Hi ,
I am trying to configure RTIC(Run time integrity Checker) on LS1046ARDB board. I want to set RTIC throttle register but I did not find any reference values for setting the Throttle value . Is there any additional document other than Trust2.1 and SECRM manual that can help us in deciding the throttle value?
Any suggestions would be appreciated.
Faizanbaig
已解决! 转到解答。
RTIC throttle register is to define how many SEC engine clocks to wait to launch the next descriptor to hash the next block of data. This is used to keep RTIC from using too much bus bandwidth.
So it depends on your use case and whether you are using the SEC engine for other operations (e.g. IPsec, VPN, TLS, etc).
I will suggest initially set RTIC Throttle (RTHR) at 0x176001c to 0xff000000, and adjust the value accordingly to your use case.
Thank you.
Could you please respond on https://community.nxp.com/t5/Layerscape/RTIC-Configuration-on-LS1046ARDB/m-p/1372745#M9398
