LSDK20.04-isc-19 Memory Error
ソリューションへジャンプ
2,681件の閲覧回数
Chidananda22
Hi All,
Previously I was using LSDK20.04-isc-09 . All running fine.
Now compiling my application with LSDK20.04-isc-19. Getting issue while pool creation .
It hangs . in GDB i can see stack corrupted .
compared . config and config/defconfig_arm64-dpaa-linuxapp-gcc.
Disabled :
CONFIG_RTE_LA12XX_SOCKET_ID=0
CONFIG_RTE_LA12XX_SOCKET_MAX_SEG=0
Any memory and pool related changes I need to take care in my application.
Please suggest
タグ(1)
2,604件の閲覧回数
Chidananda22
Thanks @LFGP .
Resolved after migrating to isc-23 . All application are up and running .
6 返答(返信)
2,641件の閲覧回数
Chidananda22
Hi @LFGP
Verified with LSDK 21.08 . Same result. Stuck in memory allocation  .
Currently our application working fine with isc-09 . But while migrating to isc-19 it is stuck in memory allocation .
Working Logs
  • fslmc: fslmc_get_container_group(): Container: dprc.2 has VFIO iommu group id = 11
  • fslmc: fslmc_vfio_setup_group(): VFIO Container FD is [0x1D]
  • fslmc: fslmc_map_dma(): --> Map address: 0x140000000, size: 1073741824
  • fslmc: rte_fslmc_vfio_dmamap(): Installed memory callback handler
  • fslmc: rte_fslmc_vfio_dmamap(): Total 1 segments found.
  • fslmc: Unable to map region (errno = 22)
  • fslmc: dpaa2_get_qbman_swp(): New Portal 0x17ffec3c0 (2) affined thread - 2340
  • fslmc: dpaa2_configure_stashing(): Portal= 2  CPU= 3 SDEST= 1
  • fslmc: DPAA Portal=0x17ffec3c0 (2) is affined to thread 2340
  • fslmc: dpaa2_get_qbman_swp(): New Portal 0x17ffe4dc0 (3) affined thread - 2341
  • fslmc: dpaa2_configure_stashing(): Portal= 3  CPU= 2 SDEST= 1
  • fslmc: DPAA Portal=0x17ffe4dc0 (3) is affined to thread 2341
  • fslmc: fslmc_memevent_cb(): Request for alloc, va=0x1c0000000, virt_addr=0x1c0000000, iova=0x1c0000000, map_len=1073741824
  • fslmc: fslmc_map_dma(): --> Map address: 0x1c0000000, size: 1073741824
  • fslmc: fslmc_memevent_cb(): Total Mapped: addr=0x1c0000000, len=1073741824
  • fslmc: dpaa2_get_qbman_swp(): New Portal 0x17ffdd7c0 (4) affined thread - 2338
  • fslmc: dpaa2_configure_stashing(): Portal= 4  CPU= 1 SDEST= 0
  • fslmc: DPAA Portal=0x17ffdd7c0 (4) is affined for eth rx to thread 2338
  • fslmc: fslmc_memevent_cb(): Request for alloc, va=0x200000000, virt_addr=0x200000000, iova=0x200000000, map_len=1073741824
Not working Logs
  • fslmc: fslmc_get_group_id(): GROUP(dprc.2) has VFIO iommu group id = 11
  • fslmc: fslmc_vfio_setup_group(): VFIO GROUP FD is 28
  • fslmc: fslmc_map_dma(): DMA MEM map size(40000000): VA(140000000):IOVA(140000000):PHY(2700000000)
  • fslmc NOTICE: DMA MEM map size(40000000): VA(140000000):IOVA(140000000):PHY(2700000000)
Stuck Here
  • fslmc: fslmc_memevent_cb(): alloc, va=0x180000000, virt=180000000, iova=180000000, len=1073741824
  • fslmc: fslmc_map_dma(): DMA MEM map size(40000000): VA(180000000):IOVA(180000000):PHY(26c0000000)
recompiled again with
No success . If any quick help based on above logs .
2,628件の閲覧回数
LFGP
dear @Chidananda22
please be sure regarding the free space to allocate the DMA.
On the other hand, please set the CONFIG_DEBUG_FS, CONFIG_DMA_API_DEBUG in the Kernel, in order to get out more info about the issue.
could you please share the complete logs for isc-09 and isc-19 as a compressed file.
2,605件の閲覧回数
Chidananda22
Thanks @LFGP .
2,592件の閲覧回数
LFGP
Dear @Chidananda22,
that is a great new, thanks for share your findings.
