How can I run nfs-server on LS1046ardb?
chhsu0229
I have tried to install nfs-kernel-server, but it does not work and report as:
[FAILED] Failed to mount NFSD configuration filesystem.
See 'systemctl status proc-fs-nfsd.mount' for details.
[DEPEND] Dependency failed for NFS server and services.
[DEPEND] Dependency failed for NFS Mount Daemon.
[DEPEND] Dependency failed for NFSv4 ID-name mapping service.
[FAILED] Failed to start LSB: HPA's tftp server.
See 'systemctl status tftpd-hpa.service' for details.
I also try to find solutions on the web sit, Unfortunately, I have no idea.....
So, does anyone know how to enable nfs-server ??
nekarose
I am trying to run nfs-server on my custom LS1046a board.
Cound you tell me How to install nfs-kernel-server?
I don't know from that part.
Pavel
See attached file. It is snapshot from LSDK 1906 kernel menu.
Use the following command for kernel menu:
flex-builder -c linux:custom -a arm64 -m ls1046ardb
Pavel Chubakov
