LS1046A L1 and L2 cache ECC
2,369件の閲覧回数
DaT63
Is ECC enabled by default for L1 and L2 caches on the LS1046A?
I know that this information is contained in register L2CTLR_EL1 , but I wonder if it is possible by program to access this register
Thanks in advance
タグ(4)
2,261件の閲覧回数
Hector_Villarruel
Hello @DaT63
Hope this post finds you well,
Yes, that is right.
As I inform you on my last reply:
L1 instruction, L1 data, and L2 caches, a Single-bit ECC correction is always enabled and is handled siliently.
Have a great day.
BR,
Hector V
3 返答(返信)
2,305件の閲覧回数
Hector_Villarruel
Hello @DaT63
Hope this email finds you well,
I apologize for the short delay regarding this case.
I would like to inform you that So for L1 instruction, L1 data, and L2 caches, a Single-bit ECC correction is always enabled and is handled siliently.
Regarding the L2CTLR_EL1,  in order to avoid any kind of confusion and keep the information as clear as possible, could you please let us know the register location in our LS1046A documentation?
Have a great day.
Hector Villarruel
2,295件の閲覧回数
DaT63
Hi @Hector_Villarruel ,
thank you for the reply. The L2CTLR_EL1 register is indicated in the ARM® Cortex®-A72 MPCore Processor TRM  that is accompanying the LS1046A Reference Manual. In any case if you state that ECC is always enabled  I do not need to check such a register and I can accept your  reply as solution
KInd Regards
タグ(4)
2,262件の閲覧回数
Hector_Villarruel
Hello @DaT63
Yes, that is right.
Have a great day.
BR,
Hector V
%3CLINGO-SUB%20id%3D%22lingo-sub-2004402%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELS1046A%20L1%20%E3%81%8A%E3%82%88%E3%81%B3%20L2%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%20ECC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2004402%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EECC%20%E3%81%AF%E3%80%81LS1046A%20%E3%81%AE%20L1%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%A8%20L2%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%AF%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BFL2CTLR_EL1%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%A7%E3%81%93%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%96%91%E5%95%8F%E3%81%AB%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2008106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ALS1046A%20L1%E3%81%8A%E3%82%88%E3%81%B3L2%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5ECC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2008106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F200047%22%20target%3D%22_blank%22%3E%40Hector_Villarruel%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82L2CTLR_EL1%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF%E3%80%81LS1046A%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AB%E4%BB%98%E5%B1%9E%E3%81%AE%20ARM%C2%AE%20Cortex-A72%C2%AE%20MPCore%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20TRM%20%E3%81%AB%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%84%E3%81%9A%E3%82%8C%E3%81%AB%E3%81%9B%E3%82%88%E3%80%81ECC%E3%81%8C%E5%B8%B8%E3%81%AB%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E8%BF%B0%E3%81%B9%E3%81%A6%E3%81%84%E3%82%8C%E3%81%B0%E3%80%81%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%A8%E3%81%97%E3%81%A6%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%BF%94%E4%BF%A1%E3%82%92%E5%8F%97%E3%81%91%E5%85%A5%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E6%95%AC%E5%85%B7%3C%2FP%3E%3C%2FLINGO-BODY%3E
