LSDK RFS to NOR or NAND flash
2,290 次查看
nxf47487
Can I use flex-builder to deploy LSDK RFS to NOR or NAND flash? I only see RFS SD/USB deployment in the document. Thanks.
2,278 次查看
bpe
I assume flex-installer was actually meant because flex-builder cannot deploy anything, it is a build automation tool. flex-installer can only deploy to a block device while NOR and NAND memories are MTD. flex-installer cannot partition such devices, so flex-builder can build a rootfs for you, but you have to deploy it by hand.
Platon
2,296 次查看
nxf47487
Deleted
2,279 次查看
bpe
Platon
2,258 次查看
nxf47487
Thanks. I mean flex-installer for the deployment.
Another question about flex-builder. Can I use flex-builder to generate jffs2 rootfs image or initramfs rootfs?
