How to edit device-tree of the tiny linux on ls1046a?
1,648 次查看
Stanleg
Dear nxp team:
our boad  changes the fman ethernet port to fixed link, and i have edited the fsl-ls1046a-rdb-sdk.dts, it works on lsdk linux, but when i boot board with tiny linux, it still working with the old device-tree, i want to know how to change the device-tree on tiny linux.
标签 (1)
2 回复数
1,636 次查看
yipingwang
Please replace the dtb file build/linux/kernel/arm64/LS/fsl-ls1046a-rdb-sdk.dtb in LSDK build envrionment.
1,631 次查看
Stanleg
   I am sure that fsl-ls1046a-rdb-sdk.dtb has replaced by the new file,and I used the fsl-ls1046a-rdb-sdk.dtb to boot LSDK linux, it worked without problem.
   So after rebuilding the dtb file, do i need some operations to rebuild the tiny linux ? According to my understanding,the tiny linux and it's device-tree are packed to the firmware.img file, but I don't know how to change the target file.
   So the problem is I can't change the target device-tree when I build the firmware.img file, or maybe I got it wrong.
