Closed
Closed
3,484 次查看
mrybaizine
Closed
标签 (2)
3 回复数
3,204 次查看
yipingwang
Hello mrybaizine,
Please refer to the following procedure.
1. $ flex-builder -i clean-rfs -r ubuntu:lite
2. Please modify configs/ubuntu/additional_packages_list as the following.
additional_lite_packages_list="systemd udev net-tools iputils-ping isc-dhcp-client libxml2-dev libnl-genl-3-dev libreadline-dev libtinfo-dev sudo"
3.$ flex-builder -i mkrfs -r ubuntu:lite
4.$ flex-builder -i packrfs -r ubuntu:lite
Yiping
3,203 次查看
yipingwang
I have applied this patch in LSDK 19.09 and generate a new ubuntu:lite rootfs filesystem, I verified it on my LS1046ARDB, it worked without networking setting up problem.
Please refer to my procedure.
1. Please modify configs/ubuntu/additional_packages_list as the following.
2. Please remove build/rfs/rootfs_lsdk1909_LS_arm64_lite/
$ sudo rm -rf build/rfs/rootfs_lsdk1909_LS_arm64_lite/
or
3. Please rebuild unbuntu:lite rootfs
$ flex-builder -i mkrfs -r ubuntu:lite  -a arm64
4. After execute the following command, please deploy build/images/rootfs_lsdk1909_LS_arm64_lite.tgz to your target board.
Yiping
3,203 次查看
yipingwang
Hello mrybaizine,
I also reproduced similar problem with LSDK 19.09, I just discussed with the LSDK testing and development team, this ubuntu-based lite userland booting issue has been fixed in LSDK 2003 release,please refer to the following patch.
The testing team provided rootfs_lsdk2003_ubuntu_lite_arm64.tgz in the following link, please try to use it.
https://drive.google.com/open?id=1aaW9raM-VZBTi_sUFbWBwaT1QXMe2zzi
Patch:
+++ b/configs/ubuntu/additional_packages_list
@@ -21,7 +21,7
- libnl-genl-3-dev libreadline-dev libtinfo-dev"
+ libnl-genl-3-dev libreadline-dev libtinfo-dev sudo"
Yiping
