Building DPDK reordering application for LS2088
1,097件の閲覧回数
sedat_altun
Hi community,
I want to build DPDK packet reordering sample application to run on LS2088RDB. I am using flexbuild to compile the components. After successfully building with flexbuild I got some dpdk applications under images subdirectory like l2fwd, but there is no reordering application at this directory , Is there any way to build dpdk ordering application with flexbuild for LS2088 RDB board?
Thanks in advance
ラベル(2)
タグ(2)
975件の閲覧回数
yipingwang
Please modify packages/apps/Makefile as the following.
$(MAKE) -j$(JOBS) -C l2fwd && $(MAKE) -j$(JOBS) -C l3fwd && $(MAKE) -j$(JOBS) -C cmdif && $(MAKE) -j$(JOBS) -C l2fwd-qdma && \
$(MAKE) -j$(JOBS) -C l2fwd && $(MAKE) -j$(JOBS) -C l3fwd && $(MAKE) -j$(JOBS) -C cmdif && $(MAKE) -j$(JOBS) -C l2fwd-qdma && $(MAKE) -j$(JOBS) -C packet_ordering && \
2 返答(返信)
976件の閲覧回数
yipingwang
975件の閲覧回数
sedat_altun
Thank you very much for your help. I was able to built DPDK packet_ordering application by editing Makefile but I couldnt find any help about how to run the application. In LS2088 SDK document some DPDK applications like l2fwd are explained but there is no help about ordering application. Could you please help us about how to run this application or which documents do we have to refer for running this application on LS2088.
Best regards.
