The FTF presentation material "FTF-DES-N1858_Security 201 Introduction to QorIQ Trust Architecture_v3.pptx" mentions "Hardware Key Pair Generation" in page 25. Is this function supported by the current LSDK? I cannot find any description about this function in LSDKUG. If not yet, will it be supported in future LSDK?
Solved! Go to Solution.
Yes, this feature is supported in the current LSDK, see details at the links below:
Hope this helps,
Platon
Hope this helps,
Platon
Thank you for the answer!
