Have support multiple PCI MSI interrupts on LS1043ARDB?
2,861件の閲覧回数
amw
my pcie device require 15 MSI interrupts,but I cannot  enable interrupts by pci_enable_msi_range or pci_alloc_irq_vectors interfaces.
pci_enable_msi_range always return 1,
I found that
static struct msi_domain_info ls_scfg_msi_domain_info = {
.flags = (MSI_FLAG_USE_DEF_DOM_OPS |
MSI_FLAG_USE_DEF_CHIP_OPS |
MSI_FLAG_PCI_MSIX),
.chip = &ls_scfg_msi_irq_chip,
msi driver support MSI_FLAG_PCI_MSIX,but not support MSI_FLAG_MULTI_PCI_MSI
my pcie device not support MSI-X,
How get 15 msi interrupts?
my build sdk is flexbuild_lsdk1812_update_010719
linux kernel version is 4.9.140
2,849件の閲覧回数
yipingwang
Please try to apply the attached patch.
As on ls1043a rev1.1 each MSI controller can support up to 32 MSI/MSI-X (with the kernel parameter lsmsi=no-affinity)
