190160] fsl_mc_allocator dpcon.122: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.196199] fsl_mc_allocator dpcon.121: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.202234] fsl_mc_allocator dpcon.120: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.208283] fsl_mc_allocator dpcon.119: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.214320] fsl_mc_allocator dpcon.118: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.220365] fsl_mc_allocator dpcon.117: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.226405] fsl_mc_allocator dpcon.116: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.232443] fsl_mc_allocator dpcon.115: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.238488] fsl_mc_allocator dpcon.114: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.244528] fsl_mc_allocator dpcon.113: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.250567] fsl_mc_allocator dpcon.112: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.256606] fsl_mc_allocator dpcon.111: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.262647] fsl_mc_allocator dpcon.110: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.268687] fsl_mc_allocator dpcon.109: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.274728] fsl_mc_allocator dpcon.108: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.280767] fsl_mc_allocator dpcon.107: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.286810] fsl_mc_allocator dpcon.106: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.292851] fsl_mc_allocator dpcon.105: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.298893] fsl_mc_allocator dpcon.104: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.304935] fsl_mc_allocator dpcon.103: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.310978] fsl_mc_allocator dpcon.102: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.317019] fsl_mc_allocator dpcon.101: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.323061] fsl_mc_allocator dpcon.100: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.329106] fsl_mc_allocator dpcon.99: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.335068] fsl_mc_allocator dpcon.98: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.341022] fsl_mc_allocator dpcon.97: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.346979] fsl_mc_allocator dpcon.96: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.352937] fsl_mc_allocator dpcon.95: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.358897] fsl_mc_allocator dpcon.94: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.364859] fsl_mc_allocator dpcon.93: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.370820] fsl_mc_allocator dpcon.92: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.376774] fsl_mc_allocator dpcon.91: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.382736] fsl_mc_allocator dpcon.90: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.388693] fsl_mc_allocator dpcon.89: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.394653] fsl_mc_allocator dpcon.88: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.400621] fsl_mc_allocator dpcon.87: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.406582] fsl_mc_allocator dpcon.86: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.412542] fsl_mc_allocator dpcon.85: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.418504] fsl_mc_allocator dpcon.84: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.424462] fsl_mc_allocator dpcon.83: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.430426] fsl_mc_allocator dpcon.82: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.436392] fsl_mc_allocator dpcon.81: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.442351] fsl_mc_allocator dpcon.80: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.448324] fsl_mc_allocator dpcon.79: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.454286] fsl_mc_allocator dpcon.78: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.460249] fsl_mc_allocator dpcon.77: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.466215] fsl_mc_allocator dpcon.76: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.472175] fsl_mc_allocator dpcon.75: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.478143] fsl_mc_allocator dpcon.74: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.484107] fsl_mc_allocator dpcon.73: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.490068] fsl_mc_allocator dpcon.72: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.496039] fsl_mc_allocator dpcon.71: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.502005] fsl_mc_allocator dpcon.70: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.507968] fsl_mc_allocator