LFGP
2,641件の閲覧回数
Chidananda22
 thanks @LFGP  for your quick response . I will use 21.08 LSDK and update you ,
2,655件の閲覧回数
LFGP
dear @Chidananda22 ,
there were several updates between  both releases (LSDK20.04-isc-09-Ubuntu 18 and  LSDK20.04-isc-19-Ubuntu20).
You need to upgrade your developer environment. Please considere to use the LSDK21.08 release.
LFGP
%3CLINGO-SUB%20id%3D%22lingo-sub-2161509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELSDK20.04-isc-19%20%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2161509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E7%9A%86%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BB%A5%E5%89%8D%E3%81%AF%3CSPAN%3ELSDK20.04-isc-09%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%99%E3%81%B9%E3%81%A6%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%8F%BE%E5%9C%A8%E3%80%81LSDK20.04-isc-19%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%97%E3%83%BC%E3%83%AB%E3%81%AE%E4%BD%9C%E6%88%90%E4%B8%AD%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%8F%E3%83%B3%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82GDB%20%E3%81%A7%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%8C%E7%A0%B4%E6%90%8D%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%AF%94%E8%BC%83%E3%81%99%E3%82%8B%E3%81%A8%E3%80%82config%20%E3%81%8A%E3%82%88%E3%81%B3%20config%2Fdefconfig_arm64-dpaa-linuxapp-gcc%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%84%A1%E5%8A%B9%20%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3ECONFIG_RTE_LA12XX_%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88ID%3D0%3C%2FP%3E%3CP%3ECONFIG_RTE_LA12XX_SOCKET_MAX_SEG%3D0%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%A8%E3%83%97%E3%83%BC%E3%83%AB%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E5%A4%89%E6%9B%B4%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%94%E6%8F%90%E6%A1%88%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2164530%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LSDK20.04-isc-19%20Memory%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2164530%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F224905%22%20target%3D%22_blank%22%3E%40Chidananda22%3C%2FA%3E%E6%A7%98%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%9D%E3%82%8C%E3%81%AF%E7%B4%A0%E6%99%B4%E3%82%89%E3%81%97%E3%81%84%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%99%E3%80%82%E7%99%BA%E8%A6%8B%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EBR%3CBR%20%2F%3E%20LFGP%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2164383%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LSDK20.04-isc-19%20Memory%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2164383%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203371%22%20target%3D%22_blank%22%3E%40LFGP%3C%2FA%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Eisc-23%20%E3%81%AB%E7%A7%BB%E8%A1%8C%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%AB%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E7%A8%BC%E5%83%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2163032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LSDK20.04-isc-19%20Memory%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2163032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F224905%22%20target%3D%22_blank%22%3E%40Chidananda22%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20DMA%20%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E7%A9%BA%E3%81%8D%E9%A0%98%E5%9F%9F%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%E4%B8%80%E6%96%B9%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%A9%B3%E7%B4%B0%E6%83%85%E5%A0%B1%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A7%20CONFIG_DEBUG_FS%E3%80%81CONFIG_DMA_API_DEBUG%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3Eisc-09%20%E3%81%A8%20isc-19%20%E3%81%AE%E5%AE%8C%E5%85%A8%E3%81%AA%E3%83%AD%E3%82%B0%E3%82%92%E5%9C%A7%E7%B8%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E3%81%97%E3%81%A6%