LS2088ardb stuck in System switches on, processor is not configured. State
prafulls
Hi Team,
    We are using device ls2088ardb, while bootup it stuck in some unknow state, an we are unable to get the console logs from UART terminal. Also the Power led blinks in Yellow color (System switches on, processor is not configured. ).
     Can you please suggest the recovery procedure for the device.
Prafull
ufedor
Please try alternative RCW_SRC options referring the QorIQ LS2085A/LS2088A Reference Design Board Getting Started Guide, Table 3. Switch configurations:
1) select NOR Flash virtual bank 4
2) select QSPI
3) prepare bootable SD card and select SD 2.0
NXP LSDK reference:
https://docs.nxp.com/bundle/GUID-487B2E69-BB19-42CB-AC38-7EF18C0FE3AE/page/GUID-956F22A7-1734-47B1-B...
ufedor
2) select QSPI
NXP LSDK reference:
prafulls
   Thank you for  sharing the useful information, which was very helpful to recovered ls2088ardb with given solution.
Prafull