dpcon.69: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.513935] fsl_mc_allocator dpcon.68: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.519900] fsl_mc_allocator dpcon.67: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.525869] fsl_mc_allocator dpcon.66: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.531834] fsl_mc_allocator dpcon.65: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.537801] fsl_mc_allocator dpcon.64: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.543767] fsl_mc_allocator dpcon.63: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.549736] fsl_mc_allocator dpcon.62: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.555704] fsl_mc_allocator dpcon.61: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.561672] fsl_mc_allocator dpcon.60: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.567640] fsl_mc_allocator dpcon.59: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.573613] fsl_mc_allocator dpcon.58: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.579581] fsl_mc_allocator dpcon.57: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.585550] fsl_mc_allocator dpcon.56: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.591519] fsl_mc_allocator dpcon.55: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.597492] fsl_mc_allocator dpcon.54: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.603462] fsl_mc_allocator dpcon.53: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.609432] fsl_mc_allocator dpcon.52: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.615402] fsl_mc_allocator dpcon.51: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.621382] fsl_mc_allocator dpcon.50: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.627350] fsl_mc_allocator dpcon.49: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.633321] fsl_mc_allocator dpcon.48: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.639294] fsl_mc_allocator dpcon.47: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.645265] fsl_mc_allocator dpcon.46: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.651237] fsl_mc_allocator dpcon.45: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.657209] fsl_mc_allocator dpcon.44: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.663182] fsl_mc_allocator dpcon.43: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.669168] fsl_mc_allocator dpcon.42: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.675139] fsl_mc_allocator dpcon.41: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.681112] fsl_mc_allocator dpcon.40: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.687087] fsl_mc_allocator dpcon.39: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.693062] fsl_mc_allocator dpcon.38: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.699036] fsl_mc_allocator dpcon.37: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.705012] fsl_mc_allocator dpcon.36: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.710984] fsl_mc_allocator dpcon.35: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.716964] fsl_mc_allocator dpcon.34: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.722940] fsl_mc_allocator dpcon.33: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.728919] fsl_mc_allocator dpcon.32: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.734897] fsl_mc_allocator dpcon.31: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.740876] fsl_mc_allocator dpcon.30: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.746852] fsl_mc_allocator dpcon.29: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.752837] fsl_mc_allocator dpcon.28: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.758811] fsl_mc_allocator dpcon.27: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.764796] fsl_mc_allocator dpcon.26: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.770775] fsl_mc_allocator dpcon.25: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.776752] fsl_mc_allocator dpcon.24: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.782732] fsl_mc_allocator dpcon.23: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.788712] fsl_mc_allocator dpcon.22: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.794690] fsl_mc_allocator dpcon.21: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.800673] fsl_mc_allocator dpcon.20: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.806653] fsl_mc_allocator dpcon.19: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.812637] fsl_mc_allocator dpcon.18: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.818618] fsl_mc_allocator dpcon.17: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.824599] fsl_mc_allocator