How can I rebuild device tree of kernel independently, base on LSDK of lx2160a
156614400
How can I rebuild device tree of kernel independently, base on LSDK of lx2160a???1  /flexbuild_lsdk2004_update_290520/packages/linux\linux\arch\arm64\boot\dts\freescale
in this path, I change fsl-lx2160a-rdb.dts,  but How can I rebuild this dts independently to get dtb??
yipingwang
You could go to folder build/linux/linux/arm64/LS/output/LSDK-20.04-V5.4-update-290520 to run the following command.
$ make ARCH=arm64 freescale/fsl-lx2160a-rdb.dtb
You will get dtb file arch/arm64/boot/dts/freescale/fsl-lx2160a-rdb.dtb
156614400
use this ??
flex-builder -c linux -a arm64
yipingwang
