Hi Team,
We are using ls2088a in our board, can we get pin muxing details for LS2088ARDB and document for pin muxing in ls2088a.
Current version of the PinMux Tool allocates selected modules/signals and checks that the projected combination of modules/signals could be implemented in general.
It is required to use PBL Tool to implement the desired multiplexing in RCW.
For doing PIINMUX in RCW there is pinmultiplexing configuration field [302-825]. Here iam able to configure some of pins.
1. Iam not sure how to use this generated pinmux report in our custom board?
2.Is there any reference to do pinmux in u-boot and kernel?
The report shows that the projected combination of modules/signals could be implemented in general.
Pin multiplexing is possible only in RCW.
By design it is impossible to alter pin multiplexing during run-time.
Hi ufedor,
We want to make following pins as GPIO in RCW .
TSEC_1588_PULSE_OUT2,
TSEC_1588_PULSE_OUT1,
TSEC_1588_CLK_OUT,
TSEC_1588_ALARM_OUT2
TSEC_1588_ALARM_OUT1
TSEC_1588_TRIG_IN2
TSEC_1588_TRIG_IN1
TSEC_1588_CLK_IN
But we dont find any filed in RCW related to above pins in codewarrior. Kindly help us where we can modify.
For the LS2088ARDB please refer to the QorIQ LS2085A/LS2088A Reference Design Board Reference Manual, Chapter 3
Qixis Programming Model, 3.34 Board Configuration Registers.
For the LS2088A in general please refer to the QorIQ LS2088A Reference Manual and QorIQ LS2088A/LS2048A Data Sheet.
Please consider that CodeWarrior QorIQ Configuration and Validation Suite contains PinMuxing Tool for the LS2088A:
https://www.nxp.com/docs/en/user-guide/QCVS_PinMuxing_User_Guide.pdf