dpcon.16: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.830581] fsl_mc_allocator dpcon.15: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.836565] fsl_mc_allocator dpcon.14: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.842544] fsl_mc_allocator dpcon.13: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.848529] fsl_mc_allocator dpcon.12: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.854510] fsl_mc_allocator dpcon.11: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.860497] fsl_mc_allocator dpcon.10: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.866483] fsl_mc_allocator dpcon.9: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.872390] fsl_mc_allocator dpcon.8: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.878288] fsl_mc_allocator dpcon.7: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.884192] fsl_mc_allocator dpcon.6: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.890090] fsl_mc_allocator dpcon.5: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.895988] fsl_mc_allocator dpcon.4: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.901887] fsl_mc_allocator dpcon.3: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.907791] fsl_mc_allocator dpcon.2: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.913689] fsl_mc_allocator dpcon.1: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.919589] fsl_mc_allocator dpcon.0: Adding to iommu group 6
Jul 23 02:01:12 EMB3 kernel: [ 6.928548] fsl_mc_dprc dprc.1: DPRC device bound to driver
Jul 23 02:01:12 EMB3 kernel: [ 6.934257] pcieport 0000:00:00.0: Adding to iommu group 7
Jul 23 02:01:12 EMB3 kernel: [ 6.939851] pcieport 0000:00:00.0: PME: Signaling with IRQ 32
Jul 23 02:01:12 EMB3 kernel: [ 6.945720] pcieport 0000:00:00.0: AER: enabled with IRQ 32
Jul 23 02:01:12 EMB3 kernel: [ 6.951379] pcieport 0001:00:00.0: Adding to iommu group 8
Jul 23 02:01:12 EMB3 kernel: [ 6.956949] pcieport 0001:00:00.0: PME: Signaling with IRQ 33
Jul 23 02:01:12 EMB3 kernel: [ 6.962808] pcieport 0001:00:00.0: AER: enabled with IRQ 33
Jul 23 02:01:12 EMB3 kernel: [ 6.968464] pcieport 0002:00:00.0: Adding to iommu group 9
Jul 23 02:01:12 EMB3 kernel: [ 6.974030] pcieport 0002:00:00.0: PME: Signaling with IRQ 34
Jul 23 02:01:12 EMB3 kernel: [ 6.979885] pcieport 0002:00:00.0: AER: enabled with IRQ 34
Jul 23 02:01:12 EMB3 kernel: [ 7.135641] fsl_dpaa2_eth dpni.9: Probed interface eth0
Jul 23 02:01:12 EMB3 kernel: [ 7.289938] fsl_dpaa2_eth dpni.8: Probed interface eth1
Jul 23 02:01:12 EMB3 kernel: [ 7.444123] fsl_dpaa2_eth dpni.7: Probed interface eth2
Jul 23 02:01:12 EMB3 kernel: [ 7.538334] fsl_dpaa2_eth dpni.6: Probed interface eth3
Jul 23 02:01:12 EMB3 kernel: [ 7.633028] fsl_dpaa2_eth dpni.5: Probed interface eth4
Jul 23 02:01:12 EMB3 kernel: [ 7.788829] fsl_dpaa2_eth dpni.4: Probed interface eth5
Jul 23 02:01:12 EMB3 kernel: [ 7.943026] fsl_dpaa2_eth dpni.3: Probed interface eth6
Jul 23 02:01:12 EMB3 kernel: [ 8.097820] fsl_dpaa2_eth dpni.2: Probed interface eth7
Jul 23 02:01:12 EMB3 kernel: [ 8.191934] fsl_dpaa2_eth dpni.1: Probed interface eth8
Jul 23 02:01:12 EMB3 kernel: [ 8.286102] fsl_dpaa2_eth dpni.0: Probed interface eth9
Jul 23 02:01:12 EMB3 kernel: [ 8.295593] dpaa2_mac dpmac.18: FROM DT: using if mode sgmii for eth_if 5
Jul 23 02:01:12 EMB3 kernel: [ 8.304770] dpaa2_mac dpmac.18: Registered fixed PHY.
Jul 23 02:01:12 EMB3 kernel: [ 8.313486] dpaa2_mac dpmac.17: FROM DT: using if mode rgmii for eth_if 4
Jul 23 02:01:12 EMB3 kernel: [ 8.322419] dpaa2_mac dpmac.17: Registered fixed PHY.
Jul 23 02:01:12 EMB3 kernel: [ 8.331673] dpaa2_mac dpmac.16: FROM DT: using if mode sgmii for eth_if 5
Jul 23 02:01:12 EMB3 kernel: [ 8.339992] dpaa2_mac dpmac.16: Registered fixed PHY.
Jul 23 02:01:12 EMB3 kernel: [ 8.349214] dpaa2_mac dpmac.14: FROM DT: using if mode sgmii for eth_if 5
Jul 23 02:01:12 EMB3 kernel: [ 8.357990] dpaa2_mac dpmac.14: Registered fixed PHY.
Jul 23 02:01:12 EMB3 kernel: [ 8.367227] dpaa2_mac dpmac.13: FROM DT: using if mode sgmii for eth_if 5
Jul 23 02:01:12 EMB3 kernel: [ 8.376048] dpaa2_mac dpmac.13: Registered fixed PHY.
Jul 23 02:01:12 EMB3 kernel: [ 8.385257] dpaa2_mac dpmac.12: FROM DT: using if mode sgmii for eth_if 5
Jul 23 02:01:12 EMB3 kernel: [ 8.393856] dpaa2_mac dpmac.12: Registered fixed PHY.
Jul 23 02:01:12 EMB3 kernel: [ 8.403108] dpaa2_mac dpmac.6: FROM MC: using if mode xgmii for eth_if 8
Jul 23 02:01:12 EMB3 kernel: [ 8.411319] dpaa2_mac dpmac.6: Registered fixed PHY.
Jul 23 02:01:12 EMB3 kernel: [ 8.420482] dpaa2_mac dpmac.5: FROM MC: using if mode xgmii for eth_if 8
Jul 23 02:01:12 EMB3 kernel: [ 8.428671] dpaa2_mac dpmac.5: Registered fixed PHY.
