Is it possible to reduce power consumption by disabling the CPU Core?
3,396 次查看
gyosunshim
I am using LSDK18.03-k4.9 for LS1043A.
This is a situation where a lot of heat is generated due to the system used without the FAN, so the power consumption must be reduced.
How can I disable power consumption if I can reduce it?
Desperately waiting for an answer.
Thank you,
Best regards.
Gyosun.
3,332 次查看
ufedor
Disabling a core is equivalent to stopping its internal clocks (PW15 low power state).
Estimated power saving from moving a core into PW15 state is provided in the QorIQ LS1043A, LS1023A Data Sheet, 3.5 Low power mode saving estimation.
For the LS1043A the saving is not significant, so there will be very small benefit in disabling cores.
Considering aforesaid it is needed to implement a heatsink having better cooling capabiliy.
5 回复数
3,333 次查看
ufedor
3,332 次查看
gyosunshim
Hi ufedor,
Thank you for the prompt response.
Lastly, I'll check only one.
If you set 3 of 4 cores to PW15 mode, can you understand that there is only 0.04w x 3 = 0.12w savings at 1GHz?
please answer about my question.
Thank you,
Best regards.
Gyosun.
3,332 次查看
ufedor
Your understanding is correct.
3,332 次查看
gyosunshim
Hi ufedor,
Thanks for the clear answer.
I'll approach it in a different way.
Thank you,
Best regards.
Gyosun.
3,080 次查看
notshure
hello gyosunshim,
I am also interested in disabling the CORE 1 (ARM a53), CORE 2 (ARM a53) and CORE 3 (ARM a53) of the QorIQ LS1043A. How did you finally solve this problem?
