root@localhost:~# restool dprc generate-dpl
/dts-v1/;
dpl-version = <10>;
* Containers
containers {
dprc@1 {
compatible = "fsl,dprc";
parent = "none";
options = "DPRC_CFG_OPT_SPAWN_ALLOWED", "DPRC_CFG_OPT_ALLOC_ALLOWED", "DPRC_CFG_OPT_OBJ_CREATE_ALLOWED", "DPRC_CFG_OPT_TOPOLOGY_CHANGES_ALLOWED", "DPRC_CFG_OPT_IRQ_CFG_ALLOWED";
objects {
/* -------------- DPBPs --------------*/
obj_set@dpbp {
type = "dpbp";
ids = <0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 >;
/* -------------- DPCONs --------------*/
obj_set@dpcon {
type = "dpcon";
ids = <0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 40 41 42 >;
/* -------------- DPDBGs --------------*/
obj_set@dpdbg {
type = "dpdbg";
ids = <0 >;
/* -------------- DPIOs --------------*/
obj_set@dpio {
type = "dpio";
ids = <0 1 2 3 4 5 6 7 >;
/* -------------- DPMCPs --------------*/
obj_set@dpmcp {
type = "dpmcp";
ids = <1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 29 30 31 32 33 34 35 36 37 38 39 40 41 42 51 52 53 54 55 56 57 58 59 60 >;
/* -------------- DPRTCs --------------*/
obj_set@dprtc {
type = "dprtc";
ids = <0 >;
dprc@2 {
parent = "dprc@1";
objects {
obj_set@dpbp {
type = "dpbp";
ids = <22 23 24 25 49 50 51 52 53 54 55 56 57 58 59 60 >;
obj_set@dpcon {
type = "dpcon";
ids = <32 33 34 35 36 37 43 44 45 46 47 50 51 >;
obj_set@dpio {
type = "dpio";
ids = <8 9 10 11 12 13 14 15 >;
obj_set@dpmcp {
type = "dpmcp";
ids = <25 26 43 44 62 63 >;
/* -------------- DPNIs --------------*/
obj_set@dpni {
type = "dpni";
ids = <5 6 7 8 >;
dprc@3 {
parent = "dprc@2";
objects {
/* -------------- DPAIOPs --------------*/
obj_set@dpaiop {
type = "dpaiop";
ids = <0 >;
obj_set@dpbp {
type = "dpbp";
ids = <28 29 30 31 32 33 34 35 >;
obj_set@dpmcp {
type = "dpmcp";
ids = <45 50 61 >;
dprc@4 {
parent = "dprc@3";
options = "DPRC_CFG_OPT_SPAWN_ALLOWED", "DPRC_CFG_OPT_ALLOC_ALLOWED", "DPRC_CFG_OPT_OBJ_CREATE_ALLOWED", "DPRC_CFG_OPT_TOPOLOGY_CHANGES_ALLOWED", "DPRC_CFG_OPT_AIOP", "DPRC_CFG_OPT_IRQ_CFG_ALLOWED";
objects {
obj_set@dpbp {
type = "dpbp";
ids = <18 19 20 21 26 27 36 37 38 39 40 41 42 43 44 45 46 47 48 >;
/* -------------- DPCIs --------------*/
obj_set@dpci {
type = "dpci";
ids = <1 >;
obj_set@dpcon {
type = "dpcon";
ids = <38 39 48 49 >;
obj_set@dpmcp {
type = "dpmcp";
ids = <27 28 46 47 48 49 >;
obj_set@dpni {
type = "dpni";
ids = <1 2 3 4 >;
* Objects
objects {
dpaiop@0 {
compatible = "fsl,dpaiop";
dpbp@0 {
compatible = "fsl,dpbp";
dpbp@1 {
dpbp@2 {
dpbp@3 {
dpbp@4 {
dpbp@5 {
dpbp@6 {
dpbp@7 {
dpbp@8 {
dpbp@9 {
dpbp@10 {
dpbp@11 {
dpbp@12 {
dpbp@13 {
dpbp@14 {
dpbp@15 {
dpbp@16 {
dpbp@17 {
dpbp@18 {
dpbp@19 {
dpbp@20 {
dpbp@21 {
dpbp@22 {
dpbp@23 {
dpbp@24 {
dpbp@25 {
dpbp@26 {
dpbp@27 {
dpbp@28 {
dpbp@29 {
dpbp@30 {
dpbp@31 {
dpbp@32 {
dpbp@33 {
dpbp@34 {
dpbp@35 {
dpbp@36 {
dpbp@37 {
dpbp@38 {
dpbp@39 {
dpbp@40 {
dpbp@41 {
dpbp@42 {
dpbp@43 {
dpbp@44 {
dpbp@45 {
dpbp@46 {
dpbp@47 {
dpbp@48 {
dpbp@49 {
dpbp@50 {
dpbp@51 {
dpbp@52 {
dpbp@53 {
dpbp@54 {
dpbp@55 {