Jul 23 02:01:12 EMB3 kernel: [ 8.437312] dpaa2_mac dpmac.4: FROM MC: using if mode xgmii for eth_if 8
Jul 23 02:01:12 EMB3 kernel: [ 8.445810] dpaa2_mac dpmac.4: Registered fixed PHY.
Jul 23 02:01:12 EMB3 kernel: [ 8.455018] dpaa2_mac dpmac.3: FROM MC: using if mode xgmii for eth_if 8
Jul 23 02:01:12 EMB3 kernel: [ 8.463214] dpaa2_mac dpmac.3: Registered fixed PHY.
Jul 23 02:01:12 EMB3 kernel: [ 8.468607] hctosys: unable to open rtc device (rtc0)
Jul 23 02:01:12 EMB3 kernel: [ 8.473935] ALSA device list:
Jul 23 02:01:12 EMB3 kernel: [ 8.476920] No soundcards found.
Jul 23 02:01:12 EMB3 kernel: [ 8.481751] Freeing unused kernel memory: 5888K
Jul 23 02:01:12 EMB3 kernel: [ 8.512347] Run /init as init process
Jul 23 02:01:12 EMB3 kernel: [ 8.654644] random: udevd: uninitialized urandom read (16 bytes read)
Jul 23 02:01:12 EMB3 kernel: [ 8.661145] random: udevd: uninitialized urandom read (16 bytes read)
Jul 23 02:01:12 EMB3 kernel: [ 8.667622] random: udevd: uninitialized urandom read (16 bytes read)
Jul 23 02:01:12 EMB3 kernel: [ 11.220404] switch cluster 0 cpu-freq governor to schedutil
Jul 23 02:01:12 EMB3 kernel: [ 11.252399] switch cluster 1 cpu-freq governor to schedutil
Jul 23 02:01:12 EMB3 kernel: [ 12.124150] random: crng init done
Jul 23 02:01:12 EMB3 kernel: [ 12.129825] random: 5 urandom warning(s) missed due to ratelimiting
Jul 23 02:01:12 EMB3 kernel: [ 12.551190] EXT4-fs (mmcblk0p1): recovery complete
Jul 23 02:01:12 EMB3 kernel: [ 12.558490] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
Jul 23 02:01:12 EMB3 kernel: [ 12.775037] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
Jul 23 02:01:16 EMB3 kernel: [ 16.521241] dal: loading out-of-tree module taints kernel.
Jul 23 02:01:16 EMB3 kernel: [ 16.529864] linux_dal 0001:01:00.0: Adding to iommu group 8
Jul 23 02:01:16 EMB3 kernel: [ 16.538088] PCIe dal driver probe
Jul 23 02:01:16 EMB3 kernel: [ 16.544067] use bar2 to config memory space
Jul 23 02:01:16 EMB3 kernel: [ 16.544111] enable PCI device: vendor id = cb10, device id = 5236
Jul 23 02:01:16 EMB3 kernel: [ 16.559899] Little endian Cpu detected!!!
Jul 23 02:01:16 EMB3 kernel: [ 16.570014] dma_phy_base[lchip] 0xe7d00000 dma_virt_base[lchip] 00000000c746039e
Jul 23 02:01:16 EMB3 kernel: [ 16.579764] ########Using DMA_MEM_MODE_PLATFORM
Jul 23 02:01:16 EMB3 kernel: [ 16.587134] Dal chip 0 found, Device Id: 0x52360f83
Jul 23 02:01:16 EMB3 kernel: [ 16.594941] Dal initialized done: cdev: linux_dal, major: 198, dma_size= 0x2000000
Jul 23 02:01:16 EMB3 kernel: [ 16.612088] dal dma phy addr: 0xe7d00000, virt addr: 00000000c746039e.
