Flexbuild is showing linkage errors (media/platform/mxc) when building kernel, how to fix?
1,141 次查看
devnull0
I've created a custom device tree. Now I would like to build the kernel. When I execute ...
flex-builder -c linux:linux:LSDK-21.08-LS1046ASBCX1 -m ls1046asbcx1
... i get errors saying unexpected GOT/PLT entries detected and unexpected run-time procedure linkages detected. I really have no idea what I'm looking at here to determine how to fix this. Please see the attached file providing the output from the above command.
It appears as if flexbuild is trying to link against drivers down in "drivers/media/platform/mxc". I'm not even sure I need this mxc stuff but even if I don't need it I don't know how to remove it. Need some help here in fixing this. I don't believe I need this mxc (i'm on a custom layerscape LS1046a board).
1 回复
1,097 次查看
yipingwang
Please modify configs/board/ls1046ardb/manifest to replace all fsl-ls1046a-rdb-sdk.dtb with your dtb file name.
Then run flex-builder -c linux -m ls1046ardb
