Generating DDR firmware image for LX2160A
Nikhiln
I'm using LX2160A custom board. How to generate the DDR firmware image for our custom board?
I tried modifying some ATF source code timing parameters in LSDK location: flexbuild_lsdk2108_github\components\firmware\atf\plat\nxp\soc-lx2160a\lx2160ardb - platform_def.h and ddr_init.c files. But unable to find the fip_ddr_all.bin files anywhere and commands to generate it.
Tags (3)
Nikhiln
I referred the document from the link. I'm not able to find the configurations suggested in document for below paths:
Plat/nxp/<SOC>/<Board>/platform_def.h
Plat/nxp/<SOC>/include/soc.h
But I found the alternate files where I modified and the configurations which seem to be working. Is this user guide updated or I'm missing something?
Also, I tried the commands suggested in section "How to compile DDR FIP image (only applicable for LX2160ARDB Rev2 and LX2162AQDS)", and I was able to generate fip_ddr_all.bin.
Is fip_ddr_all.bin file common for all ddr configurations or it is dependent on DDR configuration change?
Also I'm not able to find anything related to fixed DDR on board configuration. All I found were for different types of DIMM configurations.
Does changes for DDR configurations in "Plat/nxp/<SOC>/<Board>/ddr_init.c" file will be reflected while generating fip_ddr_all.bin or I have to modify somewhere else while generating fip_ddr_all.bin?