Jul 23 02:01:19 EMB3 kernel: [ 19.309930] ####dal_set_msi_cap lchip 0 base 0 num:1
Jul 23 02:01:19 EMB3 kernel: [ 19.315125] ####register interrupt irq:375
Jul 23 02:01:21 EMB3 kernel: [ 21.635469] fsl_dpaa2_eth dpni.9 eth0: Link Event: state up
Jul 23 02:01:21 EMB3 kernel: [ 21.635964] fsl_dpaa2_eth dpni.9 eth0: Link Event: state up
Jul 23 02:01:21 EMB3 kernel: [ 21.682174] fsl_dpaa2_eth dpni.8 eth1: Link Event: state up
Jul 23 02:01:21 EMB3 kernel: [ 21.682671] fsl_dpaa2_eth dpni.8 eth1: Link Event: state up
Jul 23 02:01:21 EMB3 kernel: [ 21.728150] fsl_dpaa2_eth dpni.7 eth2: Link Event: state up
Jul 23 02:01:21 EMB3 kernel: [ 21.728650] fsl_dpaa2_eth dpni.7 eth2: Link Event: state up
Jul 23 02:01:21 EMB3 kernel: [ 21.761899] fsl_dpaa2_eth dpni.6 eth3: Link Event: state up
Jul 23 02:01:21 EMB3 kernel: [ 21.762397] fsl_dpaa2_eth dpni.6 eth3: Link Event: state up
Jul 23 02:01:21 EMB3 kernel: [ 21.845055] fsl_dpaa2_eth dpni.4 eth5: Link Event: state up
Jul 23 02:01:21 EMB3 kernel: [ 21.845547] fsl_dpaa2_eth dpni.4 eth5: Link Event: state up
Jul 23 02:01:21 EMB3 kernel: [ 21.890689] fsl_dpaa2_eth dpni.3 eth6: Link Event: state up
Jul 23 02:01:21 EMB3 kernel: [ 21.891184] fsl_dpaa2_eth dpni.3 eth6: Link Event: state up
Jul 23 02:01:22 EMB3 kernel: [ 22.001912] rsmu-cdev 8a3400x-cdev.3.auto: Probe rsmu0 successful
Jul 23 02:01:22 EMB3 kernel: [ 22.024081] 8a3400x-phc 8a3400x-phc.2.auto: 5.2.2, Id: 0x4005 HW Rev: 4 OTP Config Select: 6
Jul 23 02:01:22 EMB3 kernel: [ 22.032715] 8a3400x-phc 8a3400x-phc.2.auto: requesting firmware 'idtcm.bin'
Jul 23 02:01:22 EMB3 kernel: [ 22.059703] 8a3400x-phc 8a3400x-phc.2.auto: PLL0 registered as ptp1
Jul 23 02:01:34 EMB3 kernel: [ 34.649445] sched: RT throttling activated
Jul 23 02:01:34 EMB3 kernel: [ 34.649572] fsl_dpaa2_eth dpni.3 eth6: dpni_set_taildrop(FQ) failed
Jul 23 02:01:40 EMB3 kernel: [ 34.659931] fsl_dpaa2_eth dpni.3 eth6: Link Event: state down
Jul 23 02:01:48 EMB3 kernel: [ 48.824267] rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
Jul 23 02:01:48 EMB3 kernel: [ 48.830365] rcu: 0-....: (6 ticks this GP) idle=652/1/0x4000000000000000 softirq=876/876 fqs=2619
Jul 23 02:01:48 EMB3 kernel: [ 48.839401] (detected by 12, t=5255 jiffies, g=1761, q=649)
Jul 23 02:01:48 EMB3 kernel: [ 48.845047] Task dump for CPU 0:
Jul 23 02:01:48 EMB3 kernel: [ 48.848263] irq/140-dpni.3 R running task 0 461 2 0x0000000a
Jul 23 02:01:48 EMB3 kernel: [ 48.855300] Call trace:
Jul 23 02:01:48 EMB3 kernel: [ 48.857744] __switch_to+0x1d0/0x2a0
Jul 23 02:01:48 EMB3 kernel: [ 48.861307] 0xffff0026d2940000
Jul 23 02:02:00 EMB3 kernel: [ 60.593716] sh (1852): drop_caches: 3
Jul 23 02:02:22 EMB3 kernel: [ 82.608262] rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
