Disable 10G port on LS1043ARDB
493 次查看
ts1234
I am facing a high temperature issue on 10G heatsink.  I want to test this board with 10G port disabled (both in uboot and kernel).
How do I permanently disable the 10G port on LS1043ARDB?
486 次查看
yipingwang
Please refer to section "32.1.1.2 SerDes protocols" in LS1043A Reference Manual, you could configure RCW filed SRDS_PRTCL_S1(RCW[128:143]) as "2455" to replace the default value "1455" to disable XFI.m9(10G port).