dpbp@56 {
dpbp@57 {
dpbp@58 {
dpbp@59 {
dpbp@60 {
dpci@1 {
compatible = "fsl,dpci";
num_of_priorities = <0x2>;
dpcon@0 {
compatible = "fsl,dpcon";
num_priorities = <0x2>;
dpcon@1 {
dpcon@2 {
dpcon@3 {
dpcon@4 {
dpcon@5 {
dpcon@6 {
dpcon@7 {
dpcon@8 {
dpcon@9 {
dpcon@10 {
dpcon@11 {
dpcon@12 {
dpcon@13 {
dpcon@14 {
dpcon@15 {
dpcon@16 {
dpcon@17 {
dpcon@18 {
dpcon@19 {
dpcon@20 {
dpcon@21 {
dpcon@22 {
dpcon@23 {
dpcon@24 {
dpcon@25 {
dpcon@26 {
dpcon@27 {
dpcon@28 {
dpcon@29 {
dpcon@30 {
dpcon@31 {
dpcon@32 {
dpcon@33 {
dpcon@34 {
dpcon@35 {
dpcon@36 {
dpcon@37 {
dpcon@38 {
dpcon@39 {
dpcon@40 {
dpcon@41 {
dpcon@42 {
dpcon@43 {
dpcon@44 {
dpcon@45 {
dpcon@46 {
dpcon@47 {
dpcon@48 {
dpcon@49 {
dpcon@50 {
dpcon@51 {
dpdbg@0 {
compatible = "fsl,dpdbg";
dpio@0 {
compatible = "fsl,dpio";
channel_mode = "DPIO_LOCAL_CHANNEL";
num_priorities = <0x8>;
dpio@1 {
dpio@2 {
dpio@3 {
dpio@4 {
dpio@5 {
dpio@6 {
dpio@7 {
dpio@8 {
dpio@9 {
dpio@10 {
dpio@11 {
dpio@12 {
dpio@13 {
dpio@14 {
dpio@15 {
dpmcp@1 {
compatible = "fsl,dpmcp";
dpmcp@2 {
dpmcp@3 {
dpmcp@4 {
dpmcp@5 {
dpmcp@6 {
dpmcp@7 {
dpmcp@8 {
dpmcp@9 {
dpmcp@10 {
dpmcp@11 {
dpmcp@12 {
dpmcp@13 {
dpmcp@14 {
dpmcp@15 {
dpmcp@16 {
dpmcp@17 {
dpmcp@18 {
dpmcp@19 {
dpmcp@20 {
dpmcp@21 {
dpmcp@22 {
dpmcp@23 {
dpmcp@24 {
dpmcp@25 {
dpmcp@26 {
dpmcp@27 {
dpmcp@28 {
dpmcp@29 {
dpmcp@30 {
dpmcp@31 {
dpmcp@32 {
dpmcp@33 {
dpmcp@34 {
dpmcp@35 {
dpmcp@36 {
dpmcp@37 {
dpmcp@38 {
dpmcp@39 {
dpmcp@40 {
dpmcp@41 {
dpmcp@42 {
dpmcp@43 {
dpmcp@44 {
dpmcp@45 {
dpmcp@46 {
dpmcp@47 {
dpmcp@48 {
dpmcp@49 {
dpmcp@50 {
dpmcp@51 {
dpmcp@52 {
dpmcp@53 {
dpmcp@54 {
dpmcp@55 {
dpmcp@56 {
dpmcp@57 {
dpmcp@58 {
dpmcp@59 {
dpmcp@60 {
dpmcp@61 {
dpmcp@62 {
dpmcp@63 {
dpni@1 {
compatible = "fsl,dpni";
type = "DPNI_TYPE_NIC";
options = "DPNI_OPT_HAS_POLICING";
num_queues = <4>;
num_tcs = <4>;
num_cgs = <4>;
mac_filter_entries = <8>;
vlan_filter_entries = <8>;
fs_entries = <3>;
qos_entries = <64>;
dist_key_size = <56>;
dpni@2 {
num_queues = <4>;
num_tcs = <4>;
num_cgs = <4>;
fs_entries = <3>;
qos_entries = <64>;
dpni@3 {
num_queues = <4>;
num_tcs = <4>;
num_cgs = <4>;
fs_entries = <3>;
qos_entries = <64>;
dpni@4 {
num_queues = <4>;
num_tcs = <4>;
num_cgs = <4>;
fs_entries = <3>;
qos_entries = <64>;
dpni@5 {
num_queues = <4>;
num_tcs = <4>;
num_cgs = <4>;
fs_entries = <3>;
qos_entries = <64>;
dpni@6 {
num_queues = <4>;
num_tcs = <4>;
num_cgs = <4>;
fs_entries = <3>;
qos_entries = <64>;
dpni@7 {
num_queues = <4>;
num_tcs = <4>;
num_cgs = <4>;
fs_entries = <3>;
qos_entries = <64>;
dpni@8 {
num_queues = <4>;
num_tcs = <4>;
num_cgs = <4>;
fs_entries = <3>;
qos_entries = <64>;
dprtc@0 {
compatible = "fsl,dprtc";
* Connections
connections {
connection@1{
endpoint1 = "dpci@1";
endpoint2 = "dpci@0";
connection@2{
endpoint1 = "dpni@1";
endpoint2 = "dpni@5";
connection@3{
endpoint1 = "dpni@2";
endpoint2 = "dpni@6";
connection@4{
endpoint1 = "dpni@3";
endpoint2 = "dpni@7";
connection@5{
endpoint1 = "dpni@4";
endpoint2 = "dpni@8";