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2162187%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LSDK20.04-isc-19%20Memory%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2162187%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203371%22%20target%3D%22_blank%22%3E%40LFGP%3C%2FA%3E%3C%2FP%3E%3CP%3ELSDK%2021.08%20%E3%81%A7%E6%A4%9C%E8%A8%BC%E6%B8%88%E3%81%BF%E3%80%82%E5%90%8C%E3%81%98%E7%B5%90%E6%9E%9C%E3%81%A7%E3%81%99%E3%80%82%E3%83%A1%E3%83%A2%E3%83%AA%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%A7%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81%E5%BD%93%E7%A4%BE%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%20isc-09%20%E3%81%A7%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81isc-19%20%E3%81%B8%E3%81%AE%E7%A7%BB%E8%A1%8C%E4%B8%AD%E3%81%AB%E3%83%A1%E3%83%A2%E3%83%AA%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%8C%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%9C%E6%A5%AD%E3%83%AD%E3%82%B0%3C%2FP%3E%3CUL%3E%3CLI%3Efslmc%3A%20fslmc_get_container_group()%3A%20%E3%82%B3%E3%83%B3%E3%83%86%E3%83%8A%3A%20dprc.2%20%E3%81%AB%E3%81%AF%20VFIO%20iommu%20%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%20ID%20%3D%2011%20%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%3Efslmc%3A%20fslmc_vfio_setup_group()%3A%20VFIO%E3%82%B3%E3%83%B3%E3%83%86%E3%83%8AFD%E3%81%AF%5B0x1D%5D%E3%81%A7%E3%81%99%3C%2FLI%3E%3CLI%3Efslmc%3A%20fslmc_map_dma()%3A%20--%26gt%3B%20%E3%83%9E%E3%83%83%E3%83%97%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A%200x140000000%E3%80%81%E3%82%B5%E3%82%A4%E3%82%BA%3A%201073741824%3C%2FLI%3E%3CLI%3Efslmc%3A%20rte_fslmc_vfio_dmamap()%3A%20%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%83%BC%3C%2FLI%3E%3CLI%3Efslmc%3A%20rte_fslmc_vfio_dmamap()%3A%20%E5%90%88%E8%A8%88%201%20%E5%80%8B%E3%81%AE%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FLI%3E%3CLI%3Efslmc%3A%20%E9%A0%98%E5%9F%9F%E3%82%92%E3%83%9E%E3%83%83%E3%83%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%20(errno%20%3D%2022)%3C%2FLI%3E%3C%2FUL%3E%3CBR%20%2F%3E%3CUL%3E%3CLI%3Efslmc%3A%20dpaa2_get_qbman_swp()%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%83%9D%E3%83%BC%E3%82%BF%E3%83%AB%200x17ffec3c0%20(2)%20%E9%96%A2%E9%80%A3Thread%20-%202340%3C%2FLI%3E%3CLI%3Efslmc%3A%20dpaa2_configure_stashing()%3A%20%E3%83%9D%E3%83%BC%E3%82%BF%E3%83%AB%3D%202%20CPU%3D%203%20SDEST%3D%201%3C%2FLI%3E%3CLI%3Efslmc%3A%20DPAA%E3%83%9D%E3%83%BC%E3%82%BF%E3%83%AB%3D0x17ffec3c0%20(2)%E3%81%AFThread%202340%E3%81%AB%E9%96%A2%E9%80%A3%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%3Efslmc%3A%20dpaa2_get_qbman_swp()%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%83%9D%E3%83%BC%E3%82%BF%E3%83%AB%200x17ffe4dc0%20(3)%20%E9%96%A2%E9%80%A3Thread%20-%202341%3C%2FLI%3E%3CLI%3Efslmc%3A%20dpaa2_configure_stashing()%3A%20%E3%83%9D%E3%83%BC%E3%82%BF%E3%83%AB%3D%203%20CPU%3D%202%20SDEST%3D%201%3C%2FLI%3E%3CLI%3Efslmc%3A%20DPAA%E3%83%9D%E3%83%BC%E3%82%BF%E3%83%AB%3D0x17ffe4dc0%20(3)%E3%81%AFThread%202341%E3%81%AB%E9%96%A2%E9%80%A3%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%3Efslmc%3A%20fslmc_memevent_cb()%3A%20alloc%20%E3%81%AE%E8%A6%81%E6%B1%82%E3%80%81va%3D0x1c0000000%E3%80%81virt_addr%3D0x1c0000000%E3%80%81iova%3D0x1c0000000%E3%80%81map_len%3D1073741824%3C%2FLI%3E%3CLI%3Efslmc%3A%20fslmc_map_dma()%3A%20--%26gt%3B%20%E3%83%9E%E3%83%83%E3%83%97%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A%200x1c0000000%E3%80%81%E3%82%B5%E3%82%A4%E3%82%BA%3A%201073741824%3C%2FLI%3E%3CLI%3Efslmc%3A%20fslmc_memevent_cb()%3A%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%95%E3%82%8C%E3%81%9F%E5%90%88%E8%A8%88%3A%20addr%3D0x1c0000000%E3%80%81len%3D1073741824%3C%2FLI%3E%3CLI%3Efslmc%3A%20dpaa2_get_qbman_swp()%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%83%9D%E3%83%BC%E3%82%BF%E3%83%AB%200x17ffdd7c0%20(4)%20%E9%96%A2%E9%80%A3Thread%20-%202338%3C%2FLI%3E%3CLI%3Efslmc%3A%20dpaa2_configure_stashing()%3A%20%E3%83%9D%E3%83%BC%E3%82%BF%E3%83%AB%3D