Solved! Go to Solution.
It is a solution that you can install 64bit ubuntu14-4.
You will compile code with float.
I traid 64bit ubuntu14.04.5,but this issue also exist, I use "arm-fsl-linux-gnueabi-gcc -march=armv7-a -mfloat-abi=hard -mfpu=neon-fp16 -mtune=cortex-a7 --sysroot=/opt/fsl-qoriq/2.0/sysroots/cortexa7hf-vfp-neon-fsl-linux-gnueabi -O2 -pipe -g -feliminate-unused-debug-types -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed test.c -o test" to compile, How can I solve this issue? Thank U