Jul 23 02:02:22 EMB3 kernel: [ 82.614349] rcu: 3-....: (1 GPs behind) idle=18a/1/0x4000000000000000 softirq=1123/1123 fqs=1998
Jul 23 02:02:22 EMB3 kernel: [ 82.623295] (detected by 2, t=5255 jiffies, g=1865, q=730)
Jul 23 02:02:22 EMB3 kernel: [ 82.628854] Task dump for CPU 3:
Jul 23 02:02:22 EMB3 kernel: [ 82.632070] ifconfig R running task 0 1984 1034 0x00000002
Jul 23 02:02:22 EMB3 kernel: [ 82.639107] Call trace:
Jul 23 02:02:22 EMB3 kernel: [ 82.641549] ret_from_fork+0x0/0x18
Jul 23 02:02:59 EMB3 kernel: [ 119.412262] rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
Jul 23 02:02:59 EMB3 kernel: [ 119.418349] rcu: 4-....: (1 GPs behind) idle=0ae/1/0x4000000000000000 softirq=882/883 fqs=2167
Jul 23 02:02:59 EMB3 kernel: [ 119.427124] (detected by 1, t=5252 jiffies, g=1869, q=1368)
Jul 23 02:02:59 EMB3 kernel: [ 119.432770] Task dump for CPU 4:
Jul 23 02:02:59 EMB3 kernel: [ 119.435988] ifconfig R running task 0 2007 1034 0x00000002
Jul 23 02:02:59 EMB3 kernel: [ 119.443029] Call trace:
Jul 23 02:02:59 EMB3 kernel: [ 119.445473] ret_from_fork+0x0/0x18
Jul 23 02:03:00 EMB3 kernel: [ 120.564371] sh (2019): drop_caches: 3
Aug 17 13:37:54 EMB3 kernel: [ 198.044261] rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
Aug 17 13:37:54 EMB3 kernel: [ 198.050349] rcu: 15-....: (1 GPs behind) idle=c56/1/0x4000000000000000 softirq=1303/1304 fqs=2626
Aug 17 13:37:54 EMB3 kernel: [ 198.059382] (detected by 14, t=5255 jiffies, g=9765, q=28021)
Aug 17 13:37:54 EMB3 kernel: [ 198.065201] Task dump for CPU 15:
Aug 17 13:37:54 EMB3 kernel: [ 198.068504] ptp4l R running task 0 2602 863 0x00000002
Aug 17 13:37:54 EMB3 kernel: [ 198.075541] Call trace:
Aug 17 13:37:54 EMB3 kernel: [ 198.077985] __switch_to+0x1d0/0x2a0
Aug 17 13:37:54 EMB3 kernel: [ 198.081548] 0x22610337000100f9
Aug 17 13:38:00 EMB3 kernel: [ 204.694649] sh (2780): drop_caches: 3
Aug 17 13:43:10 EMB3 kernel: [ 238.980262] rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
Aug 17 13:43:10 EMB3 kernel: [ 238.986348] rcu: 2-....: (1 GPs behind) idle=ca6/1/0x4000000000000000 softirq=1493/1494 fqs=2626
Aug 17 13:43:10 EMB3 kernel: [ 238.995294] (detected by 6, t=5255 jiffies, g=9769, q=59629)
Aug 17 13:43:10 EMB3 kernel: [ 239.001027] Task dump for CPU 2:
Aug 17 13:43:10 EMB3 kernel: [ 239.004244] ptp4l R running task 0 2602 863 0x00000002
Aug 17 13:43:10 EMB3 kernel: [ 239.011281] Call trace:
Aug 17 13:43:10 EMB3 kernel: [ 239.013724] __switch_to+0x1d0/0x2a0
Aug 17 13:43:10 EMB3 kernel: [ 239.017287] 0xffff0026d120a310
Aug 17 13:43:18 EMB3 kernel: [ 246.968298] rcu: INFO: rcu_preempt detected expedited stalls on CPUs/tasks: { 2-... } 5257 jiffies s: 65 root: 0x4/.