%204%20CPU%3D%201%20SDEST%3D%200%3C%2FLI%3E%3CLI%3Efslmc%3A%20DPAA%E3%83%9D%E3%83%BC%E3%82%BF%E3%83%AB%3D0x17ffdd7c0%20(4)%E3%81%AFeth%20rx%E3%81%ABThread%202338%E3%81%A8%E3%81%97%E3%81%A6%E9%96%A2%E9%80%A3%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%3Efslmc%3A%20fslmc_memevent_cb()%3A%20alloc%20%E3%81%AE%E8%A6%81%E6%B1%82%E3%80%81va%3D0x200000000%E3%80%81virt_addr%3D0x200000000%E3%80%81iova%3D0x200000000%E3%80%81map_len%3D1073741824%3C%2FLI%3E%3C%2FUL%3E%3CBR%20%2F%3E%3CP%3E%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%AA%E3%81%84%E3%83%AD%E3%82%B0%3C%2FP%3E%3CUL%3E%3CLI%3Efslmc%3A%20fslmc_get_group_id()%3A%20GROUP(dprc.2)%20%E3%81%AB%E3%81%AF%20VFIO%20iommu%20%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%20ID%20%3D%2011%20%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%3Efslmc%3A%20fslmc_vfio_setup_group()%3A%20VFIO%20%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%20FD%E3%81%AF28%E3%81%A7%E3%81%99%3C%2FLI%3E%3CLI%3Efslmc%3A%20fslmc_map_dma()%3A%20DMA%20MEM%E3%83%9E%E3%83%83%E3%83%97%E3%82%B5%E3%82%A4%E3%82%BA(40000000)%3A%20VA(140000000)%3A%20IOVA(140000000)%3A%20PHY(2700000000)%3C%2FLI%3E%3CLI%3Efslmc%20%E9%80%9A%E7%9F%A5%3A%20DMA%20MEM%20%E3%83%9E%E3%83%83%E3%83%97%20%E3%82%B5%E3%82%A4%E3%82%BA%20(40000000)%3A%20VA%20(140000000)%3A%20IOVA%20(140000000)%3A%20PHY%20(2700000000)%3C%2FLI%3E%3CLI%3Efslmc%3A%20rte_fslmc_vfio_dmamap()%3A%20%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%83%BC%3C%2FLI%3E%3CLI%3Efslmc%3A%20rte_fslmc_vfio_dmamap()%3A%20%E5%90%88%E8%A8%88%201%20%E5%80%8B%E3%81%AE%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSTRONG%3E%3CU%3E%E3%81%93%E3%81%93%E3%81%A7%E7%AB%8B%E3%81%A1%E5%BE%80%E7%94%9F%20%3C%2FU%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3Efslmc%3A%20fslmc_memevent_cb()%3A%20alloc%E3%80%81va%3D0x180000000%E3%80%81virt%3D180000000%E3%80%81iova%3D180000000%E3%80%81len%3D1073741824%3C%2FLI%3E%3CLI%3Efslmc%3A%20fslmc_map_dma()%3A%20DMA%20MEM%E3%83%9E%E3%83%83%E3%83%97%E3%82%B5%E3%82%A4%E3%82%BA(40000000)%3A%20VA(180000000)%3A%20IOVA(180000000)%3A%20PHY(26c0000000)%3C%2FLI%3E%3C%2FUL%3E%3CBR%20%2F%3E%3CP%3E%E5%86%8D%E5%BA%A6%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%A6%3C%2FP%3E%3CP%3ECONFIG_RTE_LA12XX_%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88ID%3D0%3C%2FP%3E%3CP%3ECONFIG_RTE_LA12XX_SOCKET_MAX_SEG%3D0%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%AD%E3%82%B0%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E7%B0%A1%E5%8D%98%E3%81%AA%E3%83%98%E3%83%AB%E3%83%97%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2162176%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LSDK20.04-isc-19%20Memory%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2162176%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%B4%A0%E6%97%A9%E3%81%84%E5%AF%BE%E5%BF%9C%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203371%22%20target%3D%22_blank%22%3E%40LFGP%3C%2FA%3E%20%E3%80%8221.08%20LSDK%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2161637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LSDK20.04-isc-19%20Memory%20Error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2161637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F224905%22%20target%3D%22_blank%22%3E%40Chidananda22%3C%2FA%3E%E6%A7%98%E3%80%81%3C%2FP%3E%0A%3CP%3E%E4%B8%A1%E6%96%B9%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(%20%3CSPAN%3ELSDK20.04-isc-09-Ubuntu%2018%20%E3%81%A8%20LSDK20.04-isc-19-Ubuntu20)%20%E3%81%AE%E9%96%93%E3%81%AB%E3%81%AF%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E6%9B%B4%E6%96%B0%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E9%96%8B%E7%99%BA%E8%80%85%E7%92%B0%E5%A2%83%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82LSDK21.08%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AE%E4%BD%BF%E7%94%A8%E3%82%92%E6%A4%9C%E8%A8%8E%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ELFGP%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
