Creating a new custom LS1046a machine, do I create a new fsl-xx-sdk.dts or fsl-xx.dts?
1,387 次查看
devnull0
I would like to create a new custom machine (based on a LS1046A) and in doing so means I need a device tree file (dts). I was hoping there was a baseline dts I could base my new dts file off of. I was hoping I could use the "fsl-ls1046a-rdb.dts" but I'm really confused on what the "fsl-ls1046a-rdb-sdk.dts" is. If I create a new dts file do I need an accompanied sdk.dts? Can you provide some direction/guidance here? I don't understand why NXP has defined two dts files and which one I should be basing a new dts file off of.
2 回复数
1,369 次查看
LFGP
in order to get an idea how to add custom layer to your image, please read the next pdf
https://www.nxp.com/docs/en/user-guide/LSDKYOCTOUG.pdf
1,371 次查看
LFGP
Yes, you can use the fsl-ls1046a-rdb.dts as a baseline for your own device tree, you don't need an accompanied sdk.dts
I suggest to read the book "Mastering Embedded Linux Programing" in order to get the "What and HOW"